Old September 6th, 2013, 11:47 AM   #281
Yes, you did. This pic was a lil bit farther over too.
Thing is, it's got some lean to go if I can get the front end stable. I forget who said it, but when you start getting da 250 really low, it feels like your gunna crash at any time. lol Boi.... where they right. The whole chassis starts to feel unstable. Since the gsxr rear shock and adjustments, the rear feels rock solid, not even the least bit of slip or sliding. That stock front & bars has gotta go, it's a mess at these speeds and angles.
EDIT: lol check my hands (inside hand specifically)... totally different than other pics. I am tight on the bars, a lil bit of evidence that it's sketchy down that low. If I was to lean it over any farther, the front starts to rut and turn inward to the inside with a bit of chatter. That is the bike tellin' me "your gunna eat dirt if you keep pushin' it".
Old September 9th, 2013, 02:15 PM   #282
RacerX113
Motorcycle(s): Triumph Thruxton, Ninja 250
I'm starting to drag my left peg and shifter. I'm currently using the SV racing rear sets(set as high as they'll go), stock shock and running dunlops unbeatens(150 rear). It looks like the woodcraft are a little higher and back than the SV's maybe 5MM. It doesn't feel too terrible when I drag it. I believe this is due to having plenty of room on the Dunlop 150s. But I'm wondering if I should replace them with the woodcraft or vortex(not looking foward to laying out more cash), or just hang on for a bit untill I replace the shock with an adjustable one to get another 5mm lift in the rear. The other optioin is work on my body position so I'm not leaned so much.
Here's a pic of me on track
http://www.ninjette.org/forums/showt...=127839&page=5
RacerX113 is offline   Reply With Quote
Old September 9th, 2013, 02:24 PM   #283
I seen your pics Doug
2 simple things
1 harder thing
Simple:
BP, you could always work on that
Peg length, how long are the pegs. I cut nearly and inch off mine. Mine offer me just shy of 4'' perch for my feet. Check my avatar, nuttin' but toes pokin' out.
Harder:
Raise the rear of the bike, the lil ninja actually benefits very well when the rear raised up about 10mm. Be mindful of the change to your front though and adjust as needed.
Old September 9th, 2013, 04:51 PM   #284
RacerX113
2 simple things
1 harder thing
Simple:
Harder:
I'm not near my bike now, but looking through an old post on the sv racing rear sets state that they measure out at 2.6". Not sure that is correct but I'm going through toe sliders pretty quick on my left. Although I can get a bit lazzy with foot placement.
Can you raise the rear with a stock shock? Did you raise yours 10mm in the rear? If so what did you do with the front?
Thanks,
Old September 9th, 2013, 05:21 PM   #285
for stock shock, you change the dogbone lengths to adjust rear height. adjustable dogbones are nice and easy and cheap to make/buy.
remember changing the rear height without also changing the front means you are changing rake and trail. 1inch up on the rear or 1inch down in front equals 2 degrees on the rake. generally most bikes don't go lower than 23.5 before becoming too unstable... stock is 25d.
Old September 9th, 2013, 06:37 PM   #286
lgk
Impressive, keep up the good work.
Old September 9th, 2013, 07:26 PM   #287
Thanks,
Agree with alex.s I do. I got some bones made by @Rexbo when I did the gsxr shot conversion. My front is still stock aside of heavier fork oil. In hindsight, I should have went for new front bits first.
I haven't touched a slider on the woodcraft rearsets but I do keep tidy feet most of the time.
Old September 9th, 2013, 08:31 PM   #288
fyi, rear with stock front was by far the sketchiest thing i've ridden on track.
which is saying a lot because i've taken my fzr on track, and that thing is ridicusketch.
Old September 9th, 2013, 08:36 PM   #289
I found your new word!
Old September 9th, 2013, 08:51 PM   #290
ridicusketch?
or threadjacker?
Old September 9th, 2013, 09:18 PM   #291
RacerX113
Yep they're about 3".
So where can I get my hands on some adjustable dog bones?
Also when you raise the rear, where do you measure?
For sure the front needs to be done before the rear. The stock shock isn't so bad. The stock spring rate is actually what Race Tech recommends for my weight. I would just like something with ride height adjustability and better valves. It seems to fade (not sure if thats the right word) a little at the end of a stint.
Old November 13th, 2013, 08:52 AM   #292
Watch this and then take out your bank card or CC and go.... whoa!!!!
