May 29th, 2015, 10:31 AM | #1 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
Fork pinch bolts missing
I noticed my front end seemed tweaked, and the left handle bar is bent. Upon further inspection I found that the lower triple pinch bolt on the left is backed out and the top on is missing. The right side is good.
Aside from straightening the allignment, should I pull the forks and see if they're straight? I rode the bike 600 miles home yesterday in its current state. |
May 29th, 2015, 11:06 AM | #2 |
Wtf is going on with pinch bolts this season?!?!?! I worked tech a few weeks ago found multiple riders with loose or missing pinch bolts.
I will pull them if your suspect it's bent.
May 29th, 2015, 12:28 PM | #3 |
Motorcycle Nurse?
Chris, I have the forks off. I was thinking I could lay the chrome piece down on a table and spin it inside the fork legs to see if it is bent. Will spinning it mess up the innards of it?
The chrome doesn't appear distorted or bent anywhere, I just want to make sure it isn't bent |
May 29th, 2015, 12:33 PM | #4 |
Will not hurt a thing. Spin dem innards. lol
May 29th, 2015, 12:52 PM | #5 |
Motorcycle Nurse?
the right fork has the littlest bit of light that shines through on one side while the left doesn't let any light through
Guess this means I need a right fork EDIT: JESUS WHY IS A FORK $550 Last futzed with by Floki; May 29th, 2015 at 03:45 PM. |
[visordown.com] - Ducati pinch Aprilia's WSB boss | Ninjette Newsbot | Motorcycling News | 0 | October 10th, 2013 08:30 AM |
missing upper fork bush | broughd | 2008 - 2012 Ninja 250R Tech Talk | 0 | January 10th, 2010 01:09 AM |
missing fork clamp bolt | boyonfire | 1986 - 2007 Ninja 250R Tech Talk | 11 | June 2nd, 2009 04:24 AM |
[topix.net] - Harley-Davidson feels economy's pinch | Ninjette Newsbot | Motorcycling News | 0 | November 13th, 2008 07:54 PM |
[visordown.com] - Bike schools feel pinch over test centre mayhem | Ninjette Newsbot | Motorcycling News | 0 | August 15th, 2008 09:29 AM |
