July 8th, 2015, 08:25 AM | #1 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Takes a lot of effort to push the bike
Pushing the 250 around the garage in neutral with the bike off takes a lot more effort (150% more 200% more?) than it does with my other bike.
The pads aren't dragging on the discs (at least as far as I can tell) so I think that leaves the bearings in the rim itself? Is this an accurate assessment? Is there anything else that could be causing this extra drag? Do I pull the wheels off and grease the bearings/replace the bearings? Thanks in advance. |
July 8th, 2015, 08:29 AM | #2 |
Track Clown
MOTM - Sep '15
do you have front and rear stands? get the wheels off the ground and give them a spin.
July 8th, 2015, 08:30 AM | #3 |
The pads have to be draggin' my good man. If the bearings where that bad, you would have other clues. Either way, get the wheels in the air and try to spin them by hand. The front should spin pretty freely, but the rear should spin only a revolution or two because of the chain drag.
Also try to move the wheels side to side as well to check for slop in the bearings. And listen closely, the only noise you should hear is the chain.
July 8th, 2015, 11:22 AM | #4 |
Track Clown
MOTM - Sep '15
hell, you don't even need a front wheel stand a floor jack under the cross bar on the exhaust and a rear stand works fine.
July 8th, 2015, 11:43 AM | #5 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Or the chain could be way too tight...
July 8th, 2015, 12:05 PM | #6 |
Nice addition, this is 100% accurate. Should be an easy diagnosis on that too.
July 8th, 2015, 12:19 PM | #7 |
Join Date: May 2012 Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally Posts: 384
Tire pressure?
Not enough air in them? |
July 8th, 2015, 01:13 PM | #8 | |
Another thing to check is a strong lack of alignment of the rear wheel that makes the side of the tire drag on the swing arm.
July 9th, 2015, 06:12 AM | #9 |
not an actual panda
Cool, thanks for the direction everyone. I'll throw it up on a stand this weekend and check everything! Thanks!
July 9th, 2015, 09:50 AM | #10 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
Take it out of gear?
Release brake lever?
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
[crash.net - MotoGP] - Crutchlow: Hopefully we can push a lot harder | Ninjette Newsbot | Motorcycling News | 0 | October 21st, 2014 08:20 PM |
[topix.net] - Watch an Occupy protester push a cop off his bike | Ninjette Newsbot | Motorcycling News | 0 | October 31st, 2011 03:20 PM |
[hell for leather] - Watch an Occupy protester push a cop off his bike | Ninjette Newsbot | Motorcycling News | 0 | October 31st, 2011 09:20 AM |
[visordown.com] - Welsh bike tourism push | Ninjette Newsbot | Motorcycling News | 0 | February 7th, 2011 02:00 PM |
Bluetooth push to talk - bike to bike ???? | zartan | General Motorcycling Discussion | 25 | July 1st, 2009 07:06 PM |
