Old July 27th, 2012, 12:09 PM   #1
offrdjeep87
offrdjeep87's Avatar
Motorcycle(s): 2009 Ninja 250
Opinions on turn signal mounting
I bought my 250 used with a fender eliminator kit already installed. I didn't like how the PO had the turn signals mounted so I made up different brackets for them. However, I can mount them two ways. This is where i need your opinions.
The first way:
If i flip the brackets 180 degrees:
I think I like the second way because it tucks them in tighter under the tail. My only concern with it is that they will be too close together and may be a safety issue. Thoughts?
(PS - those pictures are just a mock up. The brackets will be painted and i know everything is all crooked )
offrdjeep87 is offline   Reply With Quote
Old July 27th, 2012, 12:29 PM   #2
DARAM1281
DARAM1281's Avatar
Motorcycle(s): 2012 NINJA 250R
some states require a certain distance between the signals might wanna check before you mount them. call up your local DMV
DARAM1281 is offline   Reply With Quote
Old July 27th, 2012, 12:58 PM   #3
The difference is so small I can't tell much difference either way. Rock what you like that is legal.
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
Looking for pregen left front turn signal and mounting parts tanghonglai Items Wanted 3 August 4th, 2013 04:44 PM
Turn Signal issue, looking for opinions ArsnlTim 2008 - 2012 Ninja 250R Tech Talk 14 August 2nd, 2013 02:47 PM
Turn signal mounting plate replacing...HELP rph12 1986 - 2007 Ninja 250R Tech Talk 5 March 8th, 2012 09:48 PM
mounting turn signals bhalv 1986 - 2007 Ninja 250R Farkles 4 October 14th, 2010 01:15 PM
