Old June 1st, 2017, 10:41 AM   #1
IcyMaxx
Motorcycle(s): '08 Ninja 250J
250J carb ???
My 08 is having some carb problems, I believe there is a peice of sand clogging up one of the jets. I'll be riding and it'll choke and sputter out like it's out of gas, so I drop 2 or 3 gears and pop the clutch and she will come back alive from sloshing of the gas. My question being, I'm trying to find a jet kit, but all I see is jet kits for the 250R, can I use this jet kit or are they different carbs? Any suggestions on where to get a kit?
IcyMaxx is offline   Reply With Quote
Old June 1st, 2017, 11:11 AM   #2
Ghostt
Ghostt's Avatar
I suggest you first six the original problem, before diving into a jet kit.
Sounds like a fuel delivery issue, could be vapor locking, bad petcock, clogged fuel filter, etc....
Get it running right first before you start messing with stuff.
Why do you think you need a jet kit? Any mods to the bike?
violente et ignorantia
ZX-2R BLOG
Old June 1st, 2017, 11:24 AM   #3
Have you looked inside the tank for rust?
A significant amount of condensation in the tank could also do what you described.
I agree with Ghostt. Don't do any carb/jetting mods right now, just solve the major problem before changing things.
Old June 1st, 2017, 01:44 PM   #4
Sounds like the small pilot circuits are clogged. These have very small passages that can stop flowing at the slightest hint of lint!!! Really should take out the carbs and inspect. If you can't clear it up with spray-cleaners, send it off to Ducatiman to get a real good cleaning. And rebuild if necessary.
Old June 1st, 2017, 03:29 PM   #5
Flying
Motorcycle(s): 2010 Ninja 250
The 250J is the 250R.
Look at ebay or jetsrus.
Old June 1st, 2017, 06:13 PM   #6
ducatiman
ducatiman's Avatar
Doesn't the 250 have the same tank vent issue as the 500?
Could that be at play here?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old June 1st, 2017, 07:56 PM   #7
MrAtom
MOTM - July '15
Also:
EX250R= "Ninja 250"
EX250F= "Pregen Ninja 250"
EX250J= "Newgen Ninja 250"
Weird, right?
Old June 1st, 2017, 11:02 PM   #8
Ghostt
Ghostt's Avatar
I know the PreGen does, it uses the exact same cap, I'm not sure the NewGen does, but knowing Kawasaki I'm sure it's similar.
I have a write-up on the cap vent fix, if needed. but it's for the PreGen, but I'm sure it might apply here re as well.
ZX-2R BLOG
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
Want EX300A/250J forks or tubes;Have complete 250F triple w/'08+ brake/wheel hardware CZroe Items Wanted 6 January 26th, 2013 08:21 PM
2008 250J shock installed JeffM 1986 - 2007 Ninja 250R Farkles 27 July 20th, 2011 09:30 AM
