Old January 24th, 2012, 02:08 AM   #1
applying brake before releasing throttle?
so let me ask you guys a question
i may sound like a stupid squid though
when you get on the brakes, coming into a slow corner from a fast straight, do you ever start braking before you let off the throttle? like not much just enough to compress the forks a little. and not for long just right before and just a little bit so when you let off the gas and get on the brake harder the nose dives less?
i started doing it on sunday and things felt smoother... but im scared im going to break my front loose or something right before getting on the brakes and tucking my front... :/
Old January 24th, 2012, 04:28 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Trail braking will stiffen the suspension as you turn.
Old January 24th, 2012, 04:34 AM   #3
n4mwd
n4mwd's Avatar
I'm not crazy about the front brakes in a turn. Sometimes in sharp slow turns I will apply pressure to the rears just to keep the chain tight. I'm usually always on the throttle in a turn. I only use the fronts when I actually want to come to a stop.
Once I lost my rear tire on some sand while braking too hard while cornering. Since then, I only use just enough pressure for chain tightening. I don't see any advantage to routine braking with the fronts in a curve.
My Ninja Blog
Old January 24th, 2012, 05:05 AM   #4
Skippii
Milkshake Drinker
Skippii's Avatar
I've got pretty long fingers but I still think it would be really awkward to use the lever with the throttle turned...Haven't really tried it, but I like my hand movements to be a nice smooth motion of letting off the throttle as I reach for the lever..
Posted via Mobile Device
Old January 24th, 2012, 07:25 AM   #5
The point in time you're referencing is a throttle roll off for me. Seems to me that the added throttle at that time will only add to the compression force to the front suspension when hard front braking is applied setting entry speed, possibly pushing you out of the sweet mid-range zone. I think this is one of those areas where its different for everyone in terms of what works for them, bike setup, preloads, fork oil weight, tires and generally how aggressively a rider approaches a corner.
Please refer to the attached image where 2 orange lines identify the zone your question references. This is the throttle roll off just before braking/blipping setting corner entry speed. Complete the roll off quickly, but don't chop as it will not feel smooth.
The image also identifies another zone (2 blue lines). This is the area where I find myself rolling on the throttle with a VERY light touch of rear brakes still in effect. The only reason I do this is to smooth out the transition and not have a lurching affect in case of throttle control error or cush drive/chain slop. I also must add, I don't do this for every sharp corner. Also as you know, environmental, bike and rider conditions can move the lines around, so adjust to fit your needs.
** THESE TECHNIQUES ARE NOT FOR BEGINNERS, USE WITH CAUTION **
Old January 24th, 2012, 09:51 AM   #6
coondog
coondog's Avatar
Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125
You're the guy everyone hated in high school! Great post!
coondog is offline   Reply With Quote
Old January 24th, 2012, 10:04 AM   #7
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Hmm...not sure what this has anything to do with the thread. Personal vendetta...if so, keep it to PM.
Old January 24th, 2012, 10:08 AM   #8
He was just joking around Nem, I got it.
I also saved a bunch of money on my car insurance by switching to geico.
Old January 24th, 2012, 11:23 AM   #9
not sure what coondogs problem is. i think some people misunderstood what i was saying.
thanks for the reply chris, i didnt think about using the rear brake for that. i guess it would be about the same as rolling off the throttle slower wouldnt it? definitely would smooth things out but i feel like using the front brake sets up the forks a little bit better for a quicker front brake application...
the process im talking about for those not getting it:
* WOT,
* approach braking zone, maybe 20 feet before braking zone, apply 5-10% front brake,
* forks begin to dive,
* roll off throttle and start applying more brakes... these two happen almost the same time... throttle roll off happens quicker than the brakes come on.
* then full brakes, get down to speed (brakes down to maybe 40% by this time),
* turn in,
* then slowly trail the brake the rest of the way until a little bit before the apex (depending on the turn),
* then back to throttle roll on, smooth to wot as you give it a little help picking up with the inside bar as you can get back to full power
Old January 24th, 2012, 11:27 AM   #10
He was just complimenting Chris on a brainy yet accurate reply.
Yup.
Old January 24th, 2012, 11:28 AM   #11
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
EDIT - Just downshift and modulate the clutch.
Old January 24th, 2012, 11:35 AM   #12
that makes more sense
Old January 24th, 2012, 11:36 AM   #13
@Nemesis what do you do on the 600 for roll off?
Old January 24th, 2012, 11:56 AM   #14
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
You're not going to tuck the front from braking hard in a straight line.
Honestly...on the 600, I just simplify everything by not over thinking it.
In other words, I just deal with it.
