March 22nd, 2015, 08:00 PM | #1 |
Join Date: Apr 2014 Motorcycle(s): '08 Ninja 250 Posts: 132
Repair and sell, sell as is, or trade in?
I'm wanting to upgrade to a 636 and sell my 250. I love the 250 and I'm not bored of it, but I feel that a bigger bike will be better for the long run, especially since I'm doing more highway riding.
My 250 has 21k miles, has been low sided twice and I've rear ended someone. I wanted to keep the 250 and turn it into a streetfighter, but money is sorta an issue and having a bit more money would help with getting a new bike. I want about 2k for the 250, if I can even get that since it's been crashed. So here are the issues with the bike: -The fairings don't line up at all. I've replaced the metal fairing stay twice since the original was bent, the replacement was also bent and it's even possible that the third that's currently on the bike is bent as well, but it's fit the best out of the three. It has a Chinese front fairing and the left fairing is also Chinese. It's droops a lot and seems not to fit well when the front fairing is off. So I'm not sure if the issue is with the left side fairing itself...or with the bike. The right one also doesn't line up, but may be because of the front nose fairing being Chinese. -The left handlebar is slightly bent. -Radiator is bent a little and needs to be replaced and possibly the fan. -The back fairings are also damaged. -Dent in the exhaust. I haven't noticed any frame damage when I've went over the bike and it seems to handle like it's suppose to. The engine runs good as well. So what would be the best option? -Replace the parts and sell? -Sell as is? -Repair and trade in? -Trade in as is? Or the last option is that I know someone who works with fiberglass and he can build fairings from scratch so it may be possible to redesign the bike completely. Thoughts? Hopefully that all makes sense |
March 22nd, 2015, 08:04 PM | #2 |
im trying to understand your logic behind this. could you explain why a 636 would be a better highway or touring or commuting bike? i have ridden a 636 and i would MUCH rather be on a 250 on the highway
March 22nd, 2015, 08:21 PM | #3 |
It's what appeals to me the most so far. Doesn't have to be 636. But I go through a mountain pass a lot and the incline really kills my speed and having some extra power would be nice. It make more sense to buy a 600 than another 250, or put in a ton of money in the 250 and keep it long term. I've already spent a fair bit of money on it.
March 22nd, 2015, 08:38 PM | #4 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
I never use my zx 6r's full power too overtake. I'm sure 24 hp is enough.
Wind is also an issue with a 6r. I've had a gust of wind shift me across an entire lane. But if you're set on it, for max cash, part out. For the quickest route, sell as is/repair and sell. I'm not sure a dealer would take your bike, and I'd they did, they wouldn't give you much.
March 22nd, 2015, 08:50 PM | #5 |
i've never had any trouble going up any hills at full romping speed on the 250... maybe you need a tune up.
March 22nd, 2015, 09:13 PM | #6 |
MOTM - July '15
Yeah, my 250 is fine on the highway, even while naked. It pisses off the engine a little, but different sprockets and tucking in fixes that.
March 22nd, 2015, 10:43 PM | #7 |
in my opinion the only legitimate reason for wanting to ride a supersport on the road is simply "because i feel like it" any other reason is bullshit. a supersport is not a good street bike, plain and simple. it doesn't get good mileage, it isn't comfortable, it's got way more power than you would ever actually want to use as a sane person on the street. in the wet, it's probably twice as hard to manage as a more reasonable street bike. when you start getting the bike out of shape if you don't know what you're doing it becomes easier and easier to accidentally get in way too deep. maintenance is twice as expensive as a normal street bike, damage actually breaks **** instead of just scratching stuff up.
people forget what these types of bikes are actually for. they are for a track. they are for going balls out at 140mph right before you flog the brakes in 100 feet and trail it down to 65 into a full tilt corner before wheelying out of it. designing a bike to do this means it is DEFINITELY NOT DESIGNED TO BE A GOOD BIKE ON A STREET. don't delude yourself. don't lie to yourself. be honest about what you want and the bike will treat you MUCH better. if you want to go 145 down the highway and get arrested for it, by all means. go for the 636 for your highway cruiser or whatever. but don't be surprised when it actually turns out to be a ****** street bike. if you want a good street bike but more power, why not look at something reasonable, like an sv650. or something that isn't a race replica. race replicas are uncomfortable as **** don't get me wrong. i've driven the **** out of a 636. i've topped out my yamaha like an idiot on the freeway through traffic. i've even tried fancy ducatis and triumphs. they're all **** terrible street bikes. BECAUSE THEY WERE NOT DESIGNED FOR STREET USE. actually the ducatis were ****ing sweet. go buy a ducati.
