Old March 20th, 2014, 06:05 PM   #1
Woolley7325
Motorcycle(s): 1998 kawasaki GPX250
Non-starting 1996 gpx250
Hi all. Next week I will be acquiring a 1996 non-starting gpx250. Without having had a good look at it and with very limited motorbike engine knowledge, I need some pointers on where to start.
I'm thinking the cdi unit because the guy I bought it off said that he took it to the shops with it running fine with no issues. After shopping he went back to it and it would not start. The electrics all worked fine still. He had it taken back to his place (over 12 months ago now) and has not touched it since.
Obviously I will have more info once I actually get the bike, but going off this info does anyone have any advice on getting it going or what the problem could be? It can only be so many things right?
Any help greatly appreciated!!!
Woolley7325 is offline   Reply With Quote
Old March 20th, 2014, 07:25 PM   #2
Always start with the basics...
Gas
Air
Spark
Air is the cheapest to fix, then gas, spark can get more costly.
Old March 20th, 2014, 07:33 PM   #3
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
I'd be inclined to check for spark first (of the 3 basics you mentioned).
Old March 20th, 2014, 11:49 PM   #4
Woolley7325
Thanks for the opportunity to humbly reveal my ignorance about all things mechanical!!!
By air, do you mean air filter box?
Gas - fuel? How can i check if fuel's getting to the carbys?
Spark - plugs, leads etc? What am i looking for precisely?
Thanks in advance for putting up with me! :-)
For God did not send His Son into the world to condemn the world, but that the world through Him might be saved. John3:17
Old March 21st, 2014, 06:15 AM   #5
Here is an old post that might help.
http://www.ninjette.org/forums/showp...&postcount=111
Old March 21st, 2014, 06:17 AM   #6
This too..
http://www.ninjette.org/wiki/My_Bike_Won%27t_Start
Old March 21st, 2014, 08:43 AM   #7
Woolley7325
Just got to wait to get it now....the suspense is like being a kid at Christmas again lol
Cheers for the tips will let you know how I get on!
Old March 21st, 2014, 08:48 AM   #8
quarterliter
Motorcycle(s): 2004 Ninja 250
80% of the time, bikes don't run because old fuel was left in the carb. Clean the carbs, and with some fresh gas they usually fire up.
Old March 21st, 2014, 08:50 AM   #9
quarterliter
When you do get it running, chances are the valves need to be adjusted. Look at the ninja250.org wiki for instructions
Old March 29th, 2014, 12:09 AM   #10
Woolley7325
Finally she is here!!!!!!!
I have changed oil and filter, got new battery and now am draining old fuel. I have drained the fuel, but am wondering with this model bike should the fuel run out with the Petcock on the 'on' position? Because no fuel was running out of the tank even with the Petcock set to 'on' or 'reserve'. Or does it vacuumed out?
Any help appreciated for this noob!
The bike turns over with the new battery, but still not starting.
(I have posted this same question in the thread, sorry if that's bad form.)
Old March 29th, 2014, 02:36 AM   #11
Woolley7325
Ok, I'm a tool...you tubed it and found out it's vacuumed so that's why no fuel cones out...
On another note, got the horrible air box out. Man what a pain in the butt! Need to replace air filter as it was in terrible condition. Wonder if it'll go when I put it all back together...
Old March 30th, 2014, 03:09 AM   #12
Woolley7325
Success!!! Thanks Dave (dcj13) from my other posts for the suggestion to drain the carbs, I had no idea you could do that. The fuel came out clean when I did so that was good.
Couldn't believe it when It turned over, left it running for a few mins and she settled down - black smoke slowly faded lol. Took it for my first spin around the clothes line, ran like a dream!!
For anyone interested, This is what I did to go from non starting (totally dead for last 12 months, to running smoothly...so far!
New battery
Drained old oil, replaced with new and a new filter
Drained old fuel from tank
Drained fuel from carbs
Added a fuel additive carb cleaner to new fuel
Reconnected the two rubber cups from the air box to the carbs (what a nightmare)
Cleaned the air filter
Next I need to: check chain, tyres, brakes and pads, accelerator cable is slightly sticking..... What else - any suggestions very much appreciated!
Old March 30th, 2014, 05:08 AM   #13
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Very cool you got it going.
Worlds fastest 250 ninja
Old April 15th, 2014, 09:23 PM   #14
Woolley7325
Hey guys, got my learners the other day so I'm now ready to ride! Before I take her out on the road though I want to get brakes checked and a basic lube etc from my kwaka dealer. Being a noob I'd rather get this done by the professionals first time around to ensure I'll be as safe as I can be on an unknown bike.
Talked to the dealer and he recommended a valve check/ adjustment as it has 33000km (21500 miles). I've no idea if it's been done or not in the past. The bike runs/ sounds fine to my unskilled ear, although I've only had it in neutral and first gear lol as I can't ride it on the road yet due to my licence. (In Australia we've got to have an instructor before I go for my test).
What do you guys think? Any idea of approx cost to get it done? I'm definitely not confident to do them myself at this stage.
Appreciate any input - cheers!
Old April 20th, 2014, 04:08 PM   #15
quarterliter
Chances are it has not been done. I would say it would be a good idea to have the valves adjusted.
Old April 21st, 2014, 03:56 AM   #16
Woolley7325
Yeah I'm keen to get them done to get her running as sweetly as possible. Man I can't wait to actually ride it!!! Cheers for the advice everyone. Appreciated.
GPX250 resurrection Midnight_tinkerer 1986 - 2007 Ninja 250R Tech Talk 37 May 11th, 2014 06:57 PM
Draining fuel tank - gpx250 Woolley7325 1986 - 2007 Ninja 250R Tech Talk 4 March 29th, 2014 05:49 PM
WANTED: GPX250 or ZZR250 in UK Matz Items Wanted 3 October 25th, 2012 11:48 AM
Starting on a 1996 R6 a good idea? I'm Fred General Motorcycling Discussion 56 September 29th, 2012 09:10 AM
I want as many switches on my GPX250 that a goldwing has! marc_previtera 2008 - 2012 Ninja 250R Farkles 10 March 9th, 2012 02:33 PM
