Old May 13th, 2012, 11:31 PM   #161
toua70
toua70's Avatar
Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission)
I have the gp danmoto and I love the sound and performance. Plus I like the look a lot better
toua70 is offline   Reply With Quote
Old May 14th, 2012, 05:25 AM   #162
Reyno2ac
Reyno2ac's Avatar
Motorcycle(s): Red 2009 Ninja 650r
Did you guys have to shim your carb for just the slip on?
Reyno2ac is offline   Reply With Quote
Old May 14th, 2012, 07:03 AM   #163
toua70
toua70's Avatar
I have no done that yet. Might shim but will rejet after I get a k&n filter.
Old May 14th, 2012, 08:09 AM   #164
xSean13
xSean13's Avatar
I shimmed, it wasn't hard. Went to radioshack to get the washers...followed the DIY here. I stripped one of the hard-to-reach screws which made it a pain, but it wasn't a problem.
Old May 14th, 2012, 08:51 AM   #165
iceknyght
Recalculating. . .
iceknyght's Avatar
Motorcycle(s): '09 250 (sold) '12 Ninja 650
I have the GP as well (including the extra baffle) and really like it! Looks much better than stock and so far *knock on wood*, no problems... I haven't shimmed yet, but still plan on doing it at some point...
jasontracewell.com
iceknyght is offline   Reply With Quote
Old May 14th, 2012, 09:20 AM   #166
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
I have the GP (with baffle) as well. I've shimmed and removed the snorkel and can't be any more happy with the performance of the bike and the sound of the exhaust. I have a couple of videos of me doing some aggressive riding, you can check those out to hear how it sounds at higher rpms to redline. I also have this video where I'm comparing the stock and the gp and do a couple of fly-bys. Ignore the bird talk and forward to 5:20 to hear the exhaust at iddle and low to mid ranges. You won't find a better exhaust out there for the price. cheers
EthioKnight is offline   Reply With Quote
Old May 14th, 2012, 09:46 AM   #167
triptronix
Motorcycle(s): 2011 Ninja 250R SE
Hi
Is anyone experiencing longer warm up times after installing the GP Carbon exhaust? It took me almost 10 full minutes to warm the bike up today, note that the bike was sitting for 2 days
Does that normally happen after the bike has been sitting for a few days?
Thanks
triptronix is offline   Reply With Quote
Old May 14th, 2012, 10:00 AM   #168
xSean13
xSean13's Avatar
How do you warm it up...idle with/without choke?
It's best to choke it, let it sit for maybe 30 seconds then ride with the choke on (not riding it hard) while incrementally turning the choke off. Also, after I put some 5w-40 full synthetic oil in my bike, it warms up quicker.
Old May 14th, 2012, 10:03 AM   #169
iceknyght
Recalculating. . .
iceknyght's Avatar
Originally Posted by triptronix View Post
Hi
Thanks
I have actually noticed shorter warm up times since adding the exhaust... Before, I had to choke it for a few minutes, but after, I barely use it at all. And I routinely go a few days without riding...
The colder the weather, the more likely you'll have to warm it up for longer... Not sure if that affects you at all, but is possible...
jasontracewell.com
Old May 14th, 2012, 10:17 AM   #170
triptronix
I was thinking about the same thing being in a colder climate but its been crazy hot in Ontario as of late. I will change out my oil to 5w-40 and see if that helps out
I appreciate the responses.... amazing forum BTW
Old May 15th, 2012, 11:39 AM   #171
Kristofferzero
Motorcycle(s): 2008 Ninja 250 (sold)
Anyone had issues with the Danmoto Carbon?
I bought the GP Carbon and within a really short while the can started burning and smoking badly. Danmoto said it was due to a gap in the carbon and the exhaust fumes were making it burn. I had to destroy my can and they sent me another for free. I put the replacement on last Thursday and it's doing the exact same thing. The weird part is its at the exact same spot, right side of the bracket. Has anyone else had issues with these?
Kristofferzero is offline   Reply With Quote
Old May 15th, 2012, 02:52 PM   #172
iceknyght
Recalculating. . .
iceknyght's Avatar
No issues here with mine at all...
jasontracewell.com
Old May 15th, 2012, 03:25 PM   #173
EthioKnight
Super Noob
Sorry to read about your troubles, but mine's just fine and has been so for quite sometime now...
