Old April 14th, 2019, 03:17 PM   #1
TorontoNinja
Motorcycle(s): 2009 Kawasaki Ninja 250, 1975 Kawasaki G3SSE
Throttle kills the bike
Hi guys, so out of boredom and winter blues, I took the carbs out and put it back in, I'm an HVAC Mechanic so I felt comfortable removing it and putting it back in. I didn't do anything to the carbs beside taking them out and putting them back in. Now when I start my bike, it idles beautiful, I usually keep it around 1700rpm. As soon as I move the throttle the bike dies on me. Not sure where I ****ed up. The only thing I was unsure of was the cables coming back from the throttle, I'm not sure how tight the two nuts are supposed to be that attach to the carb. Any help would be appreciated, thanks.
TorontoNinja is offline   Reply With Quote
Old April 14th, 2019, 03:46 PM   #2
You mean you removed the carbs and reinstalled them without doing anything else to them? Maybe in jostling them around your freed up some debris that got stuck in the main jet(s). That would kill the midrange and wide-open throttle running.
Last futzed with by Triple Jim; April 16th, 2019 at 08:59 AM.
Old April 14th, 2019, 04:24 PM   #3
Yup, carbs need thorough deep cleaning and refurb.
Old April 15th, 2019, 05:51 AM   #4
before you rip the thing apart, try fresh fuel, get ALL the old out of the tank, drain the bowls, retry with 100% absolutely fresh fuel.
The throttle cables must have adequate freeplay to allow full closure of the throttle plates. Fine tune the freeplays to enable acceptable "snapback". Obviously, avoid, adjust and correct any hanging up of the throttle.
Old April 15th, 2019, 04:47 PM   #5
Yeah, set the cable adjustment for about 1mm of movement before it pulls on cable. Ensure that throttle fully closed.
Old April 16th, 2019, 07:33 AM   #6
TorontoNinja
Thank you guys for the responses. I'm going to try to adjust the throttle cables at the carb because that's what I feel like I had an issue with as I didn't remember how much they were tightened.
So I should adjust it so I have 1mm-2mm play on my throttle grip? Are there any other tips for adjusting it that I should be aware of?
Thanks
Old April 16th, 2019, 08:17 AM   #7
Nah...other than setting freeplay at the throttle, 1-2mm insufficient there. Danno, I believe, was referring to the cables at the carbs.
I believe there is a spec in the service manual for actual freeplay measured at the throttle grip...3-5mm? Anybody?
Don't let the grip rub against the switch housing....a very common assembly error in "my throttle is sticking" issues. If need be, pull it back to bar end slightly.
Old April 22nd, 2019, 10:20 AM   #8
TorontoNinja
Thank you guys for all the help, playing around and adjusting the throttle cable at the carbs brought it back to its former glory. Appreciate all the help. Ride safe.
Old May 1st, 2019, 08:58 PM   #9
Tooch
Tooch's Avatar
Motorcycle(s): 2008 Ninja 250, 2015 zx10r, 2010 Ducati 848
I'm glad you got that sorted! But can anyone explain how/why cable adjustment at the carbs causes it to die when throttle is applied?
Tooch is offline   Reply With Quote
Old May 1st, 2019, 09:45 PM   #10
It can't.
Desperate Student! 2006 250 Lengthy Post; Throttle kills Engine, Full Choke on noah_karch 1986 - 2007 Ninja 250R Tech Talk 33 April 6th, 2017 07:57 AM
Full throttle kills bike, throttle lag response. Diegone 2008 - 2012 Ninja 250R Tech Talk 10 April 30th, 2014 03:25 AM
[twisted throttle] - Twisted Throttle adds a 2012 DL650 V-Strom to the project bike l Ninjette Newsbot Motorcycling News 0 March 13th, 2012 11:40 AM
[twisted throttle] - Triumph Street Triple (2012) - Twisted Throttle Project Bike Ninjette Newsbot Motorcycling News 0 February 13th, 2012 07:10 AM
[roadracingworld.com] - AMA: House Kills Dirt Bike Ban On 2-Million Acres Of Public L Ninjette Newsbot Motorcycling News 0 March 11th, 2009 05:20 PM
