March 6th, 2017, 05:29 AM | #1 |
Join Date: Mar 2017 Motorcycle(s): 2011 Ninja 250r Posts: 13
New owner with some issues
So as some of you know, I recently picked up a 2011 Kawasaki Ninja 250r that needs some repairs.
1. Bike cranks but does not start. 2. Will only crank with kickstand up and clutch in. 3. Will crank with kickstand up and clutch out (scared me when I tried that the first time lol) 4. Will not crank with kickstand down and with clutch in or out. 5. No neutral light/hard to find neutral. What could be my possible options as to why it won't start. I pulled and cleaned the carbs and found the jets were pretty gummed up. It feels like it wants to start, but when it gets to that point, it backfires a little sometimes. Any help would be appreciated. This will be my main mode of transportation til my car is finished. Thank you! Chris |
March 6th, 2017, 05:57 AM | #2 | |
It sounds like you have, at minimum, two separate issues. The first is an issue with one or more of the safety switches. Go here: http://faq.ninja250.org/wiki/Underst...afety_switches You've got a clutch safety switch, a gear safety switch, and a side stand safety switch. Correct behavior is as follows: A bike can be started: in neutral with the side stand down and the clutch out in neutral, with the side stand up and the clutch out in gear, with the side stand down and the clutch in in gear, with the side stand up and the clutch in Inspect all the switches and if you don't see anything amiss, get out your multimeter and see what's engaging when. Re failure to get the bike running, that can be any one of many things from old fuel to fouled plugs to clogged jets (due to old fuel) to you name it, even user error. There's no indication of your experience level, so it's remotely possible that you're unaware of correct choke operation. You're on the right track with what you've already done... maybe you didn't get all the gunk out of the carbs. Keep going over all the basics. Fuel, spark, air. Make sure the fuel is fresh, and if you don't know then drain the system including the carbs. Pull the plugs and inspect for fouling and proper gap. See if they fire when you ground them. Pull out the filter and clean it. You get the idea.
March 6th, 2017, 08:03 AM | #3 |
^ Do all of the above.
As noted, I think you may still need carb work, and if you haven't completely drained the fuel out and refilled with fresh it's not going to want to start. Can you confirm that it's going into neutral? It sounds like it may not be. |
March 6th, 2017, 08:05 AM | #4 |
Join Date: Feb 2016 Motorcycle(s): 2007 ninja 250, 14 ninja 300, 09 1125CR Posts: A lot.
MOTM - May '17
March 7th, 2017, 12:11 PM | #5 |
Welcome! I hope you find your problem so you can get out and ride!
March 7th, 2017, 05:10 PM | #6 |
Well I got the neutral thing figured out. When the guy dropped the bike off, it was in fifth gear... And now it will crank with the stand down. Simple enough...right... Well...went over a few other things and it all checked out. I tried starting again with fresh gas since the old was a pee water color (darker yellowish) and it got a little closer. My buddy asked me how the oil was and I said when I checked the other day it was fine. So I look anyway and I found in the window that it was no longer a nice golden brown...but more a caramel color. Checked the coolant and the level is good and still green. I drained the oil and filter and it had a slight fuel smell to it, not a coolant smell. Although visually it looks like a head gasket, I'm hoping its not. I did an oil change and let it drain for well over about 2 hours to get as much of what was in there out, checked the plugs and nothing out of the ordinary, changed the air filter. Still nothing. I'm hoping I don't have to pull the engine for a head gasket.....
Old oil Old gas Oil window after trying to start a few times... |
March 7th, 2017, 05:11 PM | #7 |
I know it sat, but I don't remember how long he said...
March 7th, 2017, 05:33 PM | #8 |
March 8th, 2017, 04:51 AM | #9 |
March 8th, 2017, 06:07 AM | #10 |
Join Date: Apr 2014 Motorcycle(s): 1978 Z1R, 1999 EX250 Posts: A lot.
MOTY - 2018, MOTM - Oct '16
I'm wondering if the oil has water in it from condensation, especially if it sat out where the temperature had wide swings. If it were mine I'd change the oil and the filter and have another go at it. Be sure to keep an eye on the oil and coolant until you know all is well.
March 8th, 2017, 06:59 AM | #11 | |
Seeing as how you let the oil drain quite a while when you changed it, I wouldn't expect any amount of contaminants to remain in the crankcase. I've just never seen fresh oil change to that color from just cranking an engine over. |
March 8th, 2017, 07:14 AM | #12 | |
MOTM - May '17
March 8th, 2017, 08:31 AM | #13 |
I wonder how it could have gotten that bad on a low-mileage bike. That's a heck of a lot of water to have come only from condensation.
Maybe at some point the previous owner forgot to put the fill plug back in and it got left out in the rain? Low miles does not guarantee that the engine hasn't been abused. If the previous owner thrashed it, failed to break it in properly or let it overheat, it's entirely possible that damage of some sort occurred. A blown head gasket (or even a warped head) is not out of the question even at low miles. Stick with the program... keep changing the oil until no further change occurs. You might also run some fuel treatment through it once you get it running (e.g. Seafoam, Techron, etc.) to better clear out the gunk that must be in the carbs. It's quite clear that water got into places where it should not be. I'd be mildly concerned about corrosion/pitting on the engine internals. While not terminal, that might possibly lead to somewhat shortened engine life.
March 8th, 2017, 08:58 AM | #14 |
Very likely this same condensation or water intrusion has created corrosion within the carbs...evidenced by the white powdery crap we've all seen. The modern ethanol fuels even accelerate the corrosive process!
More extensive, deeper carb cleaning may be required to enable startup ... and startup is critical to enable further diagnosis as to the integrity of the cooling system/head gasket. Both oil level and quality need to be monitored, putting some miles on to fully determine. This may be a poor storage issue (water contamination) ..or indeed a head gasket.
March 8th, 2017, 09:18 AM | #15 |
if I may add to the above....unprotected outdoor storage with unstabilized fuel (fully exposed to humidity/temp swings) ...is a sure death sentence to fuel tanks, petcocks and carburetors in particular. No secret our modern ethanol fuels are substandard....attracting moisture, meanwhile "dropping out" in periods as little as *weeks*.
I strongly suggest constant use of ethanol treatment/stabilizer for EVERYONE, every tankful...whether in storage or daily use.
March 9th, 2017, 04:33 PM | #16 |
Well I got some good news today! Pulled the plugs, cranked it to clear it out, drained the carbs, put it back together and it started up. Still some issues tho.
Choke on, it revs to about 8-9K rpm. Any throttle with choke off and it wants to shut off. Gets a little better the more it runs. Seems like the throttle hangs a little bit when I let off. Coolant tank bubbles when I shut it off. And there is a hose that comes off the carb assembly in the middle of the two. Is that supposed to be connected to anything? When I plug it with my thumb, the rpms go up. Still a want to shut off every once in a while but not nearly as bad. |
UK owner | andys | New Members | 9 | February 12th, 2017 07:10 AM |
Soon to be owner!(hopefully!!) in PA | Zdolak90 | New Members | 43 | May 21st, 2014 04:06 AM |
New Owner | xxjarrodxx | New Members | 9 | October 17th, 2012 11:13 AM |
New 250R Owner... AGAIN! | 2011Ninja250R | New Members | 15 | July 28th, 2011 01:30 AM |
New owner from NJ! | Togglehead | New Members | 9 | June 15th, 2010 05:22 PM |
