October 4th, 2012, 11:13 AM | #1 |
New Member: A Fixer-Upper
Hey guys!
I just bought a '10 Ninja 250 yesterday and It needs a few things fixed on it. Ive been searching long an hard but am having trouble understanding. Problem 1: No Right Turn Signal, could I just buy this part off amazon and connect the 2 ends? http://www.amazon.com/2008-2012-Kawa.../dp/B004XAT6AI Or do I need to just remove the entire turn signal? and if so the item above should be the only thing I need to buy to fix the problem? Problem 2: How to remove water from headlight? Is it possible? |
October 4th, 2012, 11:40 AM | #2 |
Blind 250 Loving Whore
modmy250.com has flush mount LED turn signals that are plug and play. The owner is a member here. Now would be a perfect time to upgrade.
As far as water in the headlight, you should be able to just pull it out and take the bulbs out and dry if out. The front plastic is accessible from the back holes so it should dry out. |
October 4th, 2012, 12:29 PM | #3 |
To unfog the headlight, remove the headlight bulbs and get it warm in a dry environment. You shouldn't even have to move air, which will introduce dust anyway.
October 4th, 2012, 01:54 PM | #4 |
/thread moved to new-gen tech talk
October 4th, 2012, 03:51 PM | #5 |
Welcome!
October 4th, 2012, 03:58 PM | #6 |
thanks a bunch guys! Im going to give that unfogging (lol) a try. As far as the right turn signal I guess ill just order that part off of amazon and see if I can replace it myself, because I still need to get the whole bike inspected
Ninjette users vs fixer uppers | IF13 | General Motorcycling Discussion | 7 | October 13th, 2013 07:06 PM |
[superbikeplanet.com] - Ben Spies: The Fixer-Upper | Ninjette Newsbot | Motorcycling News | 0 | August 16th, 2013 08:40 AM |
scratch fixer and yellow paint fixer for cars?? | Mr.E | Off-Topic | 1 | August 8th, 2011 08:29 AM |
New Member | xjapa1n | New Members | 8 | September 9th, 2009 08:40 PM |
