January 12th, 2013, 07:52 AM | #1 |
Join Date: Jun 2012 Motorcycle(s): 2012 Ninja 250R Posts: 20
How to check if bike has been dropped?
I am currently searching for a 250 and I saw a 2008 green ninja at a decent price. When I went to check the bike, I noticed that the left fairing is missing 2 screws and the fairing is a little misaligned to the holes. The owner said that some random students at his college stole them off his bike as a prank.
How can I check if the bike was dropped and the fairing was replaced? The left indicator light looks fine but I am not sure if that was replaced also. He also has adjustable levers so his levers look new. |
January 12th, 2013, 07:54 AM | #2 |
Join Date: Oct 2012 Motorcycle(s): '04 R1 and '08 Ninja 250 Posts: 222
Look for damage on the bar ends and foot pegs.
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son |
January 12th, 2013, 07:59 AM | #3 |
fairings come off quite often for maintenance, ppl lose the screws all the time.
look at: engine case on sides for scratches / off color paint covering scratches. bent handles bars/clip ons. check alignment of tire and bars. cracked oil sight glass. most replacement fairings won't have the foam pieces on inside. scratch marks on mirrors. can't think of much else at moment. |
January 12th, 2013, 08:43 AM | #4 |
If dropped on the right side check for heavy scratches on:
Mirror Handle Bar Ends (Weights) Bent or scratched brake lever scratches on tip of the indicator light - broken damaged stalks Scratches on the exhaust can Obvious Scratches on fairings etc. On the left side: Mirror Handle Bar Ends (Weights) Bent or scratched clutch lever scratches on tip of the indicator light - broken damaged stalks Scratches on the rear seat fairing left tip (Ask me how i know this ) |
January 12th, 2013, 11:52 AM | #5 | |
How do you know this?
January 12th, 2013, 12:21 PM | #6 |
rotate the bars back and forth they should not touch the tank
January 12th, 2013, 12:22 PM | #7 |
Gixxer Powered
Join Date: Mar 2012 Motorcycle(s): 2007 GSXR 600 Posts: 397
If it's your first bike, or not I suppose, then I wouldn't worry too much on a dropped bike if it's only cosmetic.
January 12th, 2013, 01:19 PM | #9 |
Join Date: Dec 2012 Motorcycle(s): Ninja 300 - Posts: 116
Never debate with idiots. They'll drag you down to their level then beat you with experience. |
January 12th, 2013, 02:12 PM | #10 |
Additions...
Tweaked rear frame or sub-frame (sometimes easy to tell visually). Scratches on swingarm and/or axle bolts.
January 13th, 2013, 10:16 AM | #11 |
Blue Shell magnet
Join Date: Aug 2011 Motorcycle(s): 1997 Ninja 250 Posts: 816
Vibrations from the road have also been known to cause screws to back out. It's unlikely but possible.
Dropped my bike... | nvxdiz | !%@*#$%!)@#&!%@ I crashed! | 23 | August 22nd, 2012 10:54 AM |
Dropped Bike | Raider24 | !%@*#$%!)@#&!%@ I crashed! | 7 | June 19th, 2012 07:24 PM |
Dropped my bike... | Cedilla | !%@*#$%!)@#&!%@ I crashed! | 21 | July 3rd, 2010 05:05 AM |
I dropped my bike! | motorcycle_munge | !%@*#$%!)@#&!%@ I crashed! | 16 | April 29th, 2009 06:21 AM |
Dropped Bike Need Help! | NewNinja | !%@*#$%!)@#&!%@ I crashed! | 7 | March 16th, 2009 07:50 AM |
