February 21st, 2010, 02:15 PM | #1 |
Ride it like you stole it
Join Date: Jan 2010 Motorcycle(s): '09 Ninja 250R, '04 R6(sold) Posts: 362
Missing oil filter washer
I changed the oil on my brother's bike today and noticed he was missing the washer that goes between the spring and filter. The Kawasaki dealership changed the oil last so I'm pointing the finger at them for not putting it back on. The first time i changed my oil I almost did the same thing. It kinda sticks to the old filter. No real harm as I can see, but its is there for a reason. Just thought I would mention it since I have seen it happen twice now.
February 21st, 2010, 02:39 PM | #2 |
Yet an other perfect example of why I wouldn't bring my bike to a garage for something I couldn't do myself. Changing the oil is probably one of the easiest and most common tasks mechanics are confronted with, everyday. The way I see this is if they can't perform such a task correctly then, should you trust them with something that could pose a risk to your safety? What if they had forgot that crush washer between the banjo bolt of your brake lines?
Thank God that this wasn't anything major. At least doing it yourself, you know that if anything were ever to go wrong, you would be the only one responsible. |
February 21st, 2010, 07:23 PM | #3 |
MOTM - Mar '13, Jun '14
Thats a nasty picture. Why didn't they just get a trailer instead of trying the put the bike in the back seat?
missing the washer between my oil filter and the spring | corralhollowkid | 1986 - 2007 Ninja 250R Tech Talk | 14 | July 22nd, 2017 02:36 PM |
WTS: 250R OEM oil change items (filter, orings, washer) | Teh_K | Motorcycle-related | 4 | March 24th, 2014 05:14 PM |
Changed oil filter & missing washer | areifel | 2013 - 2017 Ninja 300 Tech Talk | 1 | September 10th, 2013 09:47 AM |
Oil filter washer replacement? | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 18 | June 19th, 2013 10:53 AM |
Oil Filter Crush Washer | Slono | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 24th, 2012 07:14 AM |
