Old January 22nd, 2013, 05:18 AM   #1
akcalhoun
Motorcycle(s): 2013 honda shadow phantom
engine mount
would the 300 front rubber engine mounts fit on a 250? would be nice to cut down a lil on the buzzing
akcalhoun is offline   Reply With Quote
Old January 22nd, 2013, 07:13 AM   #2
lgk
i doubt it, the frame and engine are different.
what part of the buzziness bothers you?
Old January 22nd, 2013, 07:21 AM   #3
tubarney
from what I've heard the rubber mounts do nothing.
Old January 22nd, 2013, 07:23 AM   #4
tubarney
http://www.youtube.com/watch?v=-k2IXNHov98
Watch this. skip to 5 min.
Old January 22nd, 2013, 07:25 AM   #5
Something loose? I don't hear a buzz from the bike itself, just the buzzy sounding exhaust. It's common for the levers to buzz, does it come and go at specific rpms?
Old January 22nd, 2013, 09:23 AM   #6
akcalhoun
its mostly the footpegs they can get kinda buzzy at highway speeds the handle bars a lil too
Old January 22nd, 2013, 09:53 AM   #7
DaBlue1
DaBlue1's Avatar
Still running stock gears on the hwy?
Old January 22nd, 2013, 10:02 AM   #8
So it safe to say it's the buzzy feeling vs audible sound?
Some things to think about.
Comfort grips and aftermarket clipons that bolt to fork tubes instead of top tripple.
Heavier bar ends
Rubber coated rearsets (you have aftermarket?)
Gearing
Preloads on suspension (what position do you have the rear set to?)
You have a tight grip on the bars? I would agree that the bars get buzzy at around 80, it reminds me to be loose
44lbs of air in your tires? Try a few lbs less. Sounds funny but I am not joking here.
Super hard touring tires?
Old January 23rd, 2013, 03:29 AM   #9
akcalhoun
grip on handle bars is loose, im constantly berating my riding. but i am running stock gearing and every thing else is stock (foot pegs ect.). have been srsly thinking of goin up one gear on the front and if it helps the buzzing at highway speeds i think i may finally do it soon.
Old January 23rd, 2013, 07:36 AM   #10
DaBlue1
DaBlue1's Avatar
.... but i am running stock gearing and every thing else is stock (foot pegs ect.). have been srsly thinking of goin up one gear on the front and if it helps the buzzing at highway speeds i think i may finally do it soon.
One of the best mods you can do. The Ninja becomes a new beast with a 15 tooth front sprocket. It should reduce your rpm speed by 500-700 in any gear, add approx 6 mph to your top end speed and reduced a bit of the hwy buzz at higher rpms. Switching to a synthetic also helps smooth out the engine.
Old January 23rd, 2013, 10:05 AM   #11
Yea, try the 15t front sprock. I think that should be the stock gearing. $20 and 20 mins worth of work and easily reversible. You don't even have to bust the chain.
Old January 23rd, 2013, 10:44 AM   #12
lgk
the 15 tooth sprocket should help.
get a cramp buster and some foam grips.
wear thicker socks
tuck a little once you get up to speed.
Old January 28th, 2013, 05:50 AM   #13
akcalhoun
just put on a 15 tooth sprocket, and it rly helps and i love it. i mostly drive hwy to commute and yes its a great mod shouldve done it earlier.
Old January 28th, 2013, 02:35 PM   #14
LNasty
Daily Jap rider
LNasty's Avatar
Question
I heard that switching to the 15t can damage the bike in some way is this true? Also how hard is it to change out? I commute everyday mostly hwy and my rpm's at 70 are at 10000.
Old January 28th, 2013, 05:05 PM   #15
DaBlue1
DaBlue1's Avatar
Originally Posted by LNasty View Post
....I heard that switching to the 15t can damage the bike in some way is this true?
Not true, however a 16 tooth sprocket (which some have done) will make the chain rub on the sprocket cover.
....Also how hard is it to change out? I commute everyday mostly hwy and my rpm's at 70 are at 10000.
The install is not hard at all. There's a DIY somewhere.
You should be doing closer to 80 mph @ 10k rpm (in 6th gear) with stock gears.
Installing a 15 tooth sprocket, you'll be doing closer to 70 mph @ 8k rpm (in 6th gear)
Old January 28th, 2013, 10:39 PM   #16
LNasty
Daily Jap rider
LNasty's Avatar
Question
Why is my rpm so high then with the stock sprocket? My idle is set at about 1300. What can I do to fix the high rpm in 6 gear other than switching sprockets?
Last futzed with by LNasty; January 28th, 2013 at 11:20 PM. Reason: added
Old January 29th, 2013, 06:16 AM   #17
lgk
if all our transmission gear ratios are the same, it should equal any stock bike with 14/45 sprockets.
you can 15/44 for an 9% reduction in rpm.
Old January 29th, 2013, 07:43 AM   #18
LNasty
Daily Jap rider
LNasty's Avatar
That still doesn't answer my question of why my don't are so high
Old January 29th, 2013, 07:47 AM   #19
lgk
what is your rpm at 65mph?
how many miles are on the bike?
Old January 29th, 2013, 08:17 AM   #20
LNasty
Daily Jap rider
LNasty's Avatar
2000 miles
At 65 I am at 9500 rpm
Old January 29th, 2013, 08:20 AM   #21
lgk
thats kind of what i get in 5th gear.
in 6th gear im at around 8k
Old January 29th, 2013, 08:30 AM   #22
2 things come to mind for this:
  • You have shorter gearing (13/45 or 14/47) because that is about the same rpm's I was turning when I was running 14/47 gearing
  • You have the newgen-rpm-readout-issue that is just part of the newgen CDI on some bikes.
Old January 29th, 2013, 09:08 AM   #23
LNasty
Daily Jap rider
LNasty's Avatar
Ok, I will count the teeth on sprockets
Bent Engine mount bolt oompa General Motorcycling Discussion 2 April 15th, 2015 08:27 PM
Lost Front Engine Mount Bolt - Pics of damage inside hawker1693 1986 - 2007 Ninja 250R Tech Talk 56 August 26th, 2013 04:08 PM
Engine mount nut size? FlamingYellowInsanity 1986 - 2007 Ninja 250R Tech Talk 3 February 16th, 2010 02:21 AM
