October 28th, 2011, 08:12 AM | #1 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
can't rev over 5K RPM
ok so i was in the proses of syncing my carbs and when i was warming up the bike around the block i cant pass over 5 i ordered a leo slip on has not arrived yet but i dont think just cuz i have the oem on will stop me from revving over 5 i have 0990 k&n
drilled slides crankcase breather 112.5 main jets 3 3mm washers under each needle idk do i need bigger jets? idono pls help
THE GOOD LIFE |
October 28th, 2011, 08:41 AM | #2 |
i thought the needle shims were 4mm washers, maybe that could be the issue
October 28th, 2011, 09:29 AM | #3 |
Join Date: Jun 2011 Motorcycle(s): 2010 Green SE Posts: 574
Newp, the 3 mm are the correct size for shimming.
October 28th, 2011, 09:40 AM | #4 |
cuz
more washers yea naw?
THE GOOD LIFE |
October 28th, 2011, 10:22 AM | #5 |
cuz
idk if it helps but the bike just finished a whole water bottle filled w/gas
THE GOOD LIFE |
October 28th, 2011, 10:42 AM | #6 |
Is the bike too rich? 112.5 mains seem big for use with an oem exhaust from what I can tell. Check out the jetting database for a point of reference:
http://www.ninjette.org/forums/showt...tting+database |
October 28th, 2011, 10:44 AM | #7 |
Join Date: Jul 2011 Motorcycle(s): 2009 Ninja 250R Posts: 86
112.5 main jets are pretty big, do you have the snorkel in? What kind of air filter, stock? Usually if you can't rev up high, it means you're running lean. But with 112.5 main jets and 3 washers under the needles, that seems unlikely. If anything, you're probably running way too rich. Try removing the snorkel if you haven't already, and report back. If it's revving better, then you're probably running too rich. In that case, you should try removing a washer from each needle.
PS: 3 washers is a little too much with a stock exhaust, people who put 3 washers under the needles usually have removed the airbox and installed pod filters or something like that (in addition to rejetting). I tried shimming my needles once, and put 2 washers under each needle, and my bike ran like garbage. This was because I had already rejetted the carbs. |
October 28th, 2011, 10:53 AM | #8 |
cuz
the airbox is delete i guess i wait till the slip on get here
THE GOOD LIFE |
October 28th, 2011, 11:04 AM | #9 |
cuz
for a second it started to puff out black smoke not a lot but enough to get me scared
THE GOOD LIFE |
October 28th, 2011, 11:11 AM | #10 | |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
Do you have a 110main to try? If you went through all the trouble of removing the air box, you might as well buy a full system exhaust honestly.
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
October 28th, 2011, 11:23 AM | #11 |
cuz
im hopeing that w/the slip on it will all work ill just turn it off till it gets here thanks guys
THE GOOD LIFE |
October 28th, 2011, 06:33 PM | #12 |
I'd recommend a full system... not a slip on. A slip on is basically just a muffler attached to the stock midpipe. The headers are stock. You would want a full system, like an Area P or Yoshimura, or a Leo Vince. The diameter of the pipes are larger, allowing more exhaust gasses to flow out. A slip on won't do much for you.
October 28th, 2011, 07:02 PM | #13 |
cuz
the leo slip on is on its way as we type lol ill update after i install it
THE GOOD LIFE |
November 3rd, 2011, 07:58 PM | #14 |
cuz
mna i still cant pass 5 even w/the slip on should i go down on the main jet or less on the washers?
THE GOOD LIFE |
November 3rd, 2011, 08:01 PM | #15 |
B-Town Ninja
Yeah, go down to 110 and see how it runs (if you have it). As others have said, slip ons don't do a hole lot in terms of changing air/fuel mixture. A lot of people are running 112.5 mains on bikes with full systems and getting proper mixtures so it's more than likely way too rich for stock headers.
If you have to order some, maybe get a variety in the range of 98-110 to save on shipping costs just in case.
November 3rd, 2011, 08:28 PM | #16 |
Join Date: Oct 2011 Motorcycle(s): ninja 250r, crf 50 Posts: 120
i would go smaller jet, and possibly 2 washers instead of 3.
November 3rd, 2011, 09:09 PM | #17 |
cuz
allright txs ill try tomato
THE GOOD LIFE |
November 3rd, 2011, 11:20 PM | #18 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
112.5 mains are really big while still sporting the stock exhaust, im running 110 mains, 40 pilots, and i think 3rd notch on the needle, and i have a full exhaust, K&N pod filter, Ported intake and exhaust ports, and bored up to 265cc.
if adjusting the shimms does not help, definitely go down to 108 while you still have the stock exhaust.
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
Just cleaned carbs - now stuttering at low RPM, fine at high RPM | Ohio | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 5th, 2014 10:30 PM |
RPM | OzzyDevil | General Motorcycling Discussion | 8 | April 24th, 2012 04:15 PM |
R6's RPM | Francis | General Motorcycling Discussion | 16 | January 23rd, 2011 04:41 PM |
Is 9000 rpm too much at 70? | austexjg | 2008 - 2012 Ninja 250R Tech Talk | 57 | October 2nd, 2010 12:16 PM |
she hesitates at 9k rpm | tinng321 | General Motorcycling Discussion | 8 | August 23rd, 2010 05:39 PM |
