May 21st, 2013, 02:10 PM | #1 |
Crash Test Dummy
Join Date: May 2013 Motorcycle(s): none (at the moment) Posts: 88
Engine braking
So I'm very new to this but in riding around I find myself using engine braking and throttle control to slow down for planned stops (lights, turns, stop signs, etc), far more than either wheel brake. It seems to be successful, and I can retain a normal stopping distance with this, however I don't see this discussed often on here, but I frequently see references to proper braking technique with wheel brakes, so this raises two questions:
1) Am I setting myself up for any kind of trouble by doing this? 2) Is this going to cause increased wear on the engine (on a long term basis)? |
May 21st, 2013, 02:13 PM | #2 |
just be sure to use it while feathering the brake lever at the very least so that the cars behind u kno ur slowing down
May 21st, 2013, 02:21 PM | #3 |
1) no
2) yes, slightly. but you probably wont really do any damage unless you are being extremely aggressive with your engine braking. if you feather the clutch out and don't send the RPMs above redline you'll probably never see any issues from it.
May 21st, 2013, 02:22 PM | #4 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Most of us racers red line and down shift (engine brake) from there more than the average street rider. I've own my bike a little over 5 yrs now and I haven't had any problems with the engine whatsoever. With that said, someone once asked me, "What's more inexpensive to replace? Transmission or brake pads?"
I honestly don't think you'll have any problems by downshifting/engine braking. If anything I encourage it especially in emergency brake situations (a.k.a. panic stops) with front brakes than using both the front & rear brakes.
May 21st, 2013, 02:27 PM | #5 |
it will blow out your crank journal before it will destroy the transmission. transmissions are easy to fix... $100 for an entire trans with bearings.
May 21st, 2013, 02:31 PM | #6 |
Fast-Guy wannabe
MOTM - Jan '13
What rmp range are we talking here?
6-8k 8-10k 10-12k Regardless you'll be fine if your shifting smoothly. |
May 21st, 2013, 02:56 PM | #7 |
Join Date: Jan 2013 Motorcycle(s): 03' Ninja 250ex Posts: 333
I do it all the time. Just be careful not to loose traction if your being super aggressive... like I was a few weeks ago and got a lil fishy with my bald rear tire!!
Perform Random Acts of Coolness!!ATGATT |
May 21st, 2013, 03:19 PM | #8 |
Join Date: May 2011 Motorcycle(s): 2005 Yamaha FZ6 Posts: 169
Make sure to get in the habit of using the brakes effectively in emergency situations though... If you get too used to engine braking, you won't instinctively brake correctly when you need to.
1 out of 2 members found this post helpful. |
May 21st, 2013, 03:22 PM | #9 |
CVMA #74 WSMC #750
Brake check cagers behind you.
May 21st, 2013, 03:22 PM | #10 |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
When I engine brake on the streets, I still use the front brake slightly so the brake turns on.
