Old September 17th, 2013, 10:14 AM   #1
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
bike won't start. tried everything
so the bike doesnt start. nothing. battery is good..
touch both starter relay terminals together and it cranks...
a working running same year ninja pulls into garage. i use his fusebox, voltage regulator. ignition switch, start/kill button, cdi box and starter relay....same....thing. put all this back on his back. his starts and he drives home....
so today i bought a new wiring harness.
odd. i dont get it. my harness doesnt look damaged anywhere
in other news..
The King
rabies is offline   Reply With Quote
Old September 17th, 2013, 10:38 AM   #2
You will need a voltmeter-ohmmeter and a lot of patience.
You may need to check if your generator is supplying enough juice.
Check this thread for a similar case:
http://www.ninjette.org/forums/showt...reaking&page=4
Old September 17th, 2013, 10:40 AM   #3
Did you swap coils?
Old September 17th, 2013, 11:01 AM   #4
Lychee
sail away
Lychee's Avatar
safety switches?
-clutch
-neutral
-kickstand
Old September 17th, 2013, 11:08 AM   #5
Originally Posted by Lychee View Post
safety switches?
-clutch
-neutral
-kickstand
Old September 17th, 2013, 11:16 AM   #6
rabies
rabies's Avatar
safety switches?
-clutch
-neutral
-kickstand
those were deleted last year. drove it a year like that.
stator or not. bike should crank though.
The King
Old September 17th, 2013, 02:46 PM   #7
MasterCylinder
MasterCylinder's Avatar
Motorcycle(s): '90 ex250
Check for corrosion on the start button itself. I had a mystery issue like that with my horn and turned out it was just corrosion on the metal pieces of the button.
MasterCylinder is offline   Reply With Quote
Old September 17th, 2013, 03:00 PM   #8
tc.young
Motorcycle(s): '89 klr 650, '00 250r
did it start after you cranked it? if not then check if plugs are sparking. pull the spark plug wires and use a spare spark plug, ground the threads against the engine and check for spark.
tc.young is offline   Reply With Quote
Old September 17th, 2013, 03:17 PM   #9
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
what makes you think it's electrical in the first place? the complexity?
you need fuel, spark, and air. what do you have? what's coming out the exhaust?
keep it simple
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old September 17th, 2013, 03:23 PM   #10
So it doesn't crank unless you jump the starter terminals - right?
If so, you need to look at a wiring diagram and locate the wires and path they take. Check for power at numerous points in the system and isolate where it stops. It's possible it could be corroded contacts at the button as MasterCylinder noted.
Old September 18th, 2013, 02:53 PM   #11
tc.young
even if it doesn't crank when pushing the starter, bypassing the solenoid and cranking it that way should start it. you are just bypassing one of the starting system mechanisms. if it doesn't start but cranks when bypassing the solenoid then there is an issue somewhere else.
Old September 19th, 2013, 07:19 AM   #12
n4mwd
n4mwd's Avatar
Most of the time when a ninja doesn't start, its the carburetors. If you have to short the solenoid terminals to crank it, then that's an additional problem.
My Ninja Blog
Old September 21st, 2013, 03:02 PM   #13
rabies
rabies's Avatar
i guess no1 read the first post...
new harness didnt fix it either
The King
Old September 21st, 2013, 03:23 PM   #14
Sorry Jessie, but it seems that is you who doesn't bother reading or responding the posts of members trying to help you.
Hope you find the problem on your own !!!
Old September 21st, 2013, 04:32 PM   #15
n4mwd
n4mwd's Avatar
Your first post says that your bike will crank, but not start. Why are you changing the electrical harness before you know what is wrong? Have you at least checked to make sure you have spark? If you have spark, then the most common cause of a no-start condition is the carbs.
My Ninja Blog
Old September 21st, 2013, 07:11 PM   #16
rabies
rabies's Avatar
turn the key to on. hit start button..nothing happens. nothing..like a dead battery. but battery is good and checked.
everthying minus the motor itself n stator hav been replaced and it still does nothing. but touch starter relay terminals n it cranks. has nothing to do with carbs or spark...
..its magic. or must be low on starter fluid?
The King
Old September 21st, 2013, 08:02 PM   #17
Starter button (post #7) or starter relay.
If not, trace the power - as I mentioned in post #10.
Last futzed with by jkv45; September 21st, 2013 at 09:19 PM.
Old September 22nd, 2013, 04:46 AM   #18
n4mwd
n4mwd's Avatar
Its starting to sound like you are saying that the bike runs ok, but it wont crank. That's a totally different diagnostic.
So do the dash lights come on with the ignition switch?
Does the neutral light come on?
Kill switch flipped down?
Fuses OK?
You said you shorted the terminals on the starter relay, but those terminals are not accessible. You probably mean the starter solenoid which has big nuts that are accessible.
That said, you have to get an ohm meter and track it back to the fault.
My Ninja Blog
Help!!!!!!!! - bike won't start auntymunga 2008 - 2012 Ninja 250R Tech Talk 5 August 18th, 2014 06:54 AM
Bought first bike and 1 day later it won't start: do I have a junk bike? brendandubs 1986 - 2007 Ninja 250R Tech Talk 43 May 11th, 2014 07:59 AM
Bike won't start FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 127 November 17th, 2013 03:18 PM
bike won't start... nebraskan 2008 - 2012 Ninja 250R Tech Talk 4 May 11th, 2011 01:48 AM
