June 1st, 2012, 05:56 AM | #1 |
Join Date: Apr 2011 Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold) Posts: 479
Long trip ahead
Any special maintenance issues to consider for long road trips? I'm going to Florida on the bike later this month with a friend. The trip is about 550 miles one way. I know the standard TCLOCKS check list but didn't know if there are other considerations for 10 hours of almost constant operation. My bike has about 2500 miles on it and a fresh oil change with Rotella T6. I need to check the coolant and brake / clutch fluid levels.
My warranty is about to expire before the trip too. I was thinking about adding the 2-year GTPP just in case for one reason only. I was leaving work on Wednesday afternoon and saw a customer who looked like she needed help in the store. Her reply was "Sure, if you can tell me where the nearest Harley dealership is". Turns out she and her mom were riding cross country from Las Vegas and her new bike had a CEL. I led them to the Harley dealer, talked for a bit, and then parted ways. Point being, I'd hate to be hundreds of miles from home and picking up the tab for something that could've been covered under warranty. Is that paranoia or a legitimate concern? |
June 1st, 2012, 06:34 AM | #2 |
Mostly paranoia my friend.
1100 miles should be no sweat assuming everything is in order before the ride starts. But for rides that take me a distance and away from my normal support system. I do a bit extra. For example, there is a DIY 600mile service checklist linked somewhere on this site. I do a scaled down version of that. Visual/feel check the following; Brake, clutch and throttle cables Brakes All lights Shifter linkage and bolt Chain slack Coolant level Licence plate bolts Any Leaks? Now is the time to address anything else on your bike that might worry you along the way If weather is a factor (which it will, being an old FL man myself), proper gear for that. It's most likely the trip is going to be harder on the rider than the bike. AAA is a safer bet than an extended warranty for your trip. If you want the kawi warranty, get it for the cost coverage not trip coverage. Enjoy the trip and safe travels! Oh! Take a camera and get a few shots along the way.
June 1st, 2012, 06:54 AM | #3 |
Yes, Florida weather is going to be hard on you guys: heat, humidity and afternoon thunderstorms.
I would take extra motor oil, chain lubricant (keep an eye on those two during the trip), tire repair means and Gatorade. Also some clean rags and water to clean the visor of the helmet (bugs, cars splash, etc.) and sunscreen (for wrists and neck?). Flashlight, knife, soft wire and duct tape are universal tools.
June 1st, 2012, 07:57 AM | #4 |
Join Date: Apr 2012 Motorcycle(s): 2008 ninja 250R 1979 SuzukiGS425E Posts: 94
Just took a similar length trip and the only mechanical adjustments I had to make were a clutch cable adjustment and drive chain tension. I would recommend you take/make sure your tool kit has wrenches to adjust chain slack (12mm and 14mm I think?) as it loosens. Sounds like it will be a good trip! Have fun!
June 1st, 2012, 08:01 AM | #5 |
Join Date: May 2011 Motorcycle(s): 2009 blue ninja 250r Posts: 223
Tank bag helped me out on my trip so much(rest on it). And many many short breaks. I'd also make sure you have a rain suite and all year gear in water proof bags. Warenty should not be needed IMO but for peace of mind might not be a bad idea. Have fun tons of pictures be safe.
If you’re going to lead, then lead. If you’re going to follow, get the hell out of my way! |
June 2nd, 2012, 07:19 PM | #6 | ||||
June 2nd, 2012, 09:06 PM | #7 |
Antifreeze is antifreeze.... Put whatever you like in there but I try not to mix brands or types. For your next coolant change, might I suggest a good flush of the system and fill with proper mix of engine ice & distilled water. Higher cooling effect but with antifreeze properties (-26 protection).
As for your brake fluid, do you remember what type is currently in there? I have learned mixing them is not recommended but it's also not the end of the world either. But yea, top off with DOT 3 or 4. AAA may have something specific for motorcyclists but to my knowledge they don't care what your transportation is. Car, truck, bike they will tow you for free and get you to shelter at a discounted cost. It's cheap $50 roadside assistance for the entire year no matter where you are. hmmm... Check with your insurance provider, they may already include something similar in your policy.
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; June 4th, 2012 at 08:08 AM. Reason: grammar |
June 3rd, 2012, 04:13 AM | #8 |
I have no clue. It's whatever the factory uses. That why I was thinking I should pick up a bottle from the dealer. What happens with mix of 3 and 4? I know dot 4 withstands higher temperatures.
June 3rd, 2012, 06:27 AM | #9 |
Factory supplied is DOT 4, which has a dry boiling point 45 degrees higher than DOT 3.
Both are chemically compatible (polyethylene glycol-based). DOT 5 is silicone-based and not good for the Ninja.
June 4th, 2012, 02:01 AM | #10 |
Thanks! I should have read the shop manual. It was in there. I topped off the rear reservoir with no issue. I filled the front to the fill mark per the factory manual and it began seeping through the seal on the cover plate. I pull the cover and took some out. Did I do something wrong?
Last futzed with by geeker; June 4th, 2012 at 04:37 AM. |
June 4th, 2012, 02:43 AM | #11 |
CBR250R Traitor
Join Date: Jun 2011 Motorcycle(s): 2011 Red CBR250R 2009 Ninja 250r SE(With 2008 Fairings)(sold) Posts: 924
+1 on checking your license plate bolts.
One of mine fell off on my 750 miles trip. People kept signaling me to tell me about it. |
June 4th, 2012, 06:20 AM | #12 |
As long as the level is withing the glass visor, everything should be OK.
The seal is a rubber diaphragm that allows changes in the level when the brake is operated and isolates the fluid from the atmosphere at the same time. The reason is that the DOT 3 and 4 absorb humidity from the air very quickly, which is not good for the internal parts of the brakes.
June 9th, 2012, 11:12 AM | #13 | |
June 9th, 2012, 11:27 AM | #14 |
I don't know about the new-gen, but the gears and cable of the speedometer are not difficult to service and lubricate.
Caveat: Don't over-lube, since lubricant could slowly drip down on the front tire. Glad you are ready; Florida weather has been nasty this week.
June 9th, 2012, 11:43 AM | #15 | |
June 26th, 2012, 07:22 PM | #16 |
The trip went great! The weather cooperated all week and it was comfortable on the way down. The heat was on all the way back home though. My bike had a electrical problem that caused the starter to run all the time the night before I left. I ended up finding a pinched bundle of wires to the starter button. A clunk developed in my steering while I was there. It was the only adjustment that I needed. No oil was used, a little coolant was added once I got home, but that was it. Twelve hours down and twelve hours back. I spent less than $80 on fuel round trip. Ready to go again
Newbie on long-distance trip! | Vagabondesss | New Members | 40 | July 29th, 2015 11:15 PM |
How hard/Long of a trip would it be to go 4,000 miles on my 250? | Floki | General Motorcycling Discussion | 17 | December 8th, 2013 03:18 PM |
Took my first long distance trip | sunspots | Ride Reports | 4 | August 25th, 2013 09:39 AM |
First long distance trip | slickt0mmy | General Motorcycling Discussion | 16 | May 24th, 2013 02:08 PM |
[topix.net] - Monaco here we come! Fundraisers set for a long trip | Ninjette Newsbot | Motorcycling News | 0 | May 29th, 2010 10:21 PM |
