Old June 12th, 2020, 10:48 PM   #1
Ace54321
Motorcycle(s): Kawasaki ninja 400 2019
Revs
If the revs are to high on a bike can it cause it to overheat ?
Ace54321 is offline   Reply With Quote
Old June 12th, 2020, 11:12 PM   #2
Ace54321! Glad to have you aboard...
Old June 13th, 2020, 08:27 AM   #3
No, not really. Tell us more of the story.
And welcome to the board!
The location in your profile is intended as a general one, so you might want to remove your street address.
Old June 13th, 2020, 03:15 PM   #4
Not likely revs will cause overheating. If your bike is overheating, inspect:
1. fan thermoswitch and fan. Sit next to bike and let it idle to warm up and does fan turn on when it starts to overheat? Measure all fuses
2. thermostat. Test in pot of water being heated to boiling. Does thermostat open at proper temperature (listed in manual).
3. radiator and coolant. When was last time coolant was flushed out and replaced?
Old June 14th, 2020, 08:17 PM   #5
Kowalski
Kowalski's Avatar
Motorcycle(s): 2014 Ninja 300
Is your bike really overheating or are you just watching the temp gauge climb as you rev the engine? Higher revs will create more heat and amplify any problems in the cooling system. High revs alone shouldn’t be an issue unless you’re WOT hanging in on limiter for a while.
Kowalski is offline   Reply With Quote
Old November 9th, 2020, 06:34 PM   #6
Snake
Snake's Avatar
I’m a little late but ....hello and welcome !
Difficulties on revs Darksik 2008 - 2012 Ninja 250R Tech Talk 2 December 30th, 2018 04:24 PM
Misfiring at low revs sh123469 1986 - 2007 Ninja 250R Tech Talk 17 August 16th, 2015 10:37 AM
All of a sudden the revs were all over the place.... peterpayne 1986 - 2007 Ninja 250R Tech Talk 3 April 2nd, 2014 01:03 PM
High revs tehcarguy 2008 - 2012 Ninja 250R Tech Talk 11 July 16th, 2012 04:57 AM
High revs at stand still? beninja 2008 - 2012 Ninja 250R Tech Talk 15 June 22nd, 2012 08:23 PM