Your issue isn't with the front brakes/suspension but how to take a short quick turn coming from a fast straight away. That's your problem.
Me? I just brake late & hard and release and just FLICK the bike and let the suspension & tires do its thang.
Old January 24th, 2012, 12:14 PM   #15
thanks jon. next chance i get i will practice diving in later with a quicker turn in dont be affraid to be brutally honest with me, it takes a lot for me to get butthurt. i already know im a horrible squid who sucks
i want to do some front fork tuning... something about getting hard on the brakes on that bike when going fast feels... off... at least compared to the 250... but then again you are only going like 100mph at the most on the 250... hmm maybe i shoould just take the 250!!!
Old January 24th, 2012, 12:50 PM   #16
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Here's another honesty, you're a fast learner. You were smooth out there with a really decent pace for someone who's never been to that track.
There are a few issues you need to work on and one of them is getting rid of that bike and getting you on a proper bike. And I don't mean a 250. I mean a more updated bike with better suspension (front & rear).
Old January 24th, 2012, 01:24 PM   #17
hmm. but new bikes are so expensive... do you think i can get away with an r6 shock and emulators in the front? maybe ill try to sell the 250 to help fund a new 600
Old January 24th, 2012, 02:17 PM   #18
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Or how about you race a 250.
Old January 24th, 2012, 02:39 PM   #19
n4mwd
n4mwd's Avatar
Track riding?
Alex, it might have helped us a little if you had mentioned that you were talking about track riding. I see in your posts you mention 100mph turns at WOT. At least I hope you are talking about the track. Its apples and oranges as far as I can tell. Not many people take street corners at 100 mph anyway.
My Ninja Blog
Old January 24th, 2012, 02:55 PM   #20
oh. right.
sorry.
dont take corners at 100mph on the street. as dustin from trackdaz says, the street is for wheelies and stoppies and ****
Old January 24th, 2012, 03:03 PM   #21
Old January 24th, 2012, 03:18 PM   #22
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Get your CVMA racer license and trackday fees are reduced to $100 w/trackdaz. Also other orgs give you racer's discount. Some good stuff right there!
Old January 24th, 2012, 04:41 PM   #23
how long after making it to A group should you wait to go for NRS?
Old January 24th, 2012, 05:54 PM   #24
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
I just started to get confident passing people in B group when I started to race and after the first race weekend BAM! I'm doing A pace.
Telling you, racing is the shizzle!
Old January 24th, 2012, 06:01 PM   #25
OK, ok. once my 4 pack is up (2 more days left) i will sign up for NRS.
Old January 24th, 2012, 06:12 PM   #26
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
I'm sure I shared this somewhere either here or on SCM but the true reason why I signed up for the NRS was to get discounts on trackdays. Yeah, I'm a cheap @$$.
But after I did the mock race...OMGosh! I had a grin from ear to ear and I had found a new love for the sport that was just starting to die down for me (i.e. doing trackdays).
Old January 28th, 2012, 02:01 PM   #27
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
----> My Youtube! <----
Old January 28th, 2012, 02:28 PM   #28
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Actually, everything that Chris posted applies to riding at the speed limit on twisty roads or even on the street. I'm not saying there is only one way to slow down. There are plenty of ways to achieve this goal. However, trail braking can, and will, allow you to control your speed all the way down to an apex be it a mountain road or the corner by the local 7-11. It is all about getting your speed down in a smooth and controlled manner.
I do everything that is in his diagram on the street. Like Chris stated, not for beginners, but learning this stuff is what makes a beginner into a better rider. Plus as an added benefit, it is a whole lotta fun
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix
Cancer
Last futzed with by JeffM; January 28th, 2012 at 05:28 PM.
JeffM is offline   Reply With Quote
Old January 28th, 2012, 02:41 PM   #29
Originally Posted by JeffM View Post
it a whole lotta fun
its extremely addictive when you get used to it i can only imagine how addictive backing it in is
Old January 29th, 2012, 12:45 AM   #30
pics once you figure it out
Cleaning solvent before applying chain lube nickjpass General Motorcycling Discussion 17 August 21st, 2014 01:07 PM
How successful is applying touch up paint? THE BIG SITT 2008 - 2012 Ninja 250R Farkles 11 April 11th, 2014 12:12 PM
stalls sometimes when applying throttle ninja12345 2008 - 2012 Ninja 250R Tech Talk 11 November 3rd, 2013 07:41 PM
Applying decals - clearcoat? Christofini 2008 - 2012 Ninja 250R Farkles 4 October 11th, 2013 03:20 PM
DIY- Applying Vinyl Graphics kkim 2008 - 2012 Ninja 250R Tech Talk 25 March 3rd, 2012 05:35 PM
