November 3rd, 2012, 03:21 PM | #1 |
Join Date: Nov 2012 Motorcycle(s): 2003 ninja 250 Posts: 9
03 250 choke stuck??
I have had a problem with a high idle for a little while, I had an air leak that I just fixed but it still does it. when it is already warm and I start it it shoots up to 3000 to 4000 rpms. I checked the throttle cable which seems fine. the choke cable seemed fine too but I put the tank back on and started it with the hose that goes to the choke from the petcock disconnected, at least what I believe is the hose that serves as the bypass for the choke, it was the smaller of the two and connected to the carb right under the choke cable. when started the bike idled perfectly. My problem is that the choke cable has play in it. so I don't think adjusting it will solve this. do I need to open up the carb and adjust something??? please help....
OK, so there is probably another air leak too, sprayed some starter fluid up by the boots and the idle went up.....I messed with the idle mixture screws before that so I think I'm gonna take the carb off and set those to stock since they are hard to adjust on the bike. then I can look at the boots.. Last futzed with by curioussavage; November 3rd, 2012 at 04:28 PM. |
November 3rd, 2012, 08:22 PM | #2 |
If your gunna take the carbs off, then might as well clean them while your at it. One problem off the table. Sounds like your on your way to getting it right though.
Best of luck!
November 7th, 2012, 06:38 PM | #3 |
yep
ya I already cleaned the carbs, the guy I bought it from had left it sitting so they were gummed up. they should be fine, unless some crap in the tank got in there...this idle really bugs me, it sits at 6000 rpms after I get going.
November 7th, 2012, 07:32 PM | #4 | |
If too much or not enough cable play, there is an adjustment under the gas tank (left side). The cable and actuator may need some lubrication. Nothing to adjust inside the carb regarding the choke.
November 15th, 2012, 06:31 AM | #5 |
Did you turn the idle adjuster down? Maybe it's simply set to high.
November 15th, 2012, 07:01 PM | #6 |
hmmm
so I actually just took it all apart took the carb off sprayed the carb out a bit and put it all back together. between me an my brother who just broke a valve guide(sucks) we have taken these apart quite a few times. got everything seated perfect. and it still idled high when I started it, adjusted the idle adjuster a few times it kept going up again. after I rode it a block it went down and stays down pretty much where it is supposed to, But... it seems to waver a little, its not a steady idle. I need to change the oil. but could that mean I need a valve adjustment maybe??
November 16th, 2012, 09:31 AM | #7 |
Yes, if the last adjustment was done more than 6K miles ago or improperly.
However, don't agonize over the idle rpm's, if they are low enough to facilitate gear changes, they are OK. Ride that thing away and get to know her better.
November 16th, 2012, 09:53 AM | #8 |
If your idle is jumpy, check the simple stuff first;
Airbox - clean and clear Air filter - clean and clear Vac lines - no leaks Carb boots no leaks Idle jets - clean and clear Carb sync - must be synced Fuel filter - free flowing Petcock - free flowing Plugs and wires - not fouled, gapped and not arcing Battery - holds charge and proper output voltage As long as there is nothing major wrong, getting a smooth idle shouldn't be to hard.
November 16th, 2012, 11:58 AM | #10 |
a bit out of sync is no problem. enjoy riding her. do lots of brap braping and maybe some yut-ughs
Stuck bikeless | Toly | The Ex-Ninjetters Lair | 18 | January 29th, 2015 07:44 PM |
STUCK! on the way to the dragon | 7oxSin | 1986 - 2007 Ninja 250R Tech Talk | 8 | March 20th, 2014 10:09 PM |
Cold and stuck | blink | General Motorcycling Discussion | 6 | November 21st, 2011 03:06 PM |
09 Ninja 250 Choke and Throttle ? | ozuhas | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 19th, 2009 11:09 AM |
I am stuck at a crossroads | travis5018 | General Motorcycling Discussion | 19 | January 19th, 2009 07:48 PM |
