August 1st, 2011, 11:06 AM | #1 |
Needed a Cape!!!!
Ok,
My ninja and I are chasing 600's again.... And I come up on this from the guys at the front of my group. He was going around the downhill corner that was shaded by trees. Road was still wet from the shade and he lowsided. Slid down the road and FLEW air born off the embankment. It was about a 20-25ft drop to the bottom through the trees. This looks terrible, After the crash checkout, he comes up from the crash site with only a scurf on the side of his knee. No rash, not even a hole in his leathers. Sooooo lucky. ATGATT FTW!!!! What can you learn from this? 1. when riding solo, don't take chances, save some traction for when you need it. It would have sucked to lay there for hours before someone found you 2. before you ride, have plan b, to get you and your bike back home in case you can't ride it 3. tell someone your out, so if you don't come back on time, they can go look for you, tell them to be on the lookout for scrapes on the road, in case your over an embankment and can't be seen from the road 4. put contact info where it can be seen by someone who finds you, just in case you can't speak for yourself Be safe out there.
August 1st, 2011, 11:14 AM | #2 |
MOTM - Mar '13, Jun '14
What happened to the bike?
August 1st, 2011, 11:30 AM | #3 |
Frame is straight, it runs and tires still had air in them. Everything else is gunna need checked out. Tail was ripped pretty bad and tank is trashed. Some cracks in the plastics, but they held up really well (another miracle). Mirrors, screen, leaking gas and other things you would expect.
He had on race sliders, we believe those saved the engine from any damage, even his can only had a few scratches. We are still in disbelief about most of the outcome.
August 1st, 2011, 11:38 AM | #4 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
ouch.
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
August 1st, 2011, 11:45 AM | #5 |
The rider was very lucky.
August 1st, 2011, 12:05 PM | #6 |
That guy should not go to Lost Wages, as he's done spent all his luck fo' shoore.
August 1st, 2011, 12:07 PM | #7 |
Join Date: Mar 2011 Motorcycle(s): 2007 ninja 250r Posts: 374
Dont look right to me he must have been speeding even wet roads you can still make the corner at 35
August 1st, 2011, 01:12 PM | #8 |
Looks like he was down before the turn, front end tuck, straight line into the woods.
August 1st, 2011, 01:15 PM | #9 |
There's a limit to s2pdty
Join Date: Apr 2011 Motorcycle(s): 250r ninja (sold) Posts: A lot.
Ouch. glad he's okay
August 1st, 2011, 01:18 PM | #10 |
from what i saw and was told, the rear went just shy of apex, dunno for sure know their speed when it happened, but i would bet it was near 55mph (posted speed limit).
August 1st, 2011, 02:13 PM | #11 |
Join Date: Nov 2009 Motorcycle(s): 300, WeeStrom Posts: A lot.
them kentucky boys are tuff
New Owner from Cape Town, South Africa | paper | New Members | 12 | December 10th, 2014 07:46 PM |
Hi from Cape Town | raphaeltube | New Members | 10 | August 25th, 2013 05:56 AM |
Chesapeake Cycles Cape May Ferry Ride - May 20th | Boomstick1491 | Ride Reports | 3 | May 18th, 2012 02:58 PM |
[superbikeplanet.com] - Tugging On Superman's Cape | Ninjette Newsbot | Motorcycling News | 0 | February 13th, 2012 10:40 AM |
[onewheeldrive.net] - To the Cape and Back | Ninjette Newsbot | Motorcycling News | 0 | December 24th, 2008 08:02 PM |
