June 11th, 2014, 01:05 PM | #1 |
Biker Noob
Join Date: Apr 2014 Motorcycle(s): 2004 Honda Shadow 750 Aero Posts: 176
15 Tooth Front Sprocket is My Bitch Please look at pics
It's done, I did it on my fing own. I can shift through all the gears just fine.
Please look at the pics to make sure I have done this correctly. The pics are of the sprocket installed, the shift pedal still the wrong one, waiting on the new one to come, and the last is the back tire I want to make sure its on correct. Please let me know if I need to correct something.
Riding as I stole it. |
June 11th, 2014, 02:00 PM | #2 |
June 11th, 2014, 02:01 PM | #3 |
Biker Noob
June 11th, 2014, 02:04 PM | #4 |
Looks fine to me via the pics. How did your torque your front sprocket?
June 11th, 2014, 02:09 PM | #5 |
Biker Noob
A 27 mm socket while holding the rear break. Funny thing is the 14 tooth sprocket was not on all that tight. I made sure that this was on real tight.
June 11th, 2014, 02:11 PM | #6 |
Biker Noob
Learned that trick off you tube.
June 11th, 2014, 02:11 PM | #7 |
June 11th, 2014, 02:14 PM | #8 |
Biker Noob
Doing that as we speak.
test rode it got to 70 mph in 6th at 7 K Rpms
June 11th, 2014, 02:16 PM | #9 |
June 11th, 2014, 02:38 PM | #10 |
Biker Noob
Do not know, however I will tell you in 30 mins. I will see how a 15/42 is like.
June 11th, 2014, 03:08 PM | #11 |
Biker Noob
Ok. Highway riding is nice 6th gear showing 60, really going 55 at less than 7 K rpms. Man I am going to get good gas mileage. That 15/42 combo is really nice
June 11th, 2014, 03:14 PM | #12 |
and now you have the know-how to go back to that shop and tell them how retarded they are.
June 11th, 2014, 03:14 PM | #13 |
My preferred gearing for everyday street riding. Hope you like it.
June 11th, 2014, 03:21 PM | #14 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
Glad you finally resolved this! Good on you, and good job.
June 11th, 2014, 03:28 PM | #15 |
Biker Noob
Already called them and told them that. I also told them that I will no longer shop with them. Their loss as I am about to buy a cruiser next week.
On the gearing note. I get a whole lot less vibration. With this set up. I can also get to 30 mph in first gear at like 9 k rpms which is nice. TBA I owe you all a thanks. You all told me I could do this I just did not have the self confidence.
June 11th, 2014, 04:16 PM | #16 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
Good work, welcome to the DIY club
As Dablue1 says, get the washer tapped over a bit more Ideally one flat Last futzed with by Ninjinsky; July 11th, 2014 at 07:28 AM. |
June 11th, 2014, 04:36 PM | #17 | |
Biker Noob
Done. Just did not post that pic as I wanted to ride before it rained.
June 11th, 2014, 08:18 PM | #18 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
Very nice results! Good job. I might consider this as well. Did you change the rear too or just the front ?
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
June 11th, 2014, 10:24 PM | #19 |
Biker Noob
I changed the rear to a 42 tooth 4 weeks ago.
June 12th, 2014, 05:13 AM | #20 |
Fast-Guy wannabe
MOTM - Jan '13
And we had all pretty much given up hope with you with a mass group but then weeks later you go and do this so your status as a competent human has be re-established
Now the real question now that you know how its done right is how where they doing it wrong? |
June 12th, 2014, 05:25 AM | #21 |
Biker Noob
You know I am not sure what they did wrong and what I did different. Other than following what you all said to do.
It's beyond me whay they did different.
15 tooth Front sprocket | reroka | 2008 - 2012 Ninja 250R Tech Talk | 16 | April 24th, 2014 01:07 PM |
15 tooth front sprocket | sidekick10121 | 1986 - 2007 Ninja 250R Tech Talk | 3 | March 16th, 2014 01:04 PM |
13 Tooth Front Sprocket from PitBull | 1ER6F | Motorcycle-related | 0 | April 23rd, 2013 09:32 PM |
JT Sprocket 42 tooth Rear Sprocket | lolibater | Motorcycle-related | 36 | February 25th, 2013 12:30 PM |
15 Tooth Front Sprocket | FerociousNINJA | 2008 - 2012 Ninja 250R Tech Talk | 5 | September 14th, 2010 05:21 AM |
