#1 |
Join Date: Feb 2013 Motorcycle(s): 05 F4i.... Posts: 242
Do cruiser riders throttle blip?
I always wonder that... for some of you on here who ride cruisers, do you throttle blip when downshifting?
#2 |
I came from cruizers. Generally... I didn't and neither did most of the other riders. I ran with an older crowd though. Most of the riders were 50+. Seems most of the revs were at the stops for "sh*ts and giggles".
#3 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
They should. Anything with a manual transmission, I would assume, would benefit from it unless it's some super high-tech machine.
#4 |
Ride a Harley and you will see, downshifting is useless, with belt drive. Feels like a go cart to me
#5 |
Jigglin' your Jiglets
MOTM - Apr '13
How is a belt different from a chain? I can't imagine its that different feeling
If the Ninja 250 doesn't have enough power for you, then you don't know how to ride it. AFM #676 ![]() Supersports are for n00bs |
#6 |
It's even worst with shaft drive bikes. Very ridged when no smooth.
#7 |
All about slack yo, belts don't have any. The slop in the chain can work to your advantage here. It's subtle, but there. Think about where the torque is on an HD vs the 250.
#8 | |
MOTM - Apr '13
#9 | |
I'm still lost on why down shifting is useless? |
#10 |
Join Date: Oct 2012 Motorcycle(s): 2012 red 250 ninja Posts: 740
It's not useless, and I ride a shaft and a chain. (yes, I phrased it that way on purpose)
![]() As has been said, every vehicle with a manual transmission benefits from matching engine speed to road speed when you shift gears. Now, there are two reasons to rev match, and cruisers only really see one of those reasons. On a sport bike, or really, any high rpm vehicle, when you downshift and the rpms go up high, it can cause the back wheel to lose traction as it tries to speed up the engine. This is not such an issue with lower rpm motors, as it takes less to bring the engine up to speed when it's a lower speed. However, rpm matching will save your clutch, and this applies to every vehicle out there with a standard transmission. (expect nonsynchronized transmissions like trucks, which have to be manually synchronized or they won't shift at all). |
#11 | |
Some shaft driven bikes (honda shadow) have really nice and soft cush drives. When I road a shadow back in 1987, I didn't even know what blipping was, much less do it.
#12 | |
![]() ![]() ![]() I don't know if all have wet clutch now, but before 1984, many had dry clutch, which also helped isolating engine form transmission completely. Bigger parts with more inertia also help the engine keeping steady rpms' for longer after the throttle is closed for shifting. Being engines designed for comfort, the transmission may have some kind of synchronizing mechanisms, just like cars with manual transmission have had since the 1950's...........I don't know for sure. I will ask my HD neighbor when I see him.
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#13 |
Join Date: Mar 2012 Motorcycle(s): 2003 Honda Shadow, 2008 ninja 250 Posts: 237
I blip the throttle on my shadow. Maybe its because im coming from the sport bike world but I ride the shadow the same way I ride my ninja, like I stole it
#14 | |
I really know nothing about engines, so my assumption is based on observations. |
#15 | |
I know all our cars that are manuals still require either time in the friction zone or a blip on downshifts. They don't rev match for you like the F1 cars. |
#16 | |
http://auto.howstuffworks.com/transmission4.htm The real thing looks like this: http://www.motorera.com/dictionary/p...ynchromesh.jpg
#17 | |
Basically, in a non-synchronized transmission, you push in the clutch, put it into neutral, and then wait for the rpms to fall, or blip the accelerator, depending on if it's an upshift or a downshift, and when the rpms match, you push the clutch back in and engage in gear. You can do it without the clutch, if you time it right. With a synchronized transmission, you push in the clutch, then put it in neutral. Instead of waiting for the RPMS to match, you simply put it in the gear you want, and then release the clutch. If you match the rpms, or come close, then the clutch doesn't need to do much. If you don't, the clutch does the work of rpm matching for you, although like you said, it takes a little time in the friction zone to accomplish this. Think about what happens in the transmission. When the clutch is engaged, the input shaft and the engine are spinning at the same speed. The output shaft is coupled to the driveline, or axles, or whatever, depending on the drive configuration. When you switch gears, the input and output shafts are not moving at the correct ratio for the gear you want to be in, because they are moving at the ratio for the gear you are in. In order to do that, you can either blip the throttle, with the clutch engaged (by this I mean your foot off the pedal), or you can use synchros. All bikes must have synchros, because you can't shift to neutral between gears. Blipping the throttle with the clutch engaged on a non synchro transmission does somethin different for you that doing so with the clutch disengaged on a synchro tranny. Here's hoping that this made a little bit of sense, and that you don't still have me blocked. ![]() |
#18 |
will never be a ninja
Join Date: Aug 2012 Motorcycle(s): 1996 Suzuki GSXR 750 SRAD Posts: 38
Well after reading this I have started playing with throttle bliping and I must say it actually smooths down the downshifting on my vulcan, but im sure that has more to do with the fact thag it actually have the ninja 500r motor and tranny in the frame instead of a v-twin
#19 | |
#20 |
from what i've seen it depends on the skill of the biker... if they ride lots of bikes, they blip. if they just ride their harley on saturdays to the coffee shop, they don't blip for downshifts, but they still sit there blipping their engine at stop lights. i dont think they know what the blip is for.
also, when i rode a harley i blipped. seemed natural. was a lot harder since the revs fell so quickly but i got used to it fast
Undeniable proof that sportbike riders are smarter that cruiser riders | Sigma.40 | General Motorcycling Discussion | 80 | March 22nd, 2014 04:41 AM |
[crash.net - MotoGP] - Bradl optimistic Jerez just a blip | Ninjette Newsbot | Motorcycling News | 0 | May 7th, 2013 06:50 AM |
[roadracingworld.com] - Pro-Shiftâ??s Bump & Blip Shifter | Ninjette Newsbot | Motorcycling News | 0 | March 4th, 2013 08:50 PM |
Throttle Blip and Bigger Bikes | 47ninja | Riding Skills | 3 | July 23rd, 2012 06:50 PM |
Needing blip on startup. | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 34 | March 28th, 2011 10:52 AM |
