Old August 12th, 2023, 09:05 PM   #1
begnrrider
Motorcycle(s): 2006 Ninja EX250
Angry Carburetor problems...
Got this motorcycle from a family member, it has been sitting for 10 years. Just cleaned the carbs (bowls, jets etc...) put it back in and got a new battery. Cranks and turns over but no start. So I sprayed a little starter fluid into the airbox and it revs up 3-5k rpm and dies, throttle doesn't help to keep it running. I know its looking like a carb rebuild, but is there any tricks I can try or things to look at before then?
Thank you!!
begnrrider is offline   Reply With Quote
Old August 12th, 2023, 09:18 PM   #2
Hi, greetings & salutations!!!
There's A LOT of specialised equipment and decades of experience needed to properly do restoration job on these carbs. Especially one that's been sitting that long. Many expert mechanics have had to pull carbs 4-5 times for ever deeper cleaning before bike would run right. One guy had to pull cabs 10 TIMES!
I suggest sending carbs and petcock to ducatiman (Gordon) at this outfit. Expert workmanship, reasonable fees and quick turnaround. Carbs will come back factory-fresh OEM clean. Bike will run like brand-new off showroom floor!
https://customcarbservices.com
BTW - you can search for "clean carbs ducatiman" for reviews and kind of work involved to refurb carbs.
Old August 13th, 2023, 05:21 AM   #3
I second the recommendation of Ducatiman's work. I had him restore a set and they arrive back here in perfect condition less than a week later.
Whatever you do, don't use jets from a rebuilt kit. Kits contain non Keihin jets that aren't identical to the orignials, and you'll end up in an endless tuning project.
Old August 13th, 2023, 12:54 PM   #4
ducatiman
ducatiman's Avatar
Carbs sitting with fuel for 10+ years will certainly present a challenge. Every circuit will, no doubt, be affected, likely clogged solid...requiring much more than a brush and a spraycan of carb cleaner. Every oring/seal will require replacement as will float valves with brand new. A lot to consider.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Carburetor help curlyfriezzz 2008 - 2012 Ninja 250R Tech Talk 8 December 4th, 2022 06:21 AM
Carburetor hosing help!!! Juliamun111 2013 - 2017 Ninja 300 Tech Talk 11 January 23rd, 2019 12:37 PM
carburetor skip 2008 - 2012 Ninja 250R Tech Talk 9 June 5th, 2017 12:39 PM
Carburetor - what maintenance? LemonSlice! 1986 - 2007 Ninja 250R Tech Talk 4 July 17th, 2013 09:48 AM
problem with carburetor maybe? alex.bowles 1986 - 2007 Ninja 250R Tech Talk 40 March 18th, 2013 12:58 PM
