Old January 8th, 2018, 02:32 AM   #1
Darksik
Darksik's Avatar
What clutch cable i should buy?
Hi guys i have a problem, i checked the manufacturer part number on the bikebandit webpage and there says that the number is this "54011-0565" i found some cables on ebay but on the description says another manufacturer part number, in all the sellers says this number "54011-0566" but almost all the sellers who sells that clutch cable are from china.
Also i found a guy who sells a "Motion Pro -03-0417-Black Vinyl Clutch Cable." he is from USA and im from mexico so i think the cable could move more faster than the chinese
Somebody have bought a motion pro or i should buy with the chinese guys?
I wait for your answers
I put below the links of the motion pro and the chinese clutch cable
Chinese Clutch Cable
Motion Pro Clutch Cable
Old January 8th, 2018, 05:29 AM   #2
empire00
empire00's Avatar
Motorcycle(s): 2009 250r SE, 2015 FJ-09
I would buy the motion pro. Don't want to risk it on a chinesesium cable
empire00 is offline   Reply With Quote
Old January 8th, 2018, 06:55 AM   #3
taz
taz's Avatar
MOTM - May '17
for the $2.50 more I would go with the motion pro
Old January 8th, 2018, 09:45 AM   #4
I was researching this months ago when I found frayed clutch cable. No one made quality cable with teflon-lined housing. I ordered one MotionPro and one cable through Ali. Both exactly the same. I suspect that’s where MotionPro sources their cables.
In the end, I went with used OEM cable from breakers and have both MotionPro and Chinese cable as spares in my toolbox. Be careful when installing, set adjuster rotation so that its slot is aimed up or down so the cable doesn't rub on sharp edges of teeth.
On back-burner, but I'm still looking for good cable with teflon-lined housing. May adapt one from different bike that's close enough. There are also DIY kits with unattached end. Trim to length and crimp & solder barrel-end on.
Last futzed with by DannoXYZ; January 8th, 2018 at 11:40 AM.
Old January 9th, 2018, 08:13 AM   #5
565 seems to be the current, active part #. Note its common to the 300 as well.
566 is NOT a good part # at all
Old January 15th, 2018, 04:10 AM   #6
vkuchhal
vkuchhal's Avatar
Motorcycle(s): ninja 250r -2010
i got cable for my ninja 250 2010 model from aliexpress, seems to working fine and fitment was good.
https://www.aliexpress.com/item/Moto...311.0.0.HhfpZE
vkuchhal is offline   Reply With Quote
Old January 15th, 2018, 05:38 AM   #7
Ram Jet
Ram Jet's Avatar
Partzilla.com lists the clutch cable as part number 54011-0073 and notes that it is unavailable. I would go with Motion Pro without hesitation. Remember to lubricate your new cable before installation because most manufacturers don't - I know Motion Pro doesn't.
Bill
Old January 15th, 2018, 08:59 AM   #8
That's the better of two cables available. Difference is accordion-seal on one versus little cap on other.
Old January 16th, 2018, 12:21 AM   #9
Darksik
Darksik's Avatar
Thanks for your answers guys, i bought the motion pro, only took 1 week from USA to my house, this friday i try to change the cable.
Old January 16th, 2018, 01:02 AM   #10
Ram Jet
Ram Jet's Avatar
Don't forget to lubricate it. Engine oil is just fine.
Bill
Old January 16th, 2018, 04:07 PM   #11
MrAtom
MOTM - July '15
Bill
Interesting. I have a motionpro cable still in the packaging and it's been lubed with white lithium. Note that this is for the pregen.
Old January 16th, 2018, 04:13 PM   #12
Ram Jet
Ram Jet's Avatar
I haven't checked recently but about three years ago they had an advisory on their website that advised lubing their cables because they didn't. Maybe things have changed.
Bill
Help please!!! Clutch cable JayJay 2008 - 2012 Ninja 250R Tech Talk 5 August 6th, 2015 07:54 AM
Clutch cable Linkin 2008 - 2012 Ninja 250R Tech Talk 5 January 28th, 2015 03:29 AM
clutch cable james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 July 27th, 2013 10:20 AM
Clutch Cable- Where to Buy? Jim Moore General Motorcycling Discussion 3 May 29th, 2012 05:49 AM
Clutch Cable atomicrm 2008 - 2012 Ninja 250R Tech Talk 2 December 17th, 2011 12:22 PM
