Old July 18th, 2013, 06:46 PM   #1
Cosmos
Thumbs up Another tach issue
Hello Everyone,
I am having an issue with the tachometer as follows:
On every run, after 5 mins or so of run time and riding ,the tachometer stops working ( zero reading ) for around 3-4 minutes and it is back to normal like nothing happened.
The bike pulls hard and performance is not affected... Could someone the steps to troubleshoot the issue, how is the tach connected to the motor ?
Can i check if some connections are loose, what can be done before actually replacing the tachometer..
It is a ninja 2011, if that helps
Thankyou
Cosmos is offline   Reply With Quote
Old July 19th, 2013, 06:01 AM   #2
Welcome Ben!
Others here and there have had similar issues. Some where fixed by replacing the tach, others replaced their CDI. As far as troubleshooting yours, follow the below steps.
Old July 19th, 2013, 06:04 AM   #3
Cosmos
thank you so much, much appreciated
New to forums and motorcycles, but need help with tach issue :( Gaaldornick 2008 - 2012 Ninja 250R Tech Talk 16 December 16th, 2014 07:08 AM
Tach does not exceed 4k bryzenga 1986 - 2007 Ninja 250R Tech Talk 4 October 18th, 2013 06:59 PM
Ic ignitor or tach issue and dealership kittyslasher 2008 - 2012 Ninja 250R Tech Talk 13 June 21st, 2013 04:34 AM
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue Ninjette Newsbot Motorcycling News 0 May 11th, 2010 07:50 AM
Have a lean issue with my bike, issue with coasting enricher. twiggy2cents 1986 - 2007 Ninja 250R Tech Talk 7 February 24th, 2010 06:54 PM
