December 3rd, 2013, 05:42 AM | #1 |
Join Date: Oct 2013 Motorcycle(s): '76 Yamaha RD400, '71 Kawasaki G3SS, '88 Honda CBR400RR, '90 Yamaha FZR400/600 hybrid Posts: 138
Replacing Chain and Sprockets
Sooooo, I'm back with more questions. After a few hundred miles of care free riding I started having more issues. I knew I needed to tighten the chain but last week I started hearing a sort of slapping/clacking noise coming from the area of the chain/sprockets. Specifically the front sprocket. After some inspection it appeared as if the chain was slapping the swingarm.
I cleaned, lubed and tensioned the chain. Slightly better but still a lot of noise at the front sprocket. Then I saw that the chain was tight in some spots and too loose in others as it when around. So Im prepared to buy and replace the chain and both sprockets. I'm planning on going with a 15 tooth front as most of my riding is on the freeway. I think the bike had been outside a lot of it's life and the chain prolly wasn't properly cared for. The chain and sprockets have 9,000 mi. on them. My question is this: should I go ahead and replace the sprocket bearings while I'm in there? I don't want to get this finished and still have the same noise, it seems very unsafe to ride right now. Thanks in advance!
"When in doubt, gas it!" |
December 3rd, 2013, 05:56 AM | #2 | |
The only bearing that is accessible to you is the one that holds the rear sprocket. That one needs moly grease and inspection for checking any excessive wear.
December 3rd, 2013, 07:38 AM | #3 |
Ok cool, thanks for the help. I'll probably get to doing it this weekend. I've heard a few different things about chain types. Some people have told me to avoid the clip-type like the plague. I'd rather not have to spend a bunch of money right now on the riveting tool. What do you use?
December 3rd, 2013, 07:41 AM | #4 |
The KY master key of wrenches, vice grips. They are like the duct tape of tools. lol
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; December 3rd, 2013 at 09:37 AM. |
December 3rd, 2013, 08:15 AM | #5 |
Join Date: Sep 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R, 2008 Suzuki GSX-R600, 2006 Suzuki GSX-R600 Posts: 31
If you plan on owning and working on bikes for a while (e.g. years), then the cost of the riveting tool might make sense in the long run.
December 3rd, 2013, 10:12 AM | #6 | |
I rivet the chain outside with a hammer, since I service the swingarm pivot each time that I replace a chain. I like this idea, brought to this fine forum by @csmith12 some time ago, as I have seen several clips from clip style master links work their way out in O-ring chains, never in a regular chain: I would safety wire the link.
December 7th, 2013, 05:40 AM | #7 |
I saw some posts somewhere about having to cut some links off. I got a 106 chain, I shouldn't have to cut it right?
December 7th, 2013, 09:00 AM | #8 |
Nope, not for stock sized sprockets or a few sizes above/below.
December 7th, 2013, 10:59 AM | #9 |
Ok cool. I' getting ready to do this. I'm pretty slim on the cash right now and I don't have a torque wrench. I imagine it's pretty critical to have the sprockets torqued down right?
December 7th, 2013, 11:19 AM | #10 | |
It's normally bad news if any of that stuff comes off.
December 7th, 2013, 12:10 PM | #11 |
Join Date: Jan 2013 Motorcycle(s): 2009 Ninja 250R Posts: 206
December 7th, 2013, 12:11 PM | #12 |
Yes sir, that is the gearing I run.
December 7th, 2013, 12:21 PM | #13 |
That's what I'm switching to. I'll actually be glad when my chain/sprockets wear out.
Will be interesting to see what a difference it makes after riding ~20,000 miles with the stock gearing. |
December 7th, 2013, 02:13 PM | #14 | |
Fighting Texas Aggie '05
December 7th, 2013, 02:28 PM | #15 |
i use a $10 chain breaker/riveter from harbor freight. it breaks, rivets, and only costs $10.
December 7th, 2013, 02:30 PM | #16 |
i use clip masters for the race bike. i safetywire the clip shut. as long as its safetywired or ziptied (i have used zipties before for several thousand miles with no issue) it wont come off. i have had clips come off that were not safetywired. always safetywire or ziptie a clip master.
December 9th, 2013, 07:01 AM | #17 |
So after a lot of work I got the chain and sprockets replaced yesterday. I'm liking the 15 tooth front sprocket a lot. Now I'm hearing a noise on deceleration. It had started happening about the time the chain started slapping. It's only when I come off the freeway and slowing down, normally on the off ramp. Didn't happen last night but always seems to happen going to or from work. I don't think it's gear whine. It sounds almost like a pump is struggling. It doesn't whine at a consistent pitch either, it vacillates a bit higher and lower. By the time I reach the end of the ramp it's normally stopped. Any ideas?
Questions about Replacing Chain/Sprockets | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 29th, 2015 06:44 PM |
new chain and sprockets | yogurtpooh | 2008 - 2012 Ninja 250R Tech Talk | 11 | January 31st, 2015 02:11 PM |
replacing chain and sprockets | skip | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 24th, 2014 11:47 AM |
Chain/Sprockets | Lil_Green_Demon | 2008 - 2012 Ninja 250R Tech Talk | 1 | September 9th, 2012 04:40 PM |
replacing chain... sprockets? | alex.s | General Motorcycling Discussion | 16 | August 29th, 2011 05:04 PM |
