July 5th, 2009, 12:14 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): Ninja 250R, Cbr 600RR Cbr600F4i Posts: 75
Thread pitch and size for Spool bolts
Does any one know the thread pitch and bolt size (ie m8, m10) for our swing arm spool bolt positions?
I bought a set of spools and the bolts are too small Any help would be appreciated Thanks! jason |
July 5th, 2009, 12:25 PM | #2 |
Jason - the thread about which spools fit has that info - I'm just too lazy to go searching for it right now - though I know I posted in it
July 5th, 2009, 12:31 PM | #3 |
IC2(SW)
July 5th, 2009, 12:39 PM | #4 |
Ic
10 mm is refering the bolt length or actual size... So it would be M10? I need to put two bolts in temporarily so i can just lift the bike and adjust the chain. I need to order spools later. Anyone know if 10mm is the bolt size and not the length? and thanks kim and Kerry |
July 5th, 2009, 01:15 PM | #5 |
It was also mentioned in the first thread, that the bolt size and thread pitch is difference between bigger bikes such as the zx14 and the current 08+ ninja 250
would this link apply? |
July 5th, 2009, 01:21 PM | #6 |
Join Date: May 2009 Motorcycle(s): 09 ninja 250(red) Posts: 193
pitch is 1.25
Rear spool thread size | Robbo81 | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 18th, 2014 01:48 AM |
Mismatched swingarm spool thread pitch? | krakatak | 2008 - 2012 Ninja 250R Tech Talk | 24 | May 16th, 2014 09:41 AM |
Spool size? spool bolt length? | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 29th, 2013 08:48 PM |
swingarm spool bolt size? | maxgohan | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 12th, 2013 02:54 PM |
thread pitch size for carb screws | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 17th, 2013 11:49 AM |