CVMA #55 |
May 21st, 2013, 04:42 PM | #11 | |
12,000 miles of motorcycle riding, and been driving stick ever since I had a temporary permit. I've always used the engine for some amount of slowing down because it's convenient. Never once have I tried to engine brake instead of using the brakes when making a quick stop. Oh that car's slowing faster than I expected? How about I downshift to 4th... Engine braking: totally fine. Just make sure to rev match and/or let the clutch out smoothly so there's no unnecessary jerking, and do as you please. |
May 21st, 2013, 06:54 PM | #12 | |
You have been riding your bike for less than a week, reason for which we are very happy that you are asking questions here. 1) We can reduce speed slowly or quickly. The engine braking technique is more suitable for the slow reduction, while the brakes (both for you for now) are best for quick speed change. With more miles of practice, you will find your own comfort way of doing this, even mixing both up. 2) Absolutely not, as long as you stay in the same gear until the bike comes to a speed so low that the engine starts jerking up. At that moment, you pull the clutch and apply brakes for a final stop. Others above have mentioned downshifting. That is something necessary to learn in order to engine brake for a bigger range of speeds. Let's say that you are using 5th gear and coming to a stop sign. You will not get engine braking effect all the way to the stop if you stay in gear 5: the effect will fade away soon. After some slow down, you will need to switch to 4th gear in order re-activate the braking effect, then to 3th, then to 2nd. It is a little complicated for trying it now, but after several more hundred of miles you should start practicing it. This thread will help you: http://www.ninjette.org/forums/showthread.php?t=99060 Also, I recommend the book "Proficient motorcycling", if you have not read it yet. Reading these threads will not hurt: http://www.ninjette.org/forums/showthread.php?t=134094 http://www.ninjette.org/forums/showthread.php?t=127127
May 21st, 2013, 08:38 PM | #13 | |
Of course I use engine braking all the time in addition to the brakes. I was just pointing out since this guy is a brand new rider that he should be focusing on learning how to use the brakes well to develop good long term skills. Engine braking is obviously helpful but as a new rider it's not gonna be of much help when he needs to slow down quickly to avoid a collision. |
May 22nd, 2013, 11:05 AM | #14 | |||||
Crash Test Dummy
I've been using it more and more due to that last fact. I started using it for two reasons (might be right, might be wrong) - it allows me to better track which gear I'm in rather than simply counting clicks, and it gives me more positive control of the bike's speed. Ie, if I need to adjust speed (especially if I need to do so quickly), throttle and clutch are already in use and at a usable speed/RPM, and it's just a matter of rolling back on the throttle. A couple quick questions, since we're on the subject: a) This might be more of a tech question, but can the brake lever be adjusted on the Ninja? Reason being that it might not be that difficult with the throttle at rest to cover the brake, but rolled on, my finger(s) aren't likely to touch it, much less cover it effectively. No excuses for bad habits, but that would help things out.. b) outside of simply executing panic stops, are there any other drills I could run to build braking proficiency? I haven't found that open parking lot yet, but if I did, I'd like to maximize the opportunity. |
May 22nd, 2013, 02:48 PM | #15 | |
As a newb should he practice braking?? YES. should he practice downshifting smoothly? YES. Should he even worry about confusing the two? NO! It's like a car or bicycle or anything with wheels; how do you slow down? use the brakes... As for me: pro? not by a long shot. Always learning. competent? definitely. Confuse engine vs brakes for slowing? never. But since we're on the topic, new riders (all riders really) should go to a clean, empty parking lot and work on their hard braking from 25 mph. They should work on using the rear brake at low speeds to make low speed maneuvers more smooth. They should work on using the front brake confidently, even if it feels like the tail is going to fly, or the nose is going to tuck. Learn to trust the brakes. If more riders knew how to use their brakes, there would likely be fewer cases of riders running into things. Same with cars drivers. |
May 22nd, 2013, 05:05 PM | #16 | |
b) http://amgrass.com/
Motofool .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; June 7th, 2013 at 04:04 AM. Reason: Spelling correction |
May 24th, 2013, 07:11 PM | #17 |
Braking and downshifting go hand in hand. Whether it's on the track where the rear end may be dancing after banging down the gears coming off a high speed straight or coming to the traffic light on the street, they serve a similar purpose. That's to be in the right gear when it's time to accelerate again.
