#1 |
Join Date: May 2013 Motorcycle(s): 08 Ninja 250 Posts: 121
Bike bogging when giving it throttle
My bike runs like crap when giving it throttle. When you try to give it throttle, the engine seems to bog down and struggle. From this point, if you give it more gas, it stalls. Holding it at that same amount of throttle will sometimes eventually stall it. You can't really get up in the rpms at all. With the choke fully on, it climbs up through the rpms. It doesn't rev, but it slowly climbs up.
I've changed the plugs, ran it without the air filter, and tried Seafoam, all with the same problem. I upped the idle which seemed to help, but it's still not fixed (when I raised the idle and cranked the throttle, the rpms seemed to hang a bit, but maybe I used too much Seafoam? Doesn't seafoam lean it out?). I drained all of the fuel and pulled the carbs, and they actually looked really clean. I put it back together and put a little bit of fuel in it and had the same issue. I turned it off and when I opened the gas cap, the bike make a hissing noise like it was either releasing pressure or sucking in air. I closed it back and retried it and the bike seemed much better. Not 100%, but way better than before. I tried it again the next day, and got the same thing. Ran like crap with throttle, opened cap, hissed, then ran much better.. Could this be a fuel tank venting or gas cap issue? |
#2 | |
#3 |
Join Date: Nov 2010 Motorcycle(s): 2009 Ninja 250R Posts: 194
I have the same issues during summer. What i do is i open and close the gas cap every time before i start the bike up. Been working for the past year or so.
#4 |
Sounds like you have some sort of fuel (not getting enough) or vac issue.
I need to get up there to help you out. Been racing the past 2 weekends and will be racing again in two weeks. Lemme check my schedule with your pm and let you know.
#5 | |
Ok.. I know I'm off Thursday and Friday.. not sure about nxt week. They don't post out schedule till Fridays.. should be able to.request days off thought.. |
#6 |
Let's shoot for Friday.
#7 | |
![]() Quote:
In the meantime, keeping the cap closed, pull the gas hose out of the carbs' connector and measure how much fuel if flowing down. At any time you should have at least 2 cc per second. If you do, then you will need to verify that the float valves are open, by draining the bowls. If the problem persists, then, you need to verify the operation of the diaphragms and needles.
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#8 |
Thanks but I think expert is a pretty strong word. lol
#9 |
If you are not an expert, who is?
#10 |
Alright! Sounds like a plan! Here's some vids I made earlier: https://www.youtube.com/watch?v=GhHB...e_gdata_player
https://www.youtube.com/watch?v=vx6t...e_gdata_player Those were earlier.. I let it run for a while and eventually I heard a long beeping sound coming from the tank... Seemed better after that. |
#11 |
Do you use the choke and let the bike warm up before cranking on the throttle?
Has the bike been sitting out in the rain a while? Also your gas cap looks like crap. Cleaning that up may help with your venting, there's a couple of little holes around the lock that vent the air. |
#12 |
Whoa! Definitely NOT venting. Clean that as much as possible.
What time on Friday? And pm me your addy please.
#13 |
You said you pulled the carbs, did you clean them out and drain the bowls? Seafoam may not have done the job. I had this exact problem.
#14 | ||
I drained the bowls and shot some carb cleaner through the visable holes.. looked really clean... I.didn't go.beyond the.bowls though! |
#15 | |
Pull the carbs and have them out for when I get there. We will clean them (jets and all) and put em back in. I will bring the guitar string if you have the carb cleaner ready.
#16 | |
#17 |
Nice meeting you today Darryl. Let me know how everything goes.
#18 | |
![]() Quote:
#19 |
Yep she runs just fine. Needs a new air filter and to bleed the rear brake but after that it's ready to go.
#20 | |
![]() Quote:
#21 |
#22 |
For completeness and to bring closer to the problem in the OP;
Visual check of all vac lines We cleaned the carbs Drilled caps off mix screws, one was 1 turn out, the other was 2 1/4 turns out. WTF! ![]() I pulled some goo out of one of the gas cap vent holes, ensured they both were clear While I was in the areas, I also checked; Rear and front brake pads and calipers Controls and cables Shift lever and linkage Tires Engine mount bolts Stem bolt Clip on's - one was loose ![]() Various other little things that are to much to list General wiring looked to be in good working order I also adjusted his rear shock to position 3. Overall the bike was clean, just a victim of to much dormant time in a garage from the previous owner. With a little bit more TLC, it will make a fine riding bike.
#23 |
#24 |
Stuck at the gas station. Dies when giving throttle | spc2125 | 1986 - 2007 Ninja 250R Tech Talk | 29 | May 19th, 2016 08:23 PM |
Full throttle kills bike, throttle lag response. | Diegone | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 30th, 2014 03:25 AM |
bike dies when giving it throttle | RED_09 | 2008 - 2012 Ninja 250R Tech Talk | 8 | December 16th, 2012 04:51 PM |
[twisted throttle] - Triumph Tiger 800XC 2011 - Twisted Throttle Demo Bike | Ninjette Newsbot | Motorcycling News | 0 | September 22nd, 2011 01:40 PM |
My New (used bike) is already giving me trouble.. HELP | venmichaels | 2008 - 2012 Ninja 250R Tech Talk | 26 | July 2nd, 2011 07:25 AM |
