Old June 29th, 2015, 06:51 PM   #1
HerpDerp1919
Motorcycle(s): 1989 Kawasaki Ninja 250
Leaky petcock question
So, I finally got my bike going. Took it out for a ride today and it was fantastic. Until I got home. Noticed a large pool of gas under the bike, Fuel dripping out of the air box and when i turned it over it was flooded and literally shot fuel out the exhaust pipe. The carbs were just professionally rebuilt. SO I made a phone call and discovered it is in fact a leaky petcock causing it to overflow and flood the bike out. But, Ive just dumped well over a few hundred bucks in to this bike in a short amount of time, im flat broke. Would splicing in a manual fuel shut off keep it from flooding until I can afford a new petcock?
HerpDerp1919 is offline   Reply With Quote
Old June 29th, 2015, 08:37 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Fuel petcocks aren't that expensive...
Old June 29th, 2015, 08:43 PM   #3
Ghostt
Ghostt's Avatar
First of all contact @ducatiman, second read my write-up below
If your petcock is shot, save your time, and money and get a new one, the cost of rebuilding it isn't much cheaper, due to you need two separate kits, as they for some reason don't make just one.
New one cost about $65.00
http://www.partzilla.com/parts/detai...1023-1139.html
Also be sure to order the orings(92022-183 WASHER,6.2X11X1.5)and new bolts(92001-1091BOLT,6X20),trust me you'll be better off in the long run.
Rebuilding kits are about $60 total.
K&L Supply Diaphragm Only for Fuel Petcock Repair Kit 18-6638 https://www.amazon.com/dp/B0055DWO60..._s1CGub1W9N3PH
K&L Supply Fuel Petcock Repair Kit 18-2723 https://www.amazon.com/dp/B001KO2JRW..._U1CGub05DT5NT
IMHO not worth it rebuilding, also be sure to check vacuum and fuel lines for wear, holes, and cracks, if in doubt replace them.
violente et ignorantia
ZX-2R BLOG
Old June 30th, 2015, 04:10 AM   #4
HerpDerp1919
Yeah,i got in contact with him last night and he was the one who directed me to the petcock. I know they're not that expensive. Okay, $65 is manageable, my local parts place wants $100. So can I just put a manual one online for now until my new one gets here? I just don't wanna mess the bike up with it getting gas in thecrankcase every time I ride
Old June 30th, 2015, 04:28 AM   #5
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
You are lucky you cought it. This little device has damaged many engines. And I bet it burned down some garages also.
Worlds fastest 250 ninja
Old June 30th, 2015, 07:57 AM   #6
If the float valves were working properly, the carbs would not overflow, regarding condition of the petcock.
Petcock is full opened when engine is generating vacuum and still keeping the proper fuel level in the bowls is the job of the valves of the floats.
Old June 30th, 2015, 10:37 AM   #7
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Quoting for emphasis.
The petcock and the float valves both stop the flow of fuel. If gas is leaking into the engine, both of those parts are bad and need to be fixed. Your professional carb cleaning was incomplete/ineffective.
Old June 30th, 2015, 11:47 AM   #8
Ghostt
Ghostt's Avatar
Did you install a fuel filter? If not you might have sucked up some crud from the tank, into those new carburetors, which might have stuck the float needles open. Did you ever pull tank and rinsed it out? Verified the petcock operation?
If the float valves are working properly, it wouldn't flood, also I'm going to guess you now have gas in then engine oil.
ZX-2R BLOG
Old June 30th, 2015, 01:18 PM   #9
I agree with Motofool, InvisiBill, and Ghostt, and will add that the float valve assemblies (needle and seats) do wear, and should be replaced when you clean or "rebuild" a carb.
Crud in the tank will get under the needle and not let it seat completely, as Ghostt noted.
Old June 30th, 2015, 01:32 PM   #10
ducatiman
ducatiman's Avatar
Float levels standard procedure,
Tylers carbs before...wouldn't run
After, all circuits confirmed clear...bike confirmed running upon install.
Carbs *were* cleaned properly, float valves replaced, seats dressed. Levels adjusted, wet tested, held fine.
...I can not control peripheral circumstances.
Phone message placed with Tyler, we'll be talkin'.
Old June 30th, 2015, 01:59 PM   #11
I don't doubt you did your job. Your carb work is well-respected and often recommended.
Chances are some debris from the tank got stuck under the needle.
Old June 30th, 2015, 02:30 PM   #12
Ghostt
Ghostt's Avatar
Anybody care to wager on the fuel filter?
I run a fuel filter on mine, and below is the pictures of my carburetors after5k miles, and yes I use my reserve at least one every tank.
These are just the way I found them went I opened them up, nothing else done.
Fuel filter is critical for the PreGen as it doesn't have a proper one.
ZX-2R BLOG
Old June 30th, 2015, 03:04 PM   #13
HerpDerp1919
Yes, I went through and cleaned the tank and checked over the petcock. This bike has also been sitting for minimal two years so all the petcock seals are most likely bad. The bike is probably worth $600So I'm not too interested in sticking more money in to it. I'm just putting a manual shut off in line and calling it a day. Yes ghostt there probably is oil in the crank case. Gonna change the oil again. For the third time since I got the bike 3 weeks ago.
Old June 30th, 2015, 03:05 PM   #14
HerpDerp1919
Fuel in the crankcase. Fuel. I would surely hope there's oil in the crankcase or I got bigger issues lol
Old June 30th, 2015, 03:49 PM   #15
Ghostt
Ghostt's Avatar
Adding the manual shut off, won't fix the stuck float valves, you need to clean those again, and install a fuel filter, one from a motorcycle shop, they sell them for a couple of bucks.
ZX-2R BLOG
Old July 1st, 2015, 05:21 PM   #16
HerpDerp1919
Pulled the carbs. The float valves don't leak. At all.
Old July 1st, 2015, 06:58 PM   #17
Ghostt
Ghostt's Avatar
All it takes is a grain of crud, and they won't seat properly.
Clean them and the seats, and verify all is clean, then if your not running a fuel filter, now is the time to get one, and install it.
There's only one way fuel gets into the carburetors properly, and it's past the float valves.
The other way is if the vacuum petcock is bad, as in the vacuum diaphragm has a hole/crack in it., the vacuum will pull fuel thru the vacuum line.
Verify that the petcock is working properly, odds are is not, given the age of the bike. My petcock was bad, and it's a 98'
ZX-2R BLOG
petcock question. berserk81 General Motorcycling Discussion 3 December 12th, 2013 08:08 PM
Petcock Question az3200 1986 - 2007 Ninja 250R Tech Talk 3 June 3rd, 2013 06:25 PM
2000-2007 Ninja 250 Leaky Fuel Tap / Petcock - $30 conrya5 Motorcycle-related 0 August 22nd, 2012 02:54 PM
Leaky petcock Cuongism 2008 - 2012 Ninja 250R Tech Talk 4 August 18th, 2011 07:31 AM
petcock question Realirony 2008 - 2012 Ninja 250R Tech Talk 6 March 9th, 2009 11:55 AM
