Old August 29th, 2017, 02:06 PM   #1
corksil
Motorcycle(s): A lot.
Ebay clipons?
Surely this has been discussed before but perhaps this thread can be a summation of everything already shared and agreed upon.
Disclaimer -- Any part that you install on your bike will ultimately be your own liability. By using cheap or low quality parts, you greatly increase your risk for mechanical error which could result in grievous bodily harm or death. It is not advised to work on a motorcycle unless you are confident in your ability and have the proper tools and knowledge to adequately complete the task.
With that said -- has anyone "gotten away with" ebay clipons?
In a never-ending search to make this bike handle better, I decided that I'd like to play around with raising the forks in the triple clamp. I've also got preload adjusters in there, and want to experiment with more fork tuning. All of that is a chore with the original handlebar setup because it covers the top of the forks. With clipons, I'd end up having a little more weight on the front wheel due to seating position, and I could access my preload adjusters, and I could also raise the forks a bit.
Woodcraft units go for 150 or so. These ebay knockoffs are on fifth of that.
I believe the ninja 250 had 36mm fork diameter.. the ebay ones listed say that they fit, yet are 37mm.
Hopefully someone can chime in. Thanks guys!
I'm referring to the these..
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy.
Old August 29th, 2017, 02:08 PM   #2
corksil
As usual.. it would be nice if someone could come in here and say quite simply "X are the ones I have, X are the ones to buy, and X have been working well for me for a long time."
I can lose entire days online researching all the subtle nuances pertaining to stuff like this. Risers vs spacers, angles, fuel tank clearance.. removing bar ends for increased clearance.. all of it sucks up so much time to research.
Old August 29th, 2017, 03:03 PM   #3
MrAtom
MOTM - July '15
You've been on this forum long enough to know that people are going to come in and suggest the premium line, or the "middle of the road" line whenever anyone asks about buying something made cheaper.
If someone's taken a chance on them and posted here, I hope they comment on it here for your sake. But until the unlikely event that a reputable person posts that, you're going to get responses like the above.
Best of luck!
Old August 29th, 2017, 03:57 PM   #4
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Lesson learned from a lifetime of misguided attempts to save a few bucks:
Buy quality. Buy once. Keep forever.
It's cheaper in the long run....
Old August 29th, 2017, 04:04 PM   #5
Woodcraft and forget it. $15 bar replacements as needed, with 2day shipping. It's really a no brainer until another company comes up with an end to end solution any cheaper.
Hell, if you are willing to pay the shipping... you can get them overnighted to the track. As well as there are at least 10 others who have an extra bar floating about.
The china levers are ok, if you're OCD about installing them properly. But as far as clip ons go, unless the replacement bars are the same/compatible with the woodcraft's, imma pass on them.
Old August 29th, 2017, 05:02 PM   #6
Kestrel
Kestrel's Avatar
Motorcycle(s): DR350, Ninja 250
Are you looking for a 36mm set for a pre-gen? Or a 37mm set for a later bike?
If it's for the older bike.... I've actually got a gently used set of 36mm Woodcraft riser clip ons that I plan to sell on the forums here for quite a bit under retail.
Kestrel is offline   Reply With Quote
Old August 29th, 2017, 05:13 PM   #7
hell, I just get 7/8" bar-stock to replace bent bars... Cut this in 1/2 to get two bars for $5 each!!!
http://www.ebay.com/itm/201600220367
But yea, I have Woodcraft clip-ons...
Old August 29th, 2017, 05:45 PM   #8
nice!!!!!
Old August 29th, 2017, 10:41 PM   #9
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
Only chinese anything ive ever bought have been shorty levers and theyve been flawless and ive had em years now. As for teh clipons, i rock Woodcraft. 0 problems with them, i think theyre fantastic.
Aggrotech is offline   Reply With Quote
Old August 30th, 2017, 06:42 PM   #10
corksil
Thank you all. It sounds like ebay for the levers and woodcraft for the clipons.
It would be super cool if patrick/kestrel's 36mm clipons would fit my newer '11 ninja.
Older than 08 = 36mm
08 or newer = 37mm
I don't suppose I could put 36mm clipons on my 37mm bars... Has anyone tried that? I'd love to buy used ones so I could save the couple bucks that I started this whole thread about.
Thank you all. I love this forum.
Old August 31st, 2017, 12:40 AM   #11
Nope, 36mm clip-ons won't fit on 37mm forks.
If my bike didn't come with Woodcraft, I would've gone with Chinese ones from eBay or Ali; they work just fine. Trick is to not overtighten everything. Have each clamp bolt just tight enough so it doesn't move under normal operation. But in wreck, bars will swing & rotate out of the way rather than breaking and/or damaging the forks.
Old August 31st, 2017, 05:37 PM   #12
jrshooter
Motorcycle(s): ninja 300
if i was at the track and my day would be finnished otherwise, damn straight i would dremmel out the 36 no matter how ugly it came out.
Raising clipons. beached 2008 - 2012 Ninja 250R Tech Talk 3 March 19th, 2013 11:45 AM
Does anyone have any reviews on theses eBay clipons. NinjaBoyEddy 2008 - 2012 Ninja 250R Tech Talk 10 July 17th, 2012 06:32 PM
ebay clipons, whaddya think? poo poo 2008 - 2012 Ninja 250R Tech Talk 9 September 15th, 2011 08:14 AM
shinto clipons illrational 2008 - 2012 Ninja 250R Farkles 49 October 6th, 2010 09:40 PM
for the ones with clipons???? mike_sema 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2009 07:35 PM
