Old April 3rd, 2016, 04:34 PM   #1
Goatsby
Motorcycle(s): 2006 EX250
GSXR-600 Rear Shock Swap Questions
So I bought the whole rear shock setup and dog bones from another user and I'm trying to get everything hooked up. It came with some spacers but they're too small indiameter I think, as they allow the little pivot sleeve to be pushed around. Would I be okay using washers as spacers for both ends of the dogbones?
Had to grind a hell of a lot of that bracket away to get the top end to fit. I then chewed through the spray plastic guard thingy with my teeth, hopefully it clears. EDIT: Sorry for the poor photos, I broke the glass on the camera on my phone and ever since I peeled the broken glass away the quality has been bad.
Genius!
Goatsby is offline   Reply With Quote
Old April 3rd, 2016, 05:55 PM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Here's how we did it, used '08 and '09 GSXR shocks. Have done it to 6 pregens with no problems.
https://www.ninjette.org/forums/showthread.php?t=214238
Old April 5th, 2016, 05:22 PM   #3
Goatsby
Got everything back together fianlly! The bike seems like it wants to fall in much easier in the rear compared to the front, if that makes sense. Front suspension in order now? Thanks for the help guys.
Genius!
Old April 5th, 2016, 05:40 PM   #4
Z1R rider
Z1R rider's Avatar
I'm guessing that you mean it's different than before the swap. Is the rear end at the same height as before the swap? If the back is higher than before, the turn in will be quicker. One of my 250's had the original Dunlops on it when I got it and the turn in at street speeds was scary quick, (felt like it was falling in) not at all confidence inspiring.
Old April 5th, 2016, 05:50 PM   #5
Goatsby
It's jsut different, probably also might have to do with the new diabo scooters I have compared to the 6 and 10 year old dunlops and the rear shinko. I forgot to take before and after measurements, but it feels about the same. I bought the shock with dogbones that were supposed to bring it back up to stock ride height though. When I had the bike up in the air I noticed the rear tire was a lot higher than the front with no load on either of them, but it doesn't seem to be sloped one way or the other when I'm on it.
Genius!
Old April 5th, 2016, 06:03 PM   #6
Z1R rider
Z1R rider's Avatar
New tires can make a HUGE difference in feel and handling.
Old April 6th, 2016, 01:19 PM   #7
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The fork springs are insanely soft on the PreGen. https://www.ninjette.org/forums/showthread.php?t=231171
At 175lb, you definitely want to upgrade them. If you can get your hands on some NewGen springs cheap, those are pretty close.
Check your free and static sag with the GSXR shock too. The one that seems to be the most common has a spring about 18% stiffer than stock. Depending on the exact suspension geometry, it might be a little too stiff for your weight (RT's NewGen calc and the general EX500 info state that it's too much on those bikes, but I'm not sure how different the PreGen is or how accurate RT's calc is). A stiff rear end with a squishy front end is going to have lots of rocking-horse effect going on.
new rear shock swap... perhaps i went a little too far? subxero 2008 - 2012 Ninja 250R Tech Talk 19 January 24th, 2017 12:00 PM
08 09 gsxr 600 750 rear shock suspension spring coilover ninja2007 Motorcycle-related 0 February 3rd, 2015 12:54 PM
Race-prepped 250 GSXR shock swap question Braden07 2008 - 2012 Ninja 250R Tech Talk 7 November 15th, 2014 07:03 AM
Suzuki GSXR 600/750 Shock Install Lemonfresh 2008 - 2012 Ninja 250R Tech Talk 10 August 21st, 2014 08:42 AM
GSXR shock swap questions subxero 2008 - 2012 Ninja 250R Tech Talk 75 March 13th, 2014 12:09 PM
