Old June 23rd, 2023, 03:56 AM   #1
dom
Motorcycle(s): 04 ninja 250r
i can't get it started
it seems like i tried everything.
i bought a 04 ninja 250r and they said the carb needed replacement but it ran i rebuilt the carb changed the plugs and the starter and it won't start or it will start and stay idling with the choke on but if i use any throttle or turn the choke off, it dies
i think it might be a vacuum leak but i have no clue been trying to get it running for a week
thank you
dom is offline   Reply With Quote
Old June 23rd, 2023, 05:34 AM   #2
Hi Don, welcome!
It's common with these bikes for the carburetors to get dirty, and it's very difficult to get them truly clean. Take a look at this page: https://n4mwd.blogspot.com/2013/10/s...-passages.html
Did you use jets from a carb kit when you rebuilt them? If so, that is probably contributing to your trouble. Kits contain aftermarket jets that are not correct. Also, if someone previously worked on the carbs, it's possible they assembled them wrong or left out important pieces. That happened to a guy here recently.
Old June 23rd, 2023, 05:23 PM   #3
Dom-
you made sure needle jets are present and correctly assembled (below the emulsion tubes) ?
Old June 24th, 2023, 04:12 AM   #4
Shafer
Talking
Guys it was one time....lol
Don't be like me.....the inverted needle jet is a bad performance mod
Old June 24th, 2023, 04:44 AM   #5
dom
what does that mean i think my needle is right
Old June 24th, 2023, 04:49 AM   #6
Shafer
Back story is I installed those sliver tubes in the picture by dropping them in place via the carb throat. Totally wrong.
The correct way is to insert them first before emulsion tube and main jet.
When I had mine installed incorrect the bike would not rev past 5-6k before dropping power.
See Gordon's post picture for correct orientation.
Old June 24th, 2023, 04:55 AM   #7
Shafer
thank you
Does this problem happen after a ride or just at start up?
What's your idle rpm set at when running?
Things to check:
-Airbox to carburetor fully seated and sealed
-dirty air filter
- spray wd40 or starter fluid around the ends of the carb holder boots at idle if the engine stumbles or accelerates you've found your leak.
Also check around the airbox|carb connection.
I like to take my seat and side fairing off, some times the spray will make its way to the air intake and make you think you found a leak.
Old June 24th, 2023, 08:40 AM   #8
Dom-
Care to share with us your carb cleaning "tools" you are employing? Pro compressed air? Soda blasting? Chemicals? Ultrasonic machine?
Old June 25th, 2023, 09:49 AM   #9
dom
found the problem
after a little over a week i found the problem i put the needles in through the plastic nub piece and not over it
Started Racing cbinker Ninjettes At Speed 17 October 11th, 2015 08:04 AM
Anyone into BMX? Trying to get started the big mike Off-Topic 6 January 5th, 2015 08:53 AM
Tools to get started? WhiteRice 2008 - 2012 Ninja 250R Tech Talk 16 November 11th, 2011 03:44 PM
getting started bhalv New Members 13 October 14th, 2010 07:36 PM
Started a blog here! VT Wes General Motorcycling Discussion 4 September 15th, 2010 08:28 PM