On the street, it's useful/fun to use engine braking, it's leisurely, louder, works to help slow you down, and the biggest thing is it helps you downshift your bike. If you just pull in the clutch in 5th gear and roll to a stop, you might not be able to get to first very easily. In your manual cage, no problem....just one swift move takes you from 6th to 1st. Plus, if the light turns green (or the cager on your 6 doesn't slow up) you can actually speed up because you are in a useable gear. Whether it's the stop light or your favorite corner, being in the right gear helps you exit quickly. Isn't this why we like our performance cars in manual? If you are moving quickly, and downshift, it's POSSIBLY to over rev, but for the most par, unless you are speeding up hard at the time, you aren't harming the bike... Your rear-end will break loose before you break anything. Bonus Off Topic Opinion: I still practice braking in parking lots after 3 decades of riding (and some track time). But, no amount of parking lots are going to prepare you for what your bike is going to do upon grabbing a fist full of front brakes at 80mph on the interstate. |
May 25th, 2013, 12:19 PM | #18 | |
May 25th, 2013, 03:11 PM | #19 | |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Look at schools on the weekends and churches during the week. Look for decent pavement quality with very little or no debris. Hard braking drills are really important to work on early in your riding career so that you can have a better chance of having a nice, long riding career. Stopping is the most important skill to master, in my opinion.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
June 6th, 2013, 07:07 AM | #20 |
Big Dreams, Small Wallet
Join Date: Feb 2013 Motorcycle(s): 08 Ninja 250R (Sold), 93 VFR750F (In Pieces) Posts: 508
This. Plus you feel like a MotoGP superstar when you do it right and roll into that next corner.
~BRad |
June 6th, 2013, 07:21 PM | #21 | |
Crash Test Dummy
I know a few people who cover solely with their index, but mine doesn't really even fully reach - hence the question about adjusting the lever - so the primary would be my middle, with the index engaging as soon as it starts to move inward. Just want to make sure I'm doing this the most effective way possible. |
June 6th, 2013, 07:30 PM | #22 |
Sounds like you have it figured out Ryan. Just need to tailor the controls to your size and feel.
June 7th, 2013, 04:39 AM | #23 | ||
However, I did not advise covering the front brake lever. It is a good technique, but in my opinion it is not for the first times of riding. For me, it has two purposes: 1) To reduce the reaction time and attention for braking (around half a second). 2) Help modulating the throttle with more finesse. The problem with #1 is that you must have learned (and made it a habit) to press that lever slowly enough to make the brake application gradual. New riders are more reactive than pro-active, meaning that their control inputs are on the verge of a panic reaction (no offense, just a natural thing). When their brain think "emergency brake!!!", that right hand will suddenly squeeze that lever as hard as it can. The problem with that is that the pressure of the pads will overcome the friction force on the contact patch of the front tire, the front wheel will lock and that new rider will lose steering first and balance immediately later, resulting on a fall. In order to avoid that, we need to wait for most of the weight to be transferred forward (inertia is acting here), loading that front patch and greatly increasing its friction against the pavement. If your fingers are over that lever, it is way too easy to lock the front wheel and to fall. Instead, practice initiating each braking with the rear tire and apply the front only after you feel that the front tire is properly loaded. In a real emergency situation you will not think, you will do what you are used to do everyday. Besides, you don't need that extra stress on your hand for now, you have enough skills to develop and things to get used to. Quote:
If your fingers are short, installing an adjustable lever is the best solution. Unfortunately, the distance to the bar of the original lever cannot be adjusted. Keep practicing carefully, Ryan !!!
July 6th, 2013, 11:21 AM | #24 |
rev match by bliping the throttle before a downshift and you'll be fine,
now, mastering the blip while grabbing the front brakes is the challenging part |
July 6th, 2013, 08:35 PM | #25 |
Join Date: Jun 2013 Motorcycle(s): 07' Ninja 250r Posts: 32
That downshift blip is so satisfying when you get the timing right
Just like a pro !!! |
The power of engine braking | Motofool | Videos | 16 | February 24th, 2015 02:22 AM |
Reduce Engine Braking? | tnr4 | 2013 - 2017 Ninja 300 General Discussion | 30 | December 22nd, 2012 10:18 AM |
down shifting vs engine braking | dimeified | Riding Skills | 57 | April 10th, 2012 06:05 AM |
Engine braking...good or bad? | ChaosFromAbove | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 28th, 2010 07:54 AM |
Engine braking and other question | Rafalski | Riding Skills | 1 | July 30th, 2009 10:07 PM |
