Old December 4th, 2014, 03:42 AM   #1
RuthlessZ
Motorcycle(s): 05 Ninja 250R
Necessity of Gauge Cluster?
Sorry guys I searched around and ultimately couldn't find a Ninja 250 specific answer. Is my gauge cluster necessary I'm currently fixing some(alot) of neglect to my bike, and decided to trash my front fairing,. but the bike looks silly with the stock headlight and front fairing so I was merely curious if I could remove the gauge cluster all together? I would like to remove it and then take the speedo out and find another way to case/mount it on the side of my tank. Thanks appreciate it. I assume this is a silly question and the answer is no you don't need it, and I'm aware I'll have no way to know if I'm out of oil and it's about to blow up.
-Jon
RuthlessZ is offline   Reply With Quote
Old December 4th, 2014, 07:18 AM   #2
Ghostt
Ghostt's Avatar
-Jon
There is an answer to you dilemma, check out http://bluecollarbobbers.com/m/caferacer.html
They have made a custom dash kit the uses your OEM gauges and warning lights. Give them call, they will sell individual parts of their kit.
Good luck
Kawasaki Ninja 250 Instrument Panel: http://youtu.be/akmBflxmNxM
violente et ignorantia
ZX-2R BLOG
Old December 4th, 2014, 09:49 AM   #3
Jetfoi
Jetfoi's Avatar
Motorcycle(s): 2013 zx6r and 1995 250r
even the bluecollarbobber cluster seems to big for my taste...you should look at the vapor unit...its nice and small and very clean
spend all the spare time on two wheels
Jetfoi is offline   Reply With Quote
Old December 4th, 2014, 09:56 AM   #4
get rid of it.
Old December 4th, 2014, 10:14 AM   #5
Ghostt
Ghostt's Avatar
To the OP, you got some decisions to make, you got some good choices, Vapor unit is definitely cool, and modern looking.
What's the look your going for? Fighter, bobber, ?
ZX-2R BLOG
Old December 4th, 2014, 11:13 AM   #6
MrAtom
MOTM - July '15
I don't even think you need a gauge cluster in some states. Like, you can actually not have a speedometer. Trouble is, if a cop wrongfully writes you a speeding ticket, there's no way you can contest it at all.
Old December 4th, 2014, 11:46 AM   #7
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
get rid of it.
You don't need one at all, I don't run one on my pregen.
though I wish I had a shift light, I should get on that
Old December 4th, 2014, 11:52 AM   #8
you have to disclose that the milage on the non-existent speedometer is not accurate if you sell it. i believe that is the only regulation involved.
Old December 4th, 2014, 01:01 PM   #9
skilletmo
InfoWhore
skilletmo's Avatar
Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC
Get a Trail Tech Vapor.
Everyone, go buy a dirtbike hurry
skilletmo is offline   Reply With Quote
Old December 4th, 2014, 02:33 PM   #10
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
You can just remove it (unplug the connector and remove the speedo cable at the wheel). I agree that the Vapor is a good, small alternative. Even smaller (and cheaper) is Trail Tech's Endurance II, which is a speedometer/odometer without the tach, but still with the durability and backlight you need for a streetbike. Check it out at Trailtech.net.
Chicagobob is offline   Reply With Quote
Old December 4th, 2014, 02:36 PM   #11
Hero Danny
Inline 4!!!
Hero Danny's Avatar
You better be careful how you mount your gauge cluster, if you F it up then it will look like complete D.S
Be careful. Remember you are
invisible
Old December 4th, 2014, 02:37 PM   #12
skilletmo
InfoWhore
skilletmo's Avatar
https://www.ninjette.org/forums/showthread.php?t=129394
Old December 4th, 2014, 03:00 PM   #13
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I could live without the dash all together. There are small alternatives. But I ride bicycles with out a speedo and don't care.
Worlds fastest 250 ninja
Old December 4th, 2014, 03:03 PM   #14
i think the oil pressure light is like the only one you can't tell from just feeling. maybe the only important one. maybe coolant temp too.
Old December 4th, 2014, 06:02 PM   #15
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Are those just light bulbs with no dashboard circuitry behind them? Or would one have to salvage/kludge some electronics if one wanted to put those two things (and a bicycle speedometer) in a little custom bud box?
Old December 4th, 2014, 06:13 PM   #16
i think its a dumb bulb
Old December 5th, 2014, 04:14 PM   #17
RuthlessZ
Wow guys thanks for all the info I appreciate it. I really like the Vapor option, as far as looks I'm not really going for anything in particular, just trashed my front fairing, and the stock headlight/gauge cluster looks dumb with no fairing. I could give two shits about the legality of it, I just wanted to make sure the bike wouldn't have any issues without it. I may try and wire up a light for the low oil pressure but other than that I think I'll just ditch it.
