June 5th, 2020, 03:44 PM | #1 |
Join Date: Jun 2020 Motorcycle(s): 03 ninja 250 Posts: 14
Starting/idle issue
New poster here. I have an 03 bike with a 12 motor(allegedly). I have been waiting for the plate to come from my closed dmv, it came today and I suited up for a ride. Wouldn’t start, I put plugs in because I didn’t know their history. Now it will only start with choke off, throttle wide open and petcock to off. Won’t idle either. Everything is stock with carbs and airbox. And I seem to be getting a fair amount of gas from overflow hose onto ground. Help please. Thanks
June 5th, 2020, 04:00 PM | #2 |
sure sounds like a runaway float valve, a carb pull in your future
June 5th, 2020, 05:04 PM | #3 |
Any chance that riding it might “loosen” things up? Bike has not been ridden in while, just started occasionally.
June 5th, 2020, 05:11 PM | #4 |
Not a chance. You have multiple issues. Such as dried rubber seals in petcock and carbs. With additional time, they will just dry up more and leak more. Usage won't matter. Same with clogged passageways in carbs. They will continue to accumulate more debris and dried petrol and get worse. Only fix is complete disassembly of carbs down to ever last individual components and thoroughly clean & scrub them to restore back to factory-fresh clean state.
Last futzed with by DannoXYZ; June 6th, 2020 at 04:16 AM. |
June 5th, 2020, 05:13 PM | #5 |
Marvelous, I guess I know what tomorrow brings..
June 5th, 2020, 06:40 PM | #6 |
Here's latest illustrated guide to get you started:
https://www.ninjette.org/forums/show...87#post1267487 |
June 5th, 2020, 10:40 PM | #7 |
Join Date: Jun 2017 Motorcycle(s): '09 Ninja 250R Posts: 180
Question - if someone is running their bike daily, using fuel stabilizer with their gas, how often do you recommend rebuilding/cleaning the 250 carbs? Not sure how often as there's no set maintanence schedule on em.
June 6th, 2020, 04:22 AM | #8 |
You'll want to plan ahead a bit. Get necessary equipment and supplies. Scrub brushes, ultrasonic cleaner, micro soda-blaster, etc.
Here's rebuild-kit for petcock: https://www.ebay.com/itm/312734032287 Rebuild-kit for carbs: https://www.ebay.com/itm/233439356307 Do search for "clean carbs ducatiman" here for tips. |
June 6th, 2020, 06:32 AM | #9 | |
Generally speaking (many variables) any purchased used "new to you" bike, especially those gaining in years....again around 10 year a good general rule to service carbs....service including *full* seal/oring and float valve renewal. Contrary to popular belief they have a service life...never intended to last forever (exposed in a constant fuel environment) In addition, float valves are a moving service part, their viton tips DO wear. Here's a pic of fuel rail seals from an original, untouched 25 year old set of Mikuni off a Ducati ....I'd submit these were done a little on the late side, the white corrosive drying and cracking the seals. Out and out dangerous in this instance, these leaking would be catastrophic. So, I'll submit that 25 year interval is too long. I routinely encounter 10-12 year old 250 carb oring/seals that are compromised way beyond service life ...flattened, crystal hard, corroded, etc etc.
June 6th, 2020, 07:19 AM | #10 |
So if I muddle through riding season, how much does it cost to have a pair of carbs professionally cleaned and rebuilt to stock specs? Thanks
June 6th, 2020, 07:52 AM | #11 |
I'll contact via PM
For discussion purposes, I'm doing today a 19 year old set of SV650 Suzuki carbs....a float valve went runaway....filling the combustion chamber and crankcase with fuel. I'll submit this example of denying a refurb for 19 years also too long. I'm thinking the 10 year threshold is safe and reasonable, again though...subject to variables.
June 13th, 2020, 12:33 PM | #12 |
So, with the help of the folks in here, I swapped out the 03 carbs for 12’s... starts right up, no fuel pouring out of overflow, it idles and everything. Thanks to all who offered advice and assistance!!
June 13th, 2020, 02:48 PM | #13 |
I now have 2012 carbs on 2012 engine in 2003 chassis. Apparently everything is different. Thanks
June 13th, 2020, 03:12 PM | #14 |
Exterior parts are slightly different along with jet-sizes inside. I've used them back & forth without any issues. As long as you match jet-sizes to engine it's going on.
Good job getting that fixed!! Last futzed with by DannoXYZ; June 13th, 2020 at 08:16 PM. |
Idle mixture screws are at different heights? (Idling/Starting Problem) | MegaEgg | 1986 - 2007 Ninja 250R Tech Talk | 30 | March 6th, 2016 10:37 AM |
Idle issue | djjontran | 1986 - 2007 Ninja 250R Tech Talk | 27 | August 18th, 2013 09:00 AM |
idle issue | PEN25 | 1986 - 2007 Ninja 250R Tech Talk | 10 | June 30th, 2013 02:14 PM |
Weird Cold Starting Idle | ajcadoo | 2008 - 2012 Ninja 250R Tech Talk | 9 | March 6th, 2012 08:54 AM |
Really low idle speed when starting??? HELP!! | Ktaylor07 | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 17th, 2011 09:57 PM |
