July 17th, 2014, 09:11 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): 2008 ninja 250 Posts: 271
250 race question
Hey guys I am a track guy but not a competitive racer so my question is strictly from a curiosity stand point.
Do you guys that race go thru motors as in having to replace rebuild the motor or any of its components? And do you do the work yourselves? What do you go through most tires and brakes ? Just curious thanks Mike h |
July 17th, 2014, 09:23 PM | #2 |
None of the 250 races in my area seem to go through motors. Sure stuff breaks, but no more than any other track riders. Many seem to tinker with the carb alot depending on their exhaust. Gearing is a more frequent change as well but the stock gearing is pretty popular.
What do I go through the most? Gas and oil (changes). Tires more than brakes, but I will burn a set of EBC brakes in a 10 round season (20 races). A set of good tires last me a whole season. Yes, I do all the work myself aside of tire changes. I hate changing tires.
July 17th, 2014, 09:34 PM | #3 |
ok awsome
Thanks I admire the effort you guys put in at this level. I have to get to a 250 race one day. Looks like fun.
See all you nuts come out of the woodwork. |
July 17th, 2014, 09:37 PM | #4 |
Hold up... I have a correction to my post.
What do I go through the most? $$$$$
July 17th, 2014, 09:44 PM | #5 |
ha ha
Btw just read the bottom of your post about romancing the corner. That is my downfall.
What a great point maybe I should think of it as if I was being chased by a cop |
July 17th, 2014, 10:42 PM | #6 |
Private Joker
MOTM - Mar '14
judging from tire wear for a normal track day (first track day but a normal one nonetheless where I missed a few sessions) I'd say that you'd go through tires pretty quickly racing even on a 250 due to the accelerated wear riding that hard on the tires provides.
Really I don't see there being much more wear than a track day overall per race so as a track rider I should reasonably expect racing in the 250 class to cost similar to track days if not a little bit more
July 18th, 2014, 12:47 AM | #7 |
July 18th, 2014, 06:05 AM | #8 |
I use bt003
From Bridgestone I love them as a track day tire.
July 18th, 2014, 06:14 AM | #9 |
Fighting Texas Aggie '05
from what I have seen, if your only sprinting the bike a single race a weekend a set of tires will likely last 10 rounds. The SC1/Rosso combo seems to wear a little faster than the 003Pro/003RS combo
July 18th, 2014, 06:40 AM | #10 |
SC1/Rosso II combo is what I am running. I used to run the 003's they were fine too and wore pretty good, the only reason I switched is for more grip.
July 18th, 2014, 12:20 PM | #11 |
Join Date: May 2014 Motorcycle(s): Ninja 250R & CBR250R Posts: 105
Yeah, I dont think Ive heard of anyone in our race series losing an engine, yet. Of course, now that I say that, Ill probably be the first.
Gas, oil/filter, and tires are going to be your biggest consumables as long as you arent crashing a bunch. Replacing rearsets/frames makes the price go up pretty quickly. |
July 18th, 2014, 01:24 PM | #12 |
Join Date: Oct 2012 Motorcycle(s): '04 R1 and '08 Ninja 250 Posts: 222
Draik is in his second season of racing his '08 Ninja 250. We bought it used with ~9600 street only miles. The motor work has consisted of one Valve Adjustment, and one other post seasons check. Three jetting changes. A couple different size rear sprockets get changed out. He started out last season on a set of Vesrah brake pads and other than trying out a set of EBC's for two practice sessions, he is still on the original Vesrah set.
Tires and gas are what we spend the most on. He's on his third set of tires in two seasons and goes through about $50 of race gas/weekend.
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son |
July 18th, 2014, 04:19 PM | #13 | |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
July 18th, 2014, 04:51 PM | #14 |
i've blown a crank journal and two transmissions during races. and i know of several other racers who have also blown cranks and transmissions.
July 19th, 2014, 04:07 PM | #15 |
Join Date: Oct 2013 Motorcycle(s): gsxr 750, sv650, 250 ninja Posts: 110
9000 street miles, 12 - 25 min races, and probably 75-80 dyno runs, pulled the top end off to inspect pistons and rings everything looked like new, rings had 11 thou end gap, so i put it all back together, runs as strong as ever, these are really tough little motors
July 19th, 2014, 04:25 PM | #16 |
wow
That's outstanding The reason why I ask is I thought maybe you guys might go through a couple of them at least.
I have pulled the videos up from the races , aside from looking extremely fun , Everybody running hard. Just another plus for our bikes. |
July 19th, 2014, 05:29 PM | #17 |
alex
Did you replace the motor? It was probably cheaper then maybe going to fix it I don't know just curious ?
August 5th, 2014, 12:55 PM | #18 |
Join Date: Jan 2014 Motorcycle(s): 1996 Ducati 900SS/SP 45k miles Posts: 132
question . . .
there should be plenty of engines available with all the Ninja 250s out there.
'09 Ninja 250R track only SOLD "If everything seems under control, you're not going fast enough." -Mario Andretti |
August 20th, 2014, 12:05 PM | #19 |
Join Date: May 2013 Motorcycle(s): 08 Ninja 250 Race Posts: 30
Money that's what seems to go the quickest.