March 22nd, 2015, 11:40 PM | #9 | |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Hey Unregistered never go faster than your brakes can be applied... |
March 23rd, 2015, 12:08 AM | #11 |
Nope. Its more stable as it has a wider tire. You find big cracks and lines in the road moves the bike around less. I can find more tire options for a 600 then a 250 And more places have them. I have been in strong head winds with the 250 and even running at a high rpm its hard to stay at the speed limit. most of the high ways I ride on have a speed limit of 75. And most are doing 85 on the 250 the high rpm creates a lot of annoying vibration even with non stock gearing. heck some of TX roads are now 85mph it suck to try and do 90 every day on the 250.
March 23rd, 2015, 12:29 AM | #12 |
The A Team
Join Date: Aug 2012 Motorcycle(s): Z50, CB125, RZ500, MC22, R3. Posts: 394
My 2011 did 163.87 with +4 rear sprocket at a track with short straight, that's real GPS datalogger speed, 175 on speedo,
on an open straight it went well over 180 on the clock with 43t and 45T. That's with stock headers ans airbox in place, tuned and jetted in race trim. Speed limits must be fast in the USA. |
March 23rd, 2015, 12:39 AM | #13 |
Join Date: Nov 2012 Motorcycle(s): '07 ex250-F/J Posts: A lot.
This is the answer to all your questions.
ya shoulda left out the first bit lol. That's it. Thread closed! |
March 23rd, 2015, 12:41 AM | #14 | |
March 23rd, 2015, 12:45 AM | #16 | |
what it sounds like is that you have ridden a really really ****ed up 250 with godawful tires and ****ed up suspension.
March 23rd, 2015, 12:50 AM | #17 |
The A Team
March 23rd, 2015, 12:52 AM | #18 | |
85 mph The law sets the maximum at 70 mph, but allows the Texas Transportation Commission to establish a maximum speed limit of 75 mph (80 mph or 85 mph if the highway is designed to accommodate that speed) on the highway system if that speed is determined to be safe and reasonable after a traffic or engineering study. And no setting on a 600 you can keep it balanced more easy because of a wider tire then a 250. if I am wrong post a video of you balancing a 250 on not new but also not really used tires with out it running and no feet on the grown and I bet I can do it longer on a r6 or 636.
March 23rd, 2015, 12:53 AM | #19 |
Mph?
March 23rd, 2015, 01:01 AM | #20 | |
March 23rd, 2015, 01:10 AM | #22 | |
March 23rd, 2015, 01:11 AM | #23 |
You said 95 is more then 20 over the speed limit in the country. I posted showing your talking out your ass about that.
March 23rd, 2015, 03:37 AM | #24 |
So I appreciate everyone advice. How much do you think I can get total if I go with parting it out?
March 23rd, 2015, 04:52 AM | #25 | |
The A Team
you'd be better off learning to ride the 250 and fixing whatever makes you so slow. |
March 23rd, 2015, 05:04 AM | #26 |
You never answered my question.
March 23rd, 2015, 06:30 AM | #27 |
Join Date: Jan 2015 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 121
Going back to the actual OP, with the amount of damage to the bike, you're probably better off parting it out or selling as-is.. It could be brought back to near-new condition, but it will cost about $800 or so to do it for a completely new fairing kit, radiator, exhaust, and handlebar.. Add to the costs the time it will take you to make those repairs, and that's where you have to really weight your options..
You could skimp a bit and get a complete set of fairings online somewhere like eBay or Craigslist if you're lucky.. You might find the other parts used locally as well, saving money.. Still, I find it hard to believe you'd spend less than $800 total for the parts alone.. This is also with the assumption that you haven't damaged the frame and there are no other issues.. Having rear-ended someone may have bent the forks slightly.. For an '08 with 21k miles and the repairs needed, you'll be very lucky to get $1700 for the bike as is.. I'd say $1400 would be a great deal for someone with the time and money to fix it up.. A newer bike with less than 5000 miles and no issues sells for $2500 around here (NJ).. Not sure what the market is like there in Vegas.. What's the condition of the tires?? Do you have service records?? Any mods or accessories with/on the bike?? Those will affect the pricing as well.. In the end, post it on your local Craigslist for what you'd like to get for it, and hope that someone comes around and gets close with an offer.. The worst that can happen is that you say no and part it out in the end.. |
March 23rd, 2015, 08:59 AM | #28 |
MOTM - Mar '13, Jun '14
Not true! But it does give you bigger balls!