Old November 14th, 2013, 12:12 PM   #293
Aodrn
It's a long boring story
Aodrn's Avatar
Motorcycle(s): 2012 Ninja 250
I have the SV rearsets as well. I was debating drilling an additional hole above and behind the top hole choice for bolting the peg in. I saw it done on another 250 and it looked functional, but I have yet to try it myself. I will try to take a pic later to show what I'm trying to describe. I am pretty paranoid about hitting my pegs now. My season ended in a nasty highside caused by poor body position making the peg dig into the ground on a tight left.
I do have a pic of right before that wreck though. I wrecked in that corner after I got tired and stopped hanging off as much. I always feel off at Gateway though. Next year I am going to make it my mission to figure out good lines there.
File Type: jpg untitled-1155-(ZF-5893-08696-1-001).jpg (126.8 KB, 25 views)
#41 MCRA
alex.s :crashing is a normal part of life... people are just in denial about that.
Aodrn is offline   Reply With Quote
Old March 15th, 2014, 08:50 PM   #294
pharaelga
Motorcycle(s): ZX14 and Ninja 250
Need to get better body position...
pharaelga is offline   Reply With Quote
Old March 15th, 2014, 09:05 PM   #295
Rock on Nathaniel! And welcome.
Old March 16th, 2014, 09:18 AM   #296
Aufitt
The A Team
Aufitt's Avatar
Motorcycle(s): Z50, CB125, RZ500, MC22, R3.
Slicing on my cbr.
Aufitt is offline   Reply With Quote
Old March 16th, 2014, 07:02 PM   #297
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
Can I still play?
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Old May 6th, 2014, 08:09 PM   #298
A worthy pedal bike pic.
4 out of 4 members found this post helpful.
Old May 6th, 2014, 08:10 PM   #299
Originally Posted by Peanut_EOD View Post
Can I still play?
yes sir!
Old May 6th, 2014, 08:22 PM   #300
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
mountain bike lean angle, great way to show how hardcore the sport can be
looking forward to getting a few pics up here in July
Old May 6th, 2014, 08:48 PM   #301
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
You posting chone pics without authorization again?
Sweet pics @Peanut_EOD
Old May 7th, 2014, 05:18 AM   #302
****. I wish that was me dragging bars on the berm. Alas, chone is not that skilled, nor is he off he IRL for the season.
Also, it's finals week. No biking here.
Old May 7th, 2014, 07:15 AM   #303
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
go to 3:17 into the video in this post. That guy gets it over pretty good
https://www.ninjette.org/forums/show...42&postcount=1
Old May 9th, 2014, 05:29 AM   #304
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
See the video: http://youtu.be/jOlVJv7jAHg
geeker is offline   Reply With Quote
Old May 9th, 2014, 08:09 AM   #305
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Originally Posted by geeker View Post
haha that is basically a wall ride shot.
mtb is awsome
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old May 10th, 2014, 05:37 PM   #306
greenswoave
greenswoave's Avatar
Motorcycle(s): USA
SV Racing rear sets. Kick stand is still on there.
greenswoave is offline   Reply With Quote
Old May 22nd, 2014, 02:26 PM   #307
KazMan
KazMan's Avatar
Motorcycle(s): none yet
Yeah that's all fine and well with modern equipment and suspension, not to mention hand making the turn so this can be done.
Like many things on 2 wheels, someone did it long ago and on lesser equipment! I mean dude couldn't even afford brakes!
KazMan is offline   Reply With Quote
Old March 11th, 2015, 07:08 PM   #308
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Anyway... Don't be shy, got some some lean going on Unregistered? Let's see it.
Best I got
https://www.youtube.com/watch?v=l5XYRJWz9Eo
Old March 11th, 2015, 07:13 PM   #309
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I don't miss that bulky stock pregen exhaust
Old March 11th, 2015, 07:21 PM   #310
fishdip
fishdip's Avatar
Its interesting that video was 2 years ago. same spot 2 years later and I knee the ground on a r6.
Old March 11th, 2015, 08:04 PM   #311
A spectator's view...