CRA#889E 2013 Ninja 250 Champion |
August 20th, 2014, 12:24 PM | #20 |
I thought this was supposed to be the poor man's race class, just kidding it's all the little things that add up I bet heck even track days ain't cheap but there's a lot worse ways to spend money
August 20th, 2014, 12:26 PM | #21 |
Private Joker
MOTM - Mar '14
it is the poor mans race class, the difference in cost for 250 class vs 600 class is insane
650 class (aka sv650s) is a fair way to split the difference though but you still burn through tires on one of those
August 20th, 2014, 12:55 PM | #22 |
Join Date: Jul 2014 Motorcycle(s): 2014 Ninja 300 track bike, 2007 Suzuki GSXR 750 track bike, 2002 Yamaha R6, 1995 CBR600RR f3 track bike Posts: 304
Do most of you run dedicated track only bikes or do you track your street bike? I'm planning on buying a nice '05 GSXR 600 from someone at work this fall but I really like riding my little green demon. I'll trailer the bike to and from the track no matter what.
Mike |
August 20th, 2014, 12:56 PM | #23 |
Private Joker
MOTM - Mar '14
I have a dedicated track 250 and a commuter/street 300
I'd ride the 300 on track if it weren't my day to day transportation but it is so I have the 250 it doesn't necessarily have to be a track only bike so long as you have another means of transportation and crashing your bike won't end your ability to get to school/work then you're really good to go. Tracking your street bike has an inherent advantage of you're already comfortable on that bike. I spent a large portion of my first track day getting comfortable on my track 250 (though I did crash so that made the discomfort worse)
August 20th, 2014, 01:01 PM | #24 |
All of my bikes pull double duty, street and track.
August 20th, 2014, 01:09 PM | #25 |
Neither the 250 nor the GSXR when I get it are/will be my primary means of transport. Just not practical here in NJ. I guess that I'll have to see how much I like the 600 as my get on and go bike. Scared the sh1t out of me for the first 5 minutes test riding it. It's a totally different feeling than the Ninjette at least to my inexperienced hands/butt/brain. I had the same feeling getting on the 250 for my first real ride. I don't think that I mentioned that the 250 is my first bike ever. My wife hates bikes and never wanted me to get one. To appease her I didn't. She's going to be an ex-wife shortly so I thought, WTH, I'm getting a bike! Fair trade? Lol
Mike
Track, track, track Last futzed with by Mike K; August 20th, 2014 at 01:16 PM. Reason: grammar |
August 20th, 2014, 01:22 PM | #26 |
Private Joker
MOTM - Mar '14
I'd track both of them then
August 20th, 2014, 01:31 PM | #27 |
I've been thinking about it. I thought that after I learned, gained some experience on the 250 I'd give the 600 a go.
Track, track, track |
September 13th, 2014, 10:27 AM | #28 |
Join Date: Sep 2014 Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4 Posts: 250
I started on an 05 R6 at the track at it was fun until I low sided and got scared. It has taken me about 5 track days to grow balls again and on a 250cc. When watching track or races I wonder if I should try my R6 again lol... She is for sale but no body is interested lol
September 14th, 2014, 03:49 AM | #29 | |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
The 250 is the cheapest way to have a good time on the track. |
September 14th, 2014, 04:09 AM | #30 | |
Yeah Alex... still looking at my next 250...but at least I got one to have fun with!! Hope track for me at PBIR next Sunday ... you have CCS soon !! |
September 14th, 2014, 05:57 AM | #31 | |
Hello Moto
Next season I plan to get to a lot more races...something about having a baby midway through the year put a damper on my 2014 racing. |
September 15th, 2014, 03:23 AM | #32 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
Don't think that anyone has mentioned track fees to enter each race weekend
September 15th, 2014, 06:59 AM | #33 |
Noted in post #4 Scott.
September 16th, 2014, 03:45 AM | #34 |
September 16th, 2014, 08:08 AM | #35 |
Join Date: May 2014 Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F Posts: 588
September 16th, 2014, 04:36 PM | #36 | |
For me, I do it every oil change...so for me, it's once a month. (I do race and a lot of trackdays). I am a very data driven person and log my clearances. So far there hasn't been any movement since I needed to reshim them back to spec.
Race-prepped 250 GSXR shock swap question | Braden07 | 2008 - 2012 Ninja 250R Tech Talk | 7 | November 15th, 2014 07:03 AM |
Ninja 250 Service Question | Apex123 | 2008 - 2012 Ninja 250R Tech Talk | 8 | November 2nd, 2014 06:33 AM |
Question about a loan: Ninja 250. | XurXes | General Motorcycling Discussion | 87 | August 28th, 2012 04:52 AM |
2007 Ninja 250 question | drdriftking007 | 1986 - 2007 Ninja 250R Tech Talk | 58 | April 20th, 2012 01:15 PM |
question and one observation about ninja 250 | bikermunda | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 9th, 2009 05:19 PM |
