Old June 20th, 2015, 04:18 PM   #1
inplabth
Motorcycle(s): 2006 EX250F
Unhappy Lost carb part, need to find replacement
Hi guys, I bought an 06 Ninja 250 not too long ago and was going through the carbs and I suspect I dropped a piece along the way and I can't find it on the ground. It's part number 9 on the attached image. Is there a place I can buy one of these things? I can't seem to get anything out of google.
Thanks!
inplabth is offline   Reply With Quote
Old June 20th, 2015, 04:21 PM   #2
Ghostt
Ghostt's Avatar
Send @ducatiman for all your carburetor needs.
violente et ignorantia
ZX-2R BLOG
Old June 20th, 2015, 04:58 PM   #3
ducatiman
ducatiman's Avatar
JET-NEEDLE
16017-1326
Your Price: $31.77
ouch....you may choose to check your work area again
$12 used on ebay....free shipping from multiple sources search "ex250 needle jet"
these are common to all 86-07 Keihin CV carbed 250's..spares should be readily available.
Old June 21st, 2015, 01:19 PM   #4
inplabth
Well, thanks for the help buys but I did manage to find it. It was sitting inside of a paper towel that was on the floor. On to the next part of the project, figuring out why only one cylinder is firing. (I'm betting old clapped out spark plugs)
Old June 22nd, 2015, 10:04 AM   #5
blink.
Motorcycle(s): a few
I almost lose the same piece, I was blowing off the carb with compressed air and that piece shot across the garage, took me a good hour to find it.
blink. is offline   Reply With Quote
Old June 22nd, 2015, 01:38 PM   #6
ducatiman
ducatiman's Avatar
with the main jet holder (emulsion tube) removed....they sometimes fall out, sometimes hang in when the carbs are tilted right side up.
Very common for these to go MIA and not find their way back in....resulting in major running/starting problems.
Their presence should be visibly noted upon both disassembly and reassembly.
Especially at $31 each.... jeez
Furthermore, I'd suggest cleaning the inner walls of any gook or slime....I routinely treat them in the ultrasonic machine with other stuff.
Old June 22nd, 2015, 04:06 PM   #7
inplabth
Yup, I went through each and every part in the carb with cleaner after a soak in pine-sol. Seemed to work for the snowmobiles and it's been recommended over on the ninja 250 wiki. In the interest of not throwing up a bunch of threads, I'm consolidating stuff over to a single thread on this restoration project. It's over here.
Can't find carb rebuild kit? redeiko0713 2008 - 2012 Ninja 250R Tech Talk 17 September 28th, 2013 09:32 PM
Unknown carb part dosfiddy 1986 - 2007 Ninja 250R Tech Talk 15 June 12th, 2012 10:10 PM
Carb Sync Screw Replacement? MasterCylinder 1986 - 2007 Ninja 250R Tech Talk 8 April 24th, 2012 07:54 AM
part number/ where to find a... ninja_thresh_hold 2008 - 2012 Ninja 250R Tech Talk 1 September 30th, 2011 06:37 PM
Hex Replacement Screws for Carb bowls and tops g21-30 2008 - 2012 Ninja 250R Tech Talk 2 June 14th, 2010 06:52 PM
