May 1st, 2013, 11:11 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 2006 ninja 250 Posts: 21
motorcycle + motorcycle = car
I was daydreaming and came up with a really cool idea. It might not be possible with a pregen ninja but the newgen 250 has points to mount frame sliders so WHAT IF you get a team of engineers/ whatever to combine the 2 bikes together, get really long cables for the brakes and combines them with a 2 into 1 box. then mechanically combine the shifting using just a long welded piece connecting them together, design a basic rack and pinion steering or whatever it is called to combine steering from both bikes. you would not need a differeial because the wheels are separate.....you would get a ****ing car! you can have 1 person on each bike simultneuously helping to steer , one person does half the other the other half...or make a seat in the middle and 1 person does it all. has this been done? maybe. if not whoever does this I want credit and money for the idea. officer's would say can I see your ID and registrations...?
May 1st, 2013, 11:19 PM | #2 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
.......You should day dream about something else and let others day dream about making cars.
.......like all of the engineers....who make cars. <3
CVMA #531 |
May 2nd, 2013, 01:00 AM | #3 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250(Totaled) Posts: 984
Don't quite your job to persue this....
"I am a creationist, I believe man created god." |
May 2nd, 2013, 01:50 AM | #4 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
Soooooo.... What weed are you smoking again?
May 2nd, 2013, 03:40 AM | #5 |
no it could work. theres lots of welders who have the skill to make the frame to combine these together. the rest is basic mechanics. do I sound crazy, yes. is it possible, extremely. a car is safe because it has 4 wheels, but its boring. a t-rex is cool but it cost too much. If I saw a 2 motorcycle car I would definately ride it.
May 2nd, 2013, 04:55 AM | #7 |
Join Date: Mar 2011 Motorcycle(s): 2007 ninja 250r Posts: 374
You guys are a bunch of haters.
Dreamers built this country. I say if you have the time and money do it. |
May 2nd, 2013, 06:09 AM | #8 |
Join Date: Oct 2012 Motorcycle(s): 2012 red 250 ninja Posts: 740
Let me explain why it's a bad idea.
You hit on it yourself, you don't have a differential, because they are separate. Even if you can manage to link the throttles, the engines will be slightly different, and the power response will be slightly different, so that the two bikes will constantly be trying to move at different speeds. Without creating a differential, and then either using one engine between the two bikes or some sort of double differential where both engines power it and both wheels are powered equally by it, it simply would not work properly. |
May 2nd, 2013, 06:14 AM | #9 | |
May 2nd, 2013, 06:16 AM | #10 | |
May 2nd, 2013, 06:24 AM | #11 | |
It may have been done, but that doesn't mean it will work properly, or that it should be done. |
May 2nd, 2013, 06:29 AM | #12 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
The flying version.
May 2nd, 2013, 07:16 AM | #13 | |
Join Date: Mar 2012 Motorcycle(s): 2008 Ninja 250R Posts: 257
On another note, i agree. With time and money, just about anything can be done. I.E. My father is building a trike in his garage. Started out as a 1969 Corvair rebuild project. 13 years later, he decided to scrap the frame and keep the mechanics. For the past 5 years now he's been slowing building the trike. Welding the frame and everything. Gas tank made from a slightly modified propane tank. Piece by piece. Time and money. That's all it takes. Oh yeah, one last thing. The body of it, is a coffin I know. A USED coffin i may add lol Anyways... |
May 2nd, 2013, 09:23 AM | #14 |
Most large airplanes have multiple engines. They also have the ability to adjust the air fuel mixture on the go. More importantly, they can adjust for the engines putting out slightly different amounts of thrust with the rudder, and it doesn't involve eating up your tires.
Last futzed with by ChaoSS; May 2nd, 2013 at 09:32 AM. Reason: Apparently can't type and, well, think concurrently. |
May 2nd, 2013, 09:47 AM | #15 |
not an actual panda
The original.
May 2nd, 2013, 09:51 AM | #16 |
Join Date: Dec 2012 Motorcycle(s): 2008 Ninja 250R Posts: 263
Dude. Go for it
May 2nd, 2013, 12:49 PM | #17 | |
http://www.ninjette.org/forums/showp...93&postcount=4
May 2nd, 2013, 02:16 PM | #18 |
just build it with links at the controls so only one person controls the vehicle.
then build links where both bikes lean into corners, and a computer controls the traction so the outer motorcycle is slightly faster. then i would put a dummy on one side to freak people out.
May 2nd, 2013, 02:46 PM | #19 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
May 2nd, 2013, 02:50 PM | #20 | |
May 2nd, 2013, 02:56 PM | #21 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Motorcycle + basket and wheel and seat and fairing = sidecar
May 2nd, 2013, 08:32 PM | #22 |
Join Date: May 2012 Motorcycle(s): 2008 Ninja 250r Posts: 225
I see what you are getting at but wouldn't that ruin the whole point of a motorcycle? You wouldn't have the agility of a bike which I think is the whole point. I just wouldn't feel free on a machine that has two people controlling it.
May 2nd, 2013, 09:18 PM | #23 |
heh, I was going to make a joke about that but it's probably too harsh, it was going to be a marriage joke. anyways yeah I'm trying to change out some motorcycyl tires and I bought all this gear and been working too hard on it. 2 motorcycles, what was I thinking. my next idea is a gearbox with 9 or 12 speeds, that might catch on....
May 3rd, 2013, 05:24 AM | #24 |
The poor thing will roll over before you could ever drift it.
There is reason for sport cars to be low and wide, with the driver and passenger's butts two inches above the ground. Going fast on a straight line you will be able to do, if you reduce the diameter of both rear sprockets about half. Since each engine will feel about the same load as when they were pushing a single Ninjette, you will not need more steps in the gear boxes, but you will need to synchronize the shifting of both boxes perfectly. Your cool project is as interesting as complicated.
May 3rd, 2013, 06:02 AM | #25 |
Join Date: Aug 2012 Motorcycle(s): 2010 ninja 250R SE Posts: 97
put the 250 motor into a gokart.
May 4th, 2013, 03:16 PM | #26 |
I think I've found the website for you:
http://highdeas.com/ Until someone makes your idea a reality, I think I'll just stick with a traditional bike that leans |
May 4th, 2013, 07:39 PM | #27 | |
Join Date: Apr 2012 Motorcycle(s): 650r 2009 Vulcan 800 2005 Posts: 557
I have promised myself though that if I ever wreck my bike, I'll turn it into a fully enclosed aerodynamic stretched bike with "landing gear" I am serious about that part....
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there. |
[motorcycle.com] - Weekend Awesome – Motorcycle vs. Car, the Lego Edition | Ninjette Newsbot | Motorcycling News | 0 | January 31st, 2015 07:21 AM |
[motorcycle.com] - Duke’s Den – Motorcycle Riding vs. Car Driving | Ninjette Newsbot | Motorcycling News | 0 | April 7th, 2014 05:30 PM |
Motorcycle tailgating car... best way to deal with it? | Soujyu | General Motorcycling Discussion | 58 | January 24th, 2014 09:15 AM |
Car takes down a motorcycle and runs | JELY1990 | Videos | 33 | June 23rd, 2013 07:11 AM |
Motorcycle cop hit by car | MiniCog | General Motorcycling Discussion | 15 | March 17th, 2011 09:35 AM |
