Old July 8th, 2015, 08:25 AM   #1
Panda
not an actual panda
Takes a lot of effort to push the bike
Pushing the 250 around the garage in neutral with the bike off takes a lot more effort (150% more 200% more?) than it does with my other bike.
The pads aren't dragging on the discs (at least as far as I can tell) so I think that leaves the bearings in the rim itself?
Is this an accurate assessment? Is there anything else that could be causing this extra drag?
Do I pull the wheels off and grease the bearings/replace the bearings?
Thanks in advance.
Old July 8th, 2015, 08:29 AM   #2
cbinker
cbinker's Avatar
do you have front and rear stands? get the wheels off the ground and give them a spin.
TEAM ALFALFA
www.apexassassins.com
Old July 8th, 2015, 08:30 AM   #3
The pads have to be draggin' my good man. If the bearings where that bad, you would have other clues. Either way, get the wheels in the air and try to spin them by hand. The front should spin pretty freely, but the rear should spin only a revolution or two because of the chain drag.
Also try to move the wheels side to side as well to check for slop in the bearings. And listen closely, the only noise you should hear is the chain.
Old July 8th, 2015, 11:22 AM   #4
cbinker
cbinker's Avatar
hell, you don't even need a front wheel stand a floor jack under the cross bar on the exhaust and a rear stand works fine.
TEAM ALFALFA
Old July 8th, 2015, 11:43 AM   #5
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Or the chain could be way too tight...
Old July 8th, 2015, 12:05 PM   #6
Nice addition, this is 100% accurate. Should be an easy diagnosis on that too.
Old July 8th, 2015, 12:19 PM   #7
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
Tire pressure?
Not enough air in them?
broken neck is offline   Reply With Quote
Old July 8th, 2015, 01:13 PM   #8
Originally Posted by Panda View Post
Pushing the 250 around the garage in neutral with the bike off takes a lot more effort (150% more 200% more?) than it does with my other bike...........
I agree with all the previous posts.
Another thing to check is a strong lack of alignment of the rear wheel that makes the side of the tire drag on the swing arm.
Old July 9th, 2015, 06:12 AM   #9
Panda
not an actual panda
Cool, thanks for the direction everyone. I'll throw it up on a stand this weekend and check everything! Thanks!
Old July 9th, 2015, 09:50 AM   #10
verboten1
verboten1's Avatar
MOTM - June '15
Take it out of gear?
Release brake lever?
Ride more, worry less.
[crash.net - MotoGP] - Crutchlow: Hopefully we can push a lot harder Ninjette Newsbot Motorcycling News 0 October 21st, 2014 08:20 PM
[topix.net] - Watch an Occupy protester push a cop off his bike Ninjette Newsbot Motorcycling News 0 October 31st, 2011 03:20 PM
[hell for leather] - Watch an Occupy protester push a cop off his bike Ninjette Newsbot Motorcycling News 0 October 31st, 2011 09:20 AM
[visordown.com] - Welsh bike tourism push Ninjette Newsbot Motorcycling News 0 February 7th, 2011 02:00 PM
Bluetooth push to talk - bike to bike ???? zartan General Motorcycling Discussion 25 July 1st, 2009 07:06 PM