Old May 15th, 2012, 06:56 PM   #174
bad_bwoy007
bad_bwoy007's Avatar
Motorcycle(s): 2012 Ninja SE 250R "Knight Rider"
Just installed mine yesterday and ran it about 30 miles with no issues.
bad_bwoy007 is offline   Reply With Quote
Old May 15th, 2012, 07:01 PM   #175
xSean13
xSean13's Avatar
Refund and get a jisu
Old May 15th, 2012, 10:15 PM   #176
toua70
toua70's Avatar
Had mine on for awhile now and works fine. Sucks what you're going through...
Old May 15th, 2012, 10:15 PM   #177
toua70
toua70's Avatar
Have*
Old May 16th, 2012, 11:10 AM   #178
Kristofferzero
Thanks for the replies. I emailed danmoto again and they said its either the baffle or my bike is running too rich and the gas is burning the can. Is that possible? I'm going to check my plugs today to see how my engine is running. I'm not looking forward to this... I hope i dont have to mess with my carbs again.
Though it is nice how easily Danmoto deals with issues. At this point they're giving me the option to either get a full refund, use a third carbon can, or upgrade to a full metal one. I guess it could be worse.
Old May 16th, 2012, 11:13 AM   #179
rainking
rainking's Avatar
Motorcycle(s): 2008 ZX10R & 2009 250R
No issues here either but wow, that's great customer service. Good luck with whatever you decide to do.
"Sometimes it takes a whole tankful of fuel before you can think straight."
rainking is offline   Reply With Quote
Old May 16th, 2012, 02:04 PM   #180
Kristofferzero
Alright so I took a look at my plugs and here's what I found. Does it look bad enough to imply my bike is spewing enough gas out of the exhaust to burn the can??
The only other possibility Danmoto believes it to be is the baffle but it's as straight and secure as I could get it.
Any help is appreciated.
Old May 16th, 2012, 02:40 PM   #181
Kristofferzero
I just checked NGK's website and my plugs look exactly like their picture of a normal conditioned plug.
I could just be the unluckiest Danmoto customer ever...
Old May 16th, 2012, 02:52 PM   #182
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
If anything from that picture of your plugs you look lean. What's the color of the porcelain further down the plug?
k-os is offline   Reply With Quote
Old May 16th, 2012, 03:08 PM   #183
Kristofferzero
Man this can be confusing stuff. Both plugs were white down there, I didn't notice anything else. Maybe a little dirty but the color was pretty white.
Would leanness cause the issue I'm having though?
Old May 16th, 2012, 06:25 PM   #184
k-os
Lean could be making your exhaust gases hotter, therefore scorching the carbon fiber.
Old May 16th, 2012, 07:23 PM   #185
Kristofferzero
I see. I'm not sure what you're seeing on my plugs though. If you take a look at the NGK site their "normal condition" for the plugs on their chart shows the same thing as on my plug. My bike is also shimmed and has the snorkel removed, and I seemed to be getting poor mpg before I put the can on.
Reading up on the rich/lean symptoms gets me nowhere either. I don't seem to have any of the symptoms so far as I could tell at this point.
Old May 16th, 2012, 10:27 PM   #186
k-os
Ideally the plugs should be a little tan.
http://www.4secondsflat.com/plug_chart.html
Old May 18th, 2012, 10:06 PM   #187
Kristofferzero
I think you may be right. After looking over lean symptoms again and riding today, I noticed my bike doesn't run very well when cold especially when accelerating. There was a point of lag when pulling away and when I would throttle hard it took a while to gain speed. It's completely different when warm however.
Thanks for the help. I'm thinking I should just get myself a jet kit.
Old May 19th, 2012, 07:48 AM   #188
leed
leed's Avatar
Motorcycle(s): Time will tell
You should be to just raise the needles (shim it with a washer). A jet kit is a little overkill for the Dan Moto slipon, in my opinion.
Old May 19th, 2012, 09:44 AM   #189
Kristofferzero
Yeah, I was going to get pod filters but I think I'm just going to stick with the shimming for now.
