Old December 19th, 2018, 01:40 PM   #1
dodgerdad
dodgerdad's Avatar
Petcock Rebuild?
I recently replaced my petcock with a new OEM unit and figured I would clean up and rebuild my old one as a little inexpensive project & to have a spare.
I ordered one of the parts and when I went to store them with the old unit I found the screens were badly damaged. Apparently I must have manhandled them at some point after removal.
From what I've seen, there is no part number listed for them, not to mention it doesn't look like they were made to be replaced. My question is should I remove what's left of them, rebuild the unit and use it without the screens?
My tank is squeaky clean so I can't imagine the petcock getting clogged up (and I have a fuel filter after the tank to ensure the carbs get clean fuel).
Not sure if I should order the remaining parts for a rebuild, or toss it out. Thought/opinions?
Old December 19th, 2018, 03:22 PM   #2
ducatiman
ducatiman's Avatar
IMHO.....for 8 or 9 bucks on ebay are the non-vacuum type cheapos with screens, good enough for an emergency spare. (note they should be turned to OFF for overnight or extended parking)
Up to you to keep your oldie for parts (just in case)
Note new OEM petcocks are around $75...a spare part from the oldie may just salvage and save that in the future.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
rebuild help! tap_rack_bacon 2008 - 2012 Ninja 250R Tech Talk 1 May 31st, 2017 07:51 PM
The Re-Rebuild... mr2peak 1986 - 2007 Ninja 250R Tech Talk 7 April 11th, 2016 07:11 PM
Vacuum nipple came off petcock - fix or replace petcock? fierostetz 1986 - 2007 Ninja 250R Tech Talk 3 November 24th, 2012 11:03 AM
