July 27th, 2011, 09:03 PM | #1 |
Join Date: Mar 2010 Motorcycle(s): Kawasaki Ninja 250R 09 Posts: 4
Replaced Sprockets with t15/t44 now strange noise
Hi all,
First time post.. i think? i have changed the sprockets on my 2009 ninja and now i am getting a weird click sounds coming from the front sprocket. Even when rolling my bike along the driveway. I took the sprocket cover off and the sound is coming from where the chain meets the front sprocket like it is not fitting properly. i can see the chan drop into the sprocket and vibrate. Has anyone seen this? it seems to work fine and as far as i can work out may just mean my chain and sprocket wont last as long. Cheers, Simon |
July 28th, 2011, 06:34 AM | #2 |
What brand and # parts did you use? Who did the swap? Has the chain been adjusted and aligned properly?
July 28th, 2011, 12:50 PM | #3 |
Alignment and proper slack in chain? Sounds tight from your description.
July 28th, 2011, 02:40 PM | #4 |
Which direction did you put the sprocket on? The DIY on this forum has it backwards. Label towards the engine if you bought a JT sprocket. As for clicking, I have a little bit of clicking even with the chain slack on the loose side. After some extensive reading, there are some reports that it's just the sound of the chain hitting the sprocket and the noise is louder because there is no rubber cushion like the stock sprocket has.
I'm not saying that there isnt a problem but if you've checked everything, and it is all in spec, then I'd say dont worry about it and ride-on. |
July 28th, 2011, 04:51 PM | #5 |
it was a JT and i have put the spacer side towards the engine i cant remember the part number due to throwing the packaging out and it facing the engine. I bought it from the local kawi dealer so i hope they sold me the newer model one.
the slack seems perfect as per the manual but that might change when you have different size sprockets? pushed my wheel all the way forward when i put it back on and evenly tightened it up so i am not sure what else i can do to align the sprockets. Whats the best way to see if they are aligned? I do think its just the chan slapping onto the sprocket so not sure if its a big deal. well i hope it isnt :S |
July 28th, 2011, 04:59 PM | #6 |
and if its a little tight it will loosen shorty right? >_<
July 28th, 2011, 06:23 PM | #7 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
I wonder if you got a pre-gen front sprocket that requires a shim to align correctly.
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
July 28th, 2011, 07:48 PM | #8 |
Not a great idea; if it really is too tight it can damage the transmission and/or bearings well before it stretches to proper clearance.
July 28th, 2011, 09:00 PM | #9 |
Really depends on how tight you're talking about. You'll need to be your own judge of if it's too tight. Check every spot on the chain to make sure you have the tightest point to the loosest side of the specs. Otherwise, it should be fine.
If the sprocket is the correct one, I doubt you have a problem. Also make sure you lube up the sprocket and chain thoroughly. It helps with the smoothness and could also contribute to noise. |
July 29th, 2011, 03:53 PM | #10 |
I have already checked the chain slack all the way round and its fine.
The sound happens all around the chain so i dont think it will be the tightness. Next time i clean the bike up i will pull the font sprocket off and have a look at the model. You mention that you are meant to lube the sprocket itself? i think i missed that. what do i use to do that? |
July 30th, 2011, 02:35 AM | #11 | |
Really though, if everything is put together correctly and in specifications. I bet you it's just the lack of rubber dampener that the stock has. Like I said, my chain makes that clicking noise too but runs great. Cant think of anything else to do with it. |
Strange Noise when Accelerating w/Video | SDx | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 7th, 2013 10:34 AM |
Strange Noise | msebastian | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 20th, 2013 06:55 PM |
Strange Noise please help | Darkspy72 | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 20th, 2012 06:18 AM |
Strange Noise at ~6000 RPM | forevertwowheels | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 20th, 2012 06:15 AM |
4th gear strange noise | enneract | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 11th, 2012 08:49 PM |