Old May 19th, 2012, 12:05 PM   #190
ninjagaiden09
ninjagaiden09's Avatar
Motorcycle(s): 2011 Ninja 250r
So how many washers you have so far on each needle? I have a dan moto too and I got 3 washers on each needle and it works for me. I also removed the kleen air I was getting popping and backfiring during decel.
ninjagaiden09 is offline   Reply With Quote
Old May 19th, 2012, 06:33 PM   #191
Kristofferzero
I have 2 washers on each needle. It worked great when my bike was still stock. I now have a UNI filter, no snorkel, and the danmoto so I guess the 2 washers aren't enough anymore. Hopefully having 3 will do away with this issue.
Is the popping bad? I kind of like it.
Old May 20th, 2012, 08:16 PM   #192
xSean13
xSean13's Avatar
Recorded a better idle/rev video.
Old May 20th, 2012, 08:50 PM   #193
2012NewRider
Motorcycle(s): 2012 Kawasaki Ninja 250R
I've got the GP with the Baffle to make it a deeper roar but I currently have an exhaust fume leak where the header pipe meets the exhaust coupling. You might want to check out the other threads for more research. Also, be careful with mounting. My mounting bracket did not have matching size holes for the OEM mounting screw and also be very careful to not over-tighten during install.
2012NewRider is offline   Reply With Quote
Old May 20th, 2012, 08:54 PM   #194
EthioKnight
Super Noob
I had the same issue bruh, a quick trip to Auto Zone and application of 'exhaust leak sealant' later, air tight awesomeness
Old May 20th, 2012, 09:06 PM   #195
2012NewRider
The only issues I had was that the coupling and straight pipe didnt mate properly and leaks, the mounting bracket did not have matching holes, the last is that the bracket was a little small and I ended up overtighting it.
Old May 21st, 2012, 12:00 AM   #196
edxmon
edxmon's Avatar
Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013)
no baffle, right?
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips
edxmon is offline   Reply With Quote
Old May 21st, 2012, 07:55 AM   #197
xSean13
xSean13's Avatar
Originally Posted by edxmon View Post
no baffle, right?
Correct. But it's way louder than the video shows
Old May 21st, 2012, 04:51 PM   #198
Kristofferzero
Yeah I had that issue with the bracket, too. They told me to just buy a smaller bolt but even then I had some trouble mounting it. It is really tight.
Old May 21st, 2012, 06:19 PM   #199
cmSAE
Motorcycle(s): 2012 Ninja 250
is anyone else having no luck finding the 250 exhausts on danmotos website?
update: they are out of stock, so they disabled the page. they will have more at the end of the week.
Last futzed with by cmSAE; May 21st, 2012 at 07:45 PM. Reason: update
cmSAE is offline   Reply With Quote
Old May 22nd, 2012, 07:12 AM   #200
Francis
ninjette.org newbie 2,000
Motorcycle(s): Ninja 250r
Switching From Stock to DanMoto, Vice Versa
Hey, guys. I plan to pick up a DanMoto (Carbon GP) slip-on, since it's pretty cheap, and louder than the stock.
I got a couple of concerns. I've read that I won't need to rejet with the slip-on, but I've read that some people have rejetted for the slip-on.
My second concern is the installation. I know bolting it is a little tricky as in, it doesn't just "fit" and I need to put a lot of effort into securing into the bike.
With that said, I still want to be able to do track days with the 250r, and with the DanMoto being 100+ dB, it just wouldn't work. Would switching back to the stock pipe be an easy task? Less than an hour?
Putting an hour or so every few weeks to be able to put the stock for the track and then the DanMoto back for the street isn't too bad. But if it's gonna take me hours to switch em, it wouldn't be worth my time.
Francis is offline   Reply With Quote
Danmoto exhaust illegal in CA?! RandomPhantom 2008 - 2012 Ninja 250R Farkles 29 February 20th, 2014 03:08 AM
Has anyone had any problems with the DanMoto JISU exhaust?? NinjaBoyEddy 2008 - 2012 Ninja 250R Tech Talk 46 January 8th, 2013 07:10 PM
Looking to trade my danmoto carbon gp exhaust for a jisu NinjaBoyEddy Items Wanted 1 April 30th, 2012 10:54 PM
Slip On Exhaust: DanMoto and HB Growler caps 2008 - 2012 Ninja 250R Tech Talk 7 July 22nd, 2011 09:15 AM
FS: DanMoto CF Exhaust complete w/Baffle red Motorcycle-related 3 June 18th, 2011 07:18 PM