March 23rd, 2015, 03:06 PM | #29 | |
The forks did get bent, but I've replace them. I wasn't planning on getting completely new fairings, probably used ones and repair and repaint them if I had to. I don't mind putting the time into it. The bike could probably use some new tires. I gave the service records and the only mods to the bike are the slip on and brake/clutch levers. Ninja 250's here are going for about $3,000 here. |
March 23rd, 2015, 04:35 PM | #31 |
Even a mint 2012 with under 5k miles would be a real stretch to sell at 3k. 2500 much more likely for mint 250. 2k for well used. 1.5k for beat up. Under 1k for trashed
March 23rd, 2015, 04:37 PM | #32 |
But honestly. You said yourself money is an issue. So why are you trying to buy a more expensive bike while also losing money on the bike you own.
March 23rd, 2015, 05:10 PM | #34 |
Inline 4!!!
The 250 is not comfortable on the highway. I'm sorry...it's just not.
Very buzzy, vibrates a **** ton, you gotta drop 2 gears and WOT just to pass people at a decent pace. Bike is practically red lining, screaming, more vibrating, wind hits you and you get buffeted around the lane... I only weighed 140 when I rode my 250 (now I weigh 160) and I tell you the wind PUSHED you around.. Sorry, but I agree with OP 100% that the 250 on the highway sucks. It can handle it, but it is not the best bike for the highway. Now the question, is the zx6r any better? I mean, of course it's better at the highway, but it's still not the best. Doesn't get good gas mileage and is an aggressive standing uncomfortable bike. Your best bet would probably be more of a sport touring bike. Edit: you probably could get $1,500 for your bike if you wait for the right buyer... the bike is trashed with a ton of miles. GLWS
March 23rd, 2015, 05:14 PM | #35 |
Inline 4!!!
95 (indicated) is pretty much the bikes top speed, and it is not that easy to get there... at least in my experience, who knows I may have been doing something wrong.
March 23rd, 2015, 05:15 PM | #36 |
my bike does 110 indicated at redline in 6th. it has no problem getting there.
March 23rd, 2015, 05:29 PM | #37 | ||||
Private Joker
MOTM - Mar '14
sport bikes (excluding sport touring bikes) aren't designed to be good at highway riding. If that's your aim get a cruiser or a sport touring bike, seriously that's what they're made for.
I see you over there seeing me, do you see the me I think you see? |
March 23rd, 2015, 05:29 PM | #38 |
Private Joker
MOTM - Mar '14
Have you considered shifting into 6th gear?
March 23rd, 2015, 05:31 PM | #39 |
Inline 4!!!
Your 250? Holy ****, my 300 has trouble getting up to 110 (takes like 5 minutes straight of WOT). What mods do you have???
0 out of 1 members found this post helpful. |
March 23rd, 2015, 05:33 PM | #40 |
Inline 4!!!
Lol yes, again, this was on my 250. My 300 is a completely different story... She'll pull in 6th gear up until about 95 mph, then it becomes a slow grind. I love my 300! Honestly the 300 is enough for the highway, I can pass people very easily and I don't get blown around nearly half as much as my 2 fiddy. I guess that extra 10lbs and tire make a difference somehow...
May sell my 99 | Kruse08 | Motorcycle-related | 9 | January 5th, 2015 11:37 AM |
sell or don't sell :( | Hero Danny | General Motorcycling Discussion | 43 | September 5th, 2014 06:18 PM |
Want to Trade or Sell.. (windscreen) | DR1300R | Items Wanted | 2 | March 1st, 2011 11:31 AM |
What should I sell it for? | Terrorizer | Motorcycle-related | 0 | August 16th, 2010 04:27 PM |
[superbikeplanet.com] - Soups's Free Classifieds, Born Free. Live Free. Sell or Trade | Ninjette Newsbot | Motorcycling News | 0 | July 14th, 2010 03:00 PM |