Here it is in all it's ugly glory now.
Old December 6th, 2014, 09:19 AM   #18
Let me throw you a curve ball.
Just put a aluminum plate where your cluster would be. A small one, rectangle shaped, about the size of your cell. Get an old smartphone, and mount it on that plate. A gps speedo app should do nicely. There are plenty to choose from and I would be you can find one to strike your fancy.
Doubles as a gps nav, speedo, music player and can still make 911 calls.
Old December 6th, 2014, 09:20 AM   #19
Oh! Welcome too.
Old December 6th, 2014, 09:38 AM   #20
Ghostt
Ghostt's Avatar
I'll see your cell phone, and raise you a tablet,
http://www.webbikeworld.com/gps/nexu...t-as-a-gps.htm
ZX-2R BLOG
Old December 8th, 2014, 05:20 AM   #21
Jetfoi
Jetfoi's Avatar
haha tablet is an awesome idea just seems a bit big....i looked into the cell phone option for myself awhile back but how good is gps for speed is my only question...
Old December 8th, 2014, 08:20 AM   #22
Ghostt
Ghostt's Avatar
Better than the OEM speedometer LOL
ZX-2R BLOG
Old December 8th, 2014, 10:30 AM   #23
Jetfoi
Jetfoi's Avatar
That is the truth!!
Old December 8th, 2014, 10:46 AM   #24
Ghostt
Ghostt's Avatar
That is the truth!!
I would love it if Vapor made a unit with a GPS receiver to take care of that kind of stuff , mph, odometer, trip meter etc......
ZX-2R BLOG
Old December 8th, 2014, 11:19 AM   #25
Jetfoi
Jetfoi's Avatar
Yeah but they use a sensor on the wheel which I think has a more accurate reading...do you not agree?
Old December 8th, 2014, 11:37 AM   #26
Ghostt
Ghostt's Avatar
Not really sure, depends on installation, but it wou make it easier, no calibration needed, plug-in. ride
ZX-2R BLOG
Old December 8th, 2014, 11:45 AM   #27
Chicagobob
Chicagobob's Avatar
GPS is very accurate, but it requires a satellite connection, and the readings are not as immediate as those based on the bike's wheel speed.
The Trail Tech speedos are very accurate, and are adjustable so you can dial them in for different bikes, or when you change tires. They have a good equation that allows you to set the speedo based on tire circumference (the distance the wheel travels in one revolution).
Old December 8th, 2014, 11:58 AM   #28
Ghostt
Ghostt's Avatar
Very true, I guess we have to wait for the technology to catch up, but the coolness factor and possibilities for this would be awesome, just use that imagination, Bluetooth conductivity, maybe a hud , or something like the AH64 crew, hell I want Jarvis based helmet.
ZX-2R BLOG
Old December 8th, 2014, 12:09 PM   #29
You're in VA, you may lose sat. signal every now and then in the valleys/bottoms between those hills but not all of them. Even in the backwoods of KY, I only lose gps in a few spotty areas. It should be just fine in the town/city areas 100%.
The gps refresh rate on the worst cell phone (about 2 sec) is still much better than the 5%-10% inaccuracy on the factory speedo. imho....
Old December 8th, 2014, 12:21 PM   #30
Ghostt
Ghostt's Avatar
Jarvis I bet is killer accurate, anybody got Tony Stark's phone number?
ZX-2R BLOG
Old December 8th, 2014, 04:28 PM   #31
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
I just used my Iphone or a GPS on my old ninjette. I never readlly needed a cluster.
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old December 9th, 2014, 10:29 AM   #32
Ghostt
Ghostt's Avatar
One must also remember that GPS technology is used in aviation, and avionics, both military and civilian.
ZX-2R BLOG
Old December 10th, 2014, 01:33 AM   #33
Insan3guy
Insan3guy's Avatar
Motorcycle(s): 2015 zx6r
Airspeed and actual speed differ depending on wind speed/direction. GPS is required if you want to know where you actually are.
Insan3guy is offline   Reply With Quote
Old December 10th, 2014, 05:02 AM   #34
Ghostt
Ghostt's Avatar
Precisely my point.
ZX-2R BLOG
Help me find a gauge cluster InvisiBill General Motorcycling Discussion 13 February 9th, 2015 01:39 PM
08 Gauge cluster wanted devildogae Items Wanted 2 November 7th, 2012 12:43 AM
gauge cluster paopufruit 2008 - 2012 Ninja 250R Tech Talk 4 January 8th, 2012 05:33 PM
Serious delay in gauge cluster dtyndall 2008 - 2012 Ninja 250R Tech Talk 3 June 21st, 2010 06:14 PM
Loose Gauge Cluster? jonb08 1986 - 2007 Ninja 250R Tech Talk 8 April 13th, 2009 10:40 PM
