April 18th, 2010, 07:54 AM | #1 |
Join Date: Jan 2010 Motorcycle(s): 2009 Kawasaki Ninja 250r Special Edition Posts: 217
Backfiring and popping
need some info, when i let off the throttle in a higher gear at high speeds, i get a lot of popping and backfiring as the engine slows down. is there a way to fix this? will removing the kleen air system help? its not very common and i can avoid it if i remember, but its just annoying.
April 18th, 2010, 08:01 AM | #2 |
Cleaning your air filter may help if it is dirty and clogged.
April 18th, 2010, 08:35 AM | #3 |
Keenan,
Have you done any mods? If so, what are they? |
April 18th, 2010, 11:15 AM | #4 | |
MOTM - Mar '13, Jun '14
April 18th, 2010, 11:23 AM | #5 |
April 18th, 2010, 02:44 PM | #6 |
MOTM - Sep '18, Feb '16
If you have an after market exhaust plug the top of the valve cover .It is=will stop the popping.
April 18th, 2010, 07:44 PM | #7 |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
April 18th, 2010, 07:52 PM | #8 |
April 20th, 2010, 04:20 PM | #9 |
the only thing ive done is put on a slip on yoshi. i know it makes it run a little leaner...
April 20th, 2010, 04:33 PM | #10 |
If it runs a little leaner you may want to adjust the air/fuel mixture to richen it up. The ninjettes allready run a little lean from the factory.
April 20th, 2010, 04:35 PM | #11 |
remove the Kleen air system.
also, consider shimming the needles, if you want a better responding bike. |
April 21st, 2010, 07:23 PM | #12 |
ok i see what they mean about plugging the hole, mine is a non calif model so no hole to plug.
April 21st, 2010, 07:52 PM | #13 |
April 21st, 2010, 09:01 PM | #14 |
Evap system and Kleen air are different systems, though the evap does feed in to the Kleen air. Evap is cali only, Kleen is on everyone (carb'd at least).
TYGA Performance Moto Maggot backfiring | tygapaul | Videos | 14 | November 12th, 2012 08:49 PM |
Backfiring/Popping & Running Lean | naughtylion | 2008 - 2012 Ninja 250R Tech Talk | 3 | December 13th, 2011 02:45 PM |
new akrapovic slip on.. popping/backfiring questions | ninjaflav | 2008 - 2012 Ninja 250R Tech Talk | 4 | August 4th, 2011 07:04 PM |
Backfiring/popping on deceleration | iggysmalls | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 23rd, 2010 03:37 PM |
Backfiring on Yoshi exhaust? | Ninja007 | 2008 - 2012 Ninja 250R Tech Talk | 8 | February 26th, 2009 01:47 AM |
