Old November 7th, 2015, 07:38 PM   #1
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Misconceptions of Suspension
Just read this article, brought up some interesting points.
10 Misconceptions
TEAM ALFALFA
www.apexassassins.com
Old November 10th, 2015, 06:11 PM   #2
That is a pretty good read.
Old November 10th, 2015, 07:15 PM   #3
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Nice find
http://www.sportbikes4hire.com
Old November 10th, 2015, 11:35 PM   #4
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
So no fork oil change this winter... Yééééé...
What I'm going to do with this free time now...
broken neck is offline   Reply With Quote
Old November 11th, 2015, 06:17 AM   #5
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ oil still gets dirty, get it done!
Old November 11th, 2015, 06:25 AM   #6
TnNinjaGirl
Ms. Personality
I was slightly curious about this. I've pulled forks apart that had black fluid and smelled horrible. The new fluid was clear and smelled less horrible...
I don't think I've ever pulled a set of forks apart and noticed that the fluid was visually good. It's all been pretty nasty.
So what's the difference between what he's seeing and what I'm seeing?
Old November 11th, 2015, 07:53 AM   #7
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Could it be that it's because the article mentioned a shock, not forks?
I can't think of any valid reason why one would be different from the other, though.
Old November 11th, 2015, 07:59 AM   #8
TnNinjaGirl
Ms. Personality
Good point but also good point
Old November 11th, 2015, 08:02 AM   #9
adouglas
adouglas's Avatar
Also... didn't say whether the oil in that shock was synthetic or dino.
Do they even make synthetic shock/fork oil?
Old November 11th, 2015, 08:06 AM   #10
TnNinjaGirl
Ms. Personality
Yes they make synthetic. I'm not sure if they made it 14 years ago.
Old November 11th, 2015, 08:22 AM   #11
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I feel like there should be an * to #8
They say "A well setup race bike suspension will be to stiff for the street"
key words being Well setup race bike
What does that even mean? What it doesn't mean is your run of the mill N250 or other non SS or SB with a budget suspension.
bikes with budget suspensions don't have the complex inner workings that the more expensive SS and SB's have, so what they say is true. A well setup race bike will be fine for the street but only because it has several levels to the suspension both front and rear that work precisely in conjunction with each other from early in the stroke through the mid and deep into the stroke at different speeds of compression ect... That is not true for all bikes.
Old November 11th, 2015, 08:41 AM   #12
TnNinjaGirl
Ms. Personality
I think I know what he means but I think he worded it poorly.
If you take a run of the mill CBR600rr with stock suspension but tune it for the track. IE springs, compression/rebound settings, etc... it WILL be stiffer than a street bike.
The track is smoother and one is traveling at higher speeds so the springs can be stiffer, etc, etc...
A bike set up for street is designed to be more forgiving because of the lower speeds and rough pavement/bumps.
Old November 11th, 2015, 09:03 AM   #13
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
Concerning fluid - if it stays clean, there is no reason to change it out. I've re-used fork oil many times rebuilding various healthy forks, however, as soon as a seal fails, be it an end-seal or the tube seals, that oil becomes contaminated and needs to be purified. The oil itself won't break down, and were we able to purify it locally and re-use it it would be fine, but our only option is to switch it out.
Shocks are more resilient because they are typically less exposed to the elements. Forks get beaten up every time the bike goes out for a ride. Rubber breaks down, bad things get in there...
Old November 11th, 2015, 09:20 AM   #14
bdavison
Wartown, USA
bdavison's Avatar
Here's another good read.
Suspension 101 - How to setup your suspension
Old November 11th, 2015, 09:45 AM   #15
I like it when riders start to understand the suspension bits underneath them. It answers sooooooo many questions that come up.
Old November 26th, 2015, 04:09 PM   #16
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
The track is smoother?
Not in Texas, well except for COTA
Last futzed with by GregS; November 27th, 2015 at 10:08 AM.
GregS is offline   Reply With Quote
Old December 5th, 2015, 09:45 PM   #17
NDspd
1/4 English, 3/4 Kick Ass
NDspd's Avatar
Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold)
Nice little read
NDspd is offline   Reply With Quote
Old December 8th, 2015, 07:08 PM   #18
mgentz
Board Member
10 Misconceptions
Ed did my suspension. He is awesome and very helpful.
[motorcycle.com] - Top 10 Misconceptions about Motorcycle Suspension Ninjette Newsbot Motorcycling News 0 November 5th, 2015 06:21 PM
[motorcyclistonline] - Making Sense Of Suspension: ELECTRONIC SUSPENSION Ninjette Newsbot Motorcycling News 0 August 4th, 2015 11:50 AM
[motorcycle.com] - K-Tech Suspension Announces Classic Custom Suspension Ninjette Newsbot Motorcycling News 0 January 7th, 2015 09:40 PM
[roadracingworld.com] - JRi Shocks And GP Suspension Team Up To Offer Suspension Pack Ninjette Newsbot Motorcycling News 0 November 14th, 2012 01:40 PM
[roadracingworld.com] - STM Suspension Holding Suspension Seminar June 25 In Colorado Ninjette Newsbot Motorcycling News 0 June 21st, 2011 10:10 AM
