Old July 8th, 2013, 09:56 AM   #1
corralhollowkid
Motorcycle(s): 07' Ninja 250r
missing the washer between my oil filter and the spring
I just got the ninjette... I'm changing the oil then later looking at the parts diagram and thinking to myself "I laid out all the parts and there was NO washer between my spring and the filter cartridge"
It doesn't look like its critical for the flow of oil and I know the oil is circulating. How bad is it to run the bike without that until my next oil/filter exchange?
I'm thinkin it won't hurt a damn thing... I just wanna feel better in my head while I'm riding it !
Thanks !!!
Posted via Mobile Device
corralhollowkid is offline   Reply With Quote
Old July 8th, 2013, 10:08 AM   #2
kawaninja09
kawaninja09's Avatar
Motorcycle(s): 09 250r ninja
is it the o ring washer?
kawaninja09 is offline   Reply With Quote
Old July 8th, 2013, 10:13 AM   #3
corralhollowkid
no, its not the rubber O ring...that's all nicely sealed up
its a flat metal washer that (according to the kawk parts diagram is part number 92022-1012) measures 20.5x30x1
it sits on top of the spring and below the cartridge filter... I don't think it does much.
its damn impossible to find one even at my failsafe they have everything ever made hardware store. the sizes jump from 20 to 22...
Old July 8th, 2013, 10:18 AM   #4
kawaninja09
i just recently did an oil change on mine last week but i remember having the washer but ive also heard alot that it gets stuck to the bottom of your old filter you took off so if you still have the filter check on the bottom of it for it if not im sure you could get the part from kawasaki dealership
Old July 8th, 2013, 10:31 AM   #5
corralhollowkid
Its not on the old filter ... The dealer wants $5 for the part. I will end up getting it from them, eventually.
For now ... I don't think it hurts anything to leave it out for a few miles?
Old July 8th, 2013, 10:35 AM   #6
kawaninja09
i think it just helps keep the filter in place but good luck on it
Old July 8th, 2013, 10:53 AM   #7
corralhollowkid
yeah...i don't see how the filter can really go anywhere.
I'm gonna order one from the dealer and do another oil/filter exchange soon anyhow. I used Mobil 1 full synthetic and a wix filter. The oil clouded up right away. I'll try a different oil this time. Maybe I'll pop the extra bucks for the royal purple !
Old July 8th, 2013, 11:04 AM   #8
cuong-nutz
cuong-nutz's Avatar
You will be fine without it for now. The washer is there so the spring can push up against it instead of the rubber seal on the oil filter. This prevents the seal from deforming as the spring isn't flat and wide.
HalfFast Racing Team
Old July 8th, 2013, 11:10 AM   #9
corralhollowkid
Thanks ! I'm off to work on it in 5 min... With a little more peace of mind !
Old July 29th, 2013, 08:15 AM   #10
Leaky
Motorcycle(s): 09 250R
Mine was the same, bought the bike used, didn't seem to be a washer there. How long would it be okay not running it for? Till the end of the season or should I do an oil change and replace that part again (just did the change last night).
Leaky is offline   Reply With Quote
Old July 29th, 2013, 10:24 AM   #11
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
I have done 3 oil changes without the washer cause i kept forgetting to get one. My mechanic told me it won't damage anything it purpose is just to keep the spring from digging into the rubber on the oil filter. I finally got one from my kawi dealership and he told me i didn't need ever to replace it so $4 didn't seem so bad. Hopefully i'll remember it next time i do my oil change.
I'm not small, I'm fun sized
BlueRaven is offline   Reply With Quote
Old July 29th, 2013, 10:46 AM   #12
Leaky
Ah Okay. I ordered 2 of those and 2 of the washers for the drain plug. Both were out of stock. I'm just a little paranoid about these things since it's the first time I've done any real "mechanical" work on anything.
Old July 29th, 2013, 11:04 AM   #13
BlueRaven
BlueRaven's Avatar
Better to be safe than sorry. Gotten myself in trouble a few times because i didn't ask in my line of work.
Old July 29th, 2013, 11:17 AM   #14
Leaky
Yep. I started teh engine after the oil change a couple times (also to make sure the oil levels were good). Nothing out of the ordinary, but the washer was never there anyways.
Just ordered the parts, just wanted to make sure everything was okay to ride or it would cause permanent damage down the road.
Old July 22nd, 2017, 02:36 PM   #15
KikRox
KikRox's Avatar
Motorcycle(s): 2011 Ninja 250r se
I dont have one either, doesnt make any difference what-so-ever 23000 miles no problems.. it just gives the spring something to rest on rather than the rubber gasket on the filter itself. just a backup plan so it wont accidentally rip the gasket on the filter, but you're like me and for $4 you buy a new filter every single time you change your oil at the 2000km mark right? RIGHT?? heh. (yeah 2000 km is far enough the way i ride this thing) oh wow this an old post. should have looked first!
They should give me my own section called kik rox is a silly **** who breaks stuff.
KikRox is offline   Reply With Quote
Changed oil filter & missing washer areifel 2013 - 2017 Ninja 300 Tech Talk 1 September 10th, 2013 09:47 AM
Oil filter washer replacement? cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 18 June 19th, 2013 10:53 AM
Missing Filter Spring!!! AmplexorJ 1986 - 2007 Ninja 250R Tech Talk 4 February 11th, 2012 10:52 PM
Oil Filter Crush Washer Slono 2008 - 2012 Ninja 250R Tech Talk 4 January 24th, 2012 07:14 AM
Missing oil filter washer JokerSeven 2008 - 2012 Ninja 250R Tech Talk 2 February 21st, 2010 07:23 PM