Old March 12th, 2015, 02:12 PM   #312
rc racer
rc racer's Avatar
Motorcycle(s): 2015 R3, 1969 CB160, 2002 TTR125, 2007 KX250F
Few pictures from Tracks around Texas. Endurance team bike and red sprint bike.
rc racer is offline   Reply With Quote
Old March 13th, 2015, 06:00 AM   #313
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Is the rear suspension compressed as much as it looks in that bottom picture with the black/gray bike or is it just an angle kinda thing?
it just looks odd in the picture, not sure why it would be so compressed in that instance (just going off the what can be seen in the picture)
Old March 13th, 2015, 07:17 AM   #314
rc racer
rc racer's Avatar
Its pretty compressed, The grey bike is not mine and would be sprung a little firmer if it was, Also that picture is from motorsport ranch in Houston that has bumps all over it so undersprung and likely hitting a bump is why the rear is so low in that shot.
Old March 27th, 2015, 11:45 PM   #315
chris 25Or
Motorcycle(s): 2008 CBR1000rr, 2012 BMW S1000rr, 2011 Ninja 250r, 2015 KTM RC 390, 2013 Triumph 675R
Turn 13 Jennings.
chris 25Or is offline   Reply With Quote
Old March 28th, 2015, 08:50 AM   #316
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I think you guys are doing it wrong. This is lean angle!!!
On a serious note, with everything stock, does anyone know what gets dragged first on the new gen 250 or the 300? I'm assuming it's footpegs? Once the feelers touch down, how much more lean does one generally have?
I'm a conservative rider and I'm just afraid that I'll freak out if, one day, something drags....and I abruptly snap the throttle shut. That would be a bad day during mid corner on the street?
So, let me just put this out here....if something starts dragging and I'm mid corner and I need to maintain the same line (if not, I'll either run out of road or cross the double yellow), what should I do? Do I roll off gently? Or do I just keep the throttle in the position and keep the same lean angle?
Old March 28th, 2015, 10:57 AM   #317
Actually, that was the original point of this thread but I knew it would turn into a pic fest. That's ok, we are having fun here.
I can only speed for a 250 as I haven't ridden a 300 hard enough to get it low.
On a stock 250
Peg feelers (remove)
Pegs
Exhaust
Side stand
If you got the talent and the stones... you can ride through the feels, folding pegs and some of the exhaust and light touches of the sidestand. Once the sidestand or exhaust starts to drag really really hard... you best start thinking about standing it up or lowsiding.
On a race prepped 250
Side stand (remove)
Side stand tab (cut off)
Rearsets
After that... depends on your bikes aftermarket mods
#1 rule of getting a 250 low... DO NOT drag the side stand or side stand mount tab. You're playing with fire when draggin' that. As Rexbo posted early in this thread, once you get really, really low, the 250 is a rite scary machine to ride. The frame flexes, the head chatters, and you get all other kinds of strange feedback from the bike. Sure it looks cool to nearly drag an elbow on a 250, but.... caution should be advised at those lean angles!!!!
Old March 28th, 2015, 11:31 AM   #318
Side stand (remove)
Rearsets
after that there's a pretty big gap until bars and bodywork start hitting and the tail last. tires just aren't made for those kind of lean angles though.
so the lesson is... cut that side stand tab, kids!
Old March 28th, 2015, 11:45 AM   #319
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
The reason I ask is because I ride pretty conservatively and never dragged anything.
It's just that, in the future, if I'm ever in a situation where I went in a corner too hot (street) and the feelers dragged, I'll know I can keep that lean angle to complete the turn.
So....my 2nd question: if the feelers do touch down while I'm mid corner, do I hold the throttle position the way it is? Or should I roll off gently? What can I do with the throttle to either maintain my line (or better yet....tighten my line)?
Old March 28th, 2015, 12:20 PM   #320
burningscooter
clutch
burningscooter's Avatar
Motorcycle(s): L1 GSXR600
if you're going to maintain your line, then, maintenance throttle and gently roll on as you make your way through the corner.
If you're going to tighten your line, then, you can roll off as you've suggested, or you can correct the line with a little front brake.
burningscooter is offline   Reply With Quote
This never gets old. Braking with lean angle. Gurk Riding Skills 33 April 27th, 2014 10:46 AM
[visordown.com] - Caption that the 85 lean angle Ninjette Newsbot Motorcycling News 0 February 25th, 2014 07:00 AM
Got a new Bike and some lean angle ;D WesleySnipes Pictures 7 October 29th, 2013 07:20 PM
[motogp.com] - The Lean Angle Experience Ninjette Newsbot Motorcycling News 0 September 26th, 2013 10:40 AM
Ever wonder what serious lean angle looks like rojoracing53 Videos 6 April 4th, 2013 12:06 AM
