Old March 23rd, 2012, 09:54 AM   #1
dburgess1231
dburgess1231's Avatar
Motorcycle(s): 2003 Ninja EX250 blue
Is a wider rear wheel possible?
I have an '03. Does anyone know if we can get a 140 or 150 rear wheel tire on the back without making any changes? I know my buddies went up to a 150 on his '08 without making changes to the bike. Is there any advantages/disadvantages to a wider rear tire besides looking BA?
dburgess1231 is offline   Reply With Quote
Old March 23rd, 2012, 10:22 AM   #2
I am swapping rear swingarm, shock, wheels, ect... from a 08+ to my 92 to get better shock and tire options. Maybe that is more work than your willing to do.
The main reason to run the "slightly" wider tire is because stickier tires are normally made in wider sizes that do not fit the pregens. For me, BA comes second to function.
Old March 23rd, 2012, 01:41 PM   #3
Get Pirelli Sport Demons, or Bridgestone BT45's in a 130/90-16 rear size. They're both very wide for a 130. The BT45 "actual" width is like 138mm. It looks wider on my bike.
but honestly, even though my rear is basically 140mm wide, I pull up next to a 600, and it still looks like bicycle tires. Whatever. Not worth the money and effort in my mind. Just get something sticky in a size that fits the rim correctly, and be done with it.
Old March 23rd, 2012, 01:48 PM   #4
I remember a post on here where a guy was at the track and changed his rear tire. He left it up against a fence and another rider picks it up and says "who's front tire is this". hahahahah
It is what it is.....
Old March 23rd, 2012, 02:47 PM   #5
theres no point getting a wider wheel or tire when you have 16" rims. it will do only harm. like the smart chris said, the only point is for sticky rubber. but when they dont make sticky rubber in 16", theres no point.
the higher rotating mass will slow the bike down. the tires are going to be more expensive. youll also change the handling characteristics so if you dont know what you are doing it can be dangerous.
Old March 23rd, 2012, 10:06 PM   #6
duckracer
duckracer's Avatar
Motorcycle(s): Ducati 1098 and 04 Ninja 250 race bikes
The 17 inch wheel conversion is totaly worth it! With 17 inch wheels you can run better tires with a much better (round) profile and they have a better aspect ratio (more contact when leaned over). The rotaional mass is not that much more, because the tires tend to be lighter than the bias ply that are made for most 16 inch wheels, and the new gen wheels are a bit lighter. Now a 150 is over kill and will cause the bike to be a bit slower to change direction side to side. A 140 works great and fits with just a minor milling of the right caliper mount. I have done the 17 inch conversion on mine so I know it works.
duckracer is offline   Reply With Quote
Old March 24th, 2012, 07:12 AM   #7
dburgess1231
Aproximately how much does the 17" conversion cost?
Old March 24th, 2012, 08:23 AM   #8
http://www.ninjette.org/forums/showthread.php?t=91825
Old March 27th, 2012, 06:21 AM   #9
gunturwibowo
Motorcycle(s): ninja 250
BT 92 with 160/60 is still possible, but michelin pilot series 180/55 also can
gunturwibowo is offline   Reply With Quote
Old March 27th, 2012, 06:43 AM   #10
dburgess1231
This is for a newgen ninja. I was referring to a pregen.
Old March 27th, 2012, 10:38 AM   #11
gunturwibowo
oh my god, i misread the section, i'm sorry
Old March 27th, 2012, 10:43 AM   #12
If the conversion is made, then it's applicable. np here.
Rear shock set to high (rear wheel slipping)? passive101 2008 - 2012 Ninja 250R Tech Talk 6 August 10th, 2014 08:45 PM
08+ rear wheel, right rear set, rear brake system, seat cuong-nutz Items Wanted 2 October 6th, 2013 05:37 PM
Rear wheel spitting up onto the fender & rear seat. Solutions? uKER 2013 - 2017 Ninja 300 Farkles 21 July 29th, 2013 01:00 PM
Wider rear rim RACE LEGAL? krolinked Ninjettes At Speed 9 December 8th, 2012 09:12 AM
