July 14th, 2015, 06:30 AM | #1 |
Name: S n 0 r r £
Location: Stjoerdal, Norway (San Diego, CA, USA, 2015-2016 , Bielefeld, Nordrhein Westfalen,Germany 2021-'22)
Join Date: Sep 2012 Motorcycle(s): TMZ 5.952 "Tula" 200, Ninja 250 -Special ed. '11, ZZR 1400 (ZX14), Honda CB 1100 F Super Bol D'or Posts: 146
How long does the exhaust end can usually last?
I have noticed that the cap on the rear of exhaust system on my 2012 250R has started to gain visible rust. I loosened the 5 screws holding it in place and
took a look underneath. I could see rust more or less all over the end of the end can that had been hidden under the cap. The bike was bought spring 2012 and has about 20000 miles (32000 km) on the odometer. I guess it's hard to prevent the rust when it's already there, though I will soak it in WD-40 .. Anyone that knows how long the stock end can usually last? I live close to Trondheim on the norwegian cost, probably having a climate closer to New York than southern California, to give an indication.. |
July 14th, 2015, 08:33 AM | #2 |
Time will vary on usage, maintenance, storage and the amount of TLC given.
If you live near the coast or in an area where much salt is used to treat roads, then it will rust unless you're OCD about keeping it washed and waxed. I figure most riders do not wash their bike after every ride and keep it garaged to protect it from the elements. So goes the need to buy more chrome.
July 14th, 2015, 09:21 AM | #3 | |
Name: S n 0 r r £
I also used it for my daily commute in temperatures down to 1-2 degrees C (just above the freezing point of water). No wonder the exhaust system corrodes. weather conditions: http://www.yr.no/place/Norway/Sør-Tr...tatistics.html |
July 14th, 2015, 10:47 AM | #4 |
Private Joker
MOTM - Mar '14
Mine has a good deal of rust but I crashed on that side and it acted like a slider so when I rode through winter with all the salt on the roads it started rusting. I never really cared since it's an unimportant piece to me and I intend to replace it down the road anyway. Just make sure everything important is rust free though
things should rust at around the same rate as cars in the same area, maybe a tad quicker
July 14th, 2015, 08:20 PM | #5 | |
If the trips are short enough for the exhaust pipe not to reach normal operation temperature, that condensed water remains inside the pipe. Any steel that is not covered by galvanized or paint or chrome does quickly oxidize in presence of water. The edges of the cap are good candidates because are normally uncovered by paint or zinc (galvanized). Try to find a rust remover that is available in your country and apply it over the rusted areas. This chemical transforms rust into a black protective coat. WD-40 will only remove water temporarily.
July 15th, 2015, 03:04 AM | #6 | |
Name: S n 0 r r £
The vast majority of my trips were 40 km, or about 25 miles, since the bike is used for commuting. They take around 40 minutes, typically. I applied some tectyl rust prevention ( http://www.valvolineeurope.com/english/products/tectyl ) but may try some rust remover instead, as you suggest. Maybe I should wait for a while, since the mixture of WD 40 and Tectyl might disturb the useful properties of the rust remover. I would off course expect the original exhaust to rust, but I'm surprised that it has happened this fast. I could see signs of rust on the end cap, but after loosening the 5 screws, I found the part of the silencer hidden under it, in a seemingly much worse condition. |
[motorcyclenews.com - sport] - Danny Webb thrilled to end long-running points drought | Ninjette Newsbot | Motorcycling News | 0 | April 14th, 2013 10:42 AM |
Exhaust for Top End | mgentz | Ninjettes At Speed | 11 | March 13th, 2013 04:49 AM |
Exhaust for Top End | mgentz | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 25th, 2013 10:53 PM |
Long Island End of July Run | Clearlynotstefan | Ride Reports | 1 | July 28th, 2011 05:35 PM |
