November 28th, 2012, 10:16 PM | #1 |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
Wider rear rim RACE LEGAL?
If i get one of those aftermarket wider rims for the rear will I be unable to race in any 250 orgs?
It doesn't LOOK that steep. But you can go first... |
November 28th, 2012, 11:52 PM | #2 |
CVMA/AFM #72
Join Date: Oct 2009 Motorcycle(s): 2009 Ninja 250r (Racebike), 2015 FZ-07(Tourer), 2001 KX65(LOL bike) Posts: A lot.
Well, depending on where you want to race. If you head up north, AFM has a superbike class that should allow that, but you couldn't race in their production class.
If you want to race all over, I THINK wera west has a class that formula 250s can run in, but once again, you couldn't run in their superstock class. The new Willow series has still yet to release their rulebook or expected list of classes, so you may be able to race it there, too, if they also end up having a formula based 250 class. But, you could not currently race a 250 without stock wheels at CVMA unless you want to race a bunch of 650s and a 250 2 stroke in Formula 2. If you just want to do trackdays, have at it. But if you want to race it, it really wouldn't be a worthwhile investment |
November 29th, 2012, 07:16 AM | #3 |
CVMA#747 Ⓓⓜⓔⓝⓣⓔⓓ ⓡⓐⓒⓘⓝⓖ
Join Date: Sep 2011 Motorcycle(s): 09 250R * 09 Yamaha R6 * 08 CBR 1000RR * 04 NSR 50 * 02 KX 250 Posts: A lot.
you REALLY want a wider rear rim on your 250?
most cats already scrape hard parts and bodywork. you trying to have it more stable at full lean or sumfin?
**CVMA#747**AFM#747R**M1GP#77**LeoVince*RaceTech*Hotbodies*Cyclemall*Bridgestone * Motorad*Dainese*PolyMoto*Woodcraft**Visit The Dmented Racing Youtube Channel* |
December 2nd, 2012, 11:47 PM | #4 |
Nerd
I want it to lean mooooorrrrrrr. Like R6 Status!
December 3rd, 2012, 12:03 AM | #5 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
So you're parting out your 250, and want a wider rim for it? You're confusing!
On the other hand, don't get the rim. If you want to lean more GET YOUR BUTT OFF THE SEAT
CVMA #531 |
December 3rd, 2012, 08:33 AM | #6 |
maaaan... you need to visit the "LEAN" thread... some of us are scraping bodywork on our 250's. most of us drag shifter lever (i know i do). ninja's lean homie, you just gotta make it happen!
December 3rd, 2012, 08:44 AM | #7 |
I know EXACTLY how you feel brother. Check here.
Some great pics in there and some nuggets of great setup info. In the end, I just came to realize that without heavy modification, a 250 isn't gunna lean at speed like a 600 and feel as planted. Add your pics in there while your there.
December 7th, 2012, 05:58 PM | #8 | ||
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
You can accomplish the same thing with going with a wider tire. I think the widest you can go is 150. OEM is 130. Have you tried a 140 or 150 rear tire to see if that helps?
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
December 7th, 2012, 08:38 PM | #9 |
Join Date: Feb 2011 Motorcycle(s): Green 2013 ZX-6R Posts: 723
It's only illegal if you get caught. However if you're going to cheat you might want to do something that actually gives you an advantage.
http://www.simplysurrealphotography....es/peanut2.png |
December 8th, 2012, 09:12 AM | #10 |
What would a wider wheel do? The profile of a 140 tire is great on the stock rim.
Lot of local guys are running a 120 rear, how about a skinnier wheel |
Plug and Play 4.5 rear Rim? | joes280 | 2008 - 2012 Ninja 250R Farkles | 345 | August 1st, 2014 01:21 AM |
08-12 front and rear rim width | Kangxi | 2008 - 2012 Ninja 250R Tech Talk | 8 | December 17th, 2012 03:23 PM |
Is a wider rear wheel possible? | dburgess1231 | 1986 - 2007 Ninja 250R Tech Talk | 11 | March 27th, 2012 10:43 AM |
EX250J ('08+) Front rim; also selling rear rim in an older thread | CZroe | Motorcycle-related | 11 | September 11th, 2011 08:32 PM |
Rear tyre Rim bent | vkuchhal | 2008 - 2012 Ninja 250R Tech Talk | 14 | March 12th, 2011 03:01 PM |
