August 9th, 2012, 03:17 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): 2012 Kawasaki Ninja 250 Posts: 13
My 2012 Ninja 250 keeps falling ...
Hey I just recently purchased a 2012 Ninja 250 and currently I am going through the MSF training. However the I've fallen twice and I'm a little concerned about the bike. The last time I was going about 70mph and started to slow down before a curve when the clutch completely pulled in and the rear wheel locked up. Can someone tell me what I did wrong? Right now I'm a little paranoid as this wasn't covered during the course specifically. It doesn't help that I don't remember if I downshifted at the same time I pressed both brakes ... it happened wayyy too fast. As a result my clutch is a lot looser than before even after adjusting it. I haven't adjusted it near the engine yet though. I've ridden it since then but now I'm extremely cautious when changing gears and slowing down. Should I be concerned and how in the world do I get the tension back on my clutch? P.S. My friction zone has really shifted.
August 9th, 2012, 03:21 PM | #2 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
Having trouble making out what happened, but I think you should get an R6.
August 9th, 2012, 03:23 PM | #3 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250r Posts: 56
It sounds like you downshifted into too low of a gear for the speed that you were traveling. If you were going 70mph and somehow downshifted multiple times while you tried to slow down, I could definitely see this happening. If you went down at 70, I wouldn't mess around and have a shop look at the bike to make sure it's safe to ride.
August 9th, 2012, 03:30 PM | #4 |
Que Buenos Son!!!
MOTM - Nov '14
If you "fall down" at 70 mph that's not a fall, it's a crash.
August 9th, 2012, 03:52 PM | #5 |
Yeah I'm going to get it looked at just to be safe ... and btw what is a R6? ( I smell an incoming joke) but yeah I may have downshifted too far. The crash basically flipped my gear shift backwards and bent it a little and scratched up the plastics on the left side. Other than that the bike has run fine since as far as just riding around the block. I'm about to take it to a shop but in the meantime are there anytips on how to get more horsepower out of my 250? :-D
August 9th, 2012, 03:56 PM | #6 |
R6 is a 600cc supersport (Yamaha R6). Yes it's a joke, you can see it's origins here:
http://www.ninjette.org/forums/showthread.php?t=109499 |
August 9th, 2012, 04:02 PM | #7 |
Yes I'm going to go and fall down on an R6 Supersport lol... that would be almost equilavent to time travel wouldn't it? The two crashes were basically just me dropping the bike the first time trying to move it across some recently wet dirt or what some would call "Mud" while it was on and it just dropped. The second time is the above incident other than that I just wish it would pick up just a tad quicker without me getting an extreme ankle exercise from shifting so much. Still any tips would be greatly appreciated in how do I get the best out of my bike.
August 9th, 2012, 04:14 PM | #8 |
Join Date: Apr 2011 Motorcycle(s): 2011 Green 250R Posts: 346
Sounds like you need to slow things down a little bit and learn the basics of riding first before flying around at 70 mph.
August 9th, 2012, 04:28 PM | #9 |
Yep I do ... first bike so got a little anxious. BUT I am actually extremely safe on it, the spill was due to a stupid little itch I needed to scratch apparently the pavement of a deserted street did that for me ... as far as top speed I'm good. I just want to be able to get on the highway without cars running up on me in the future. I had gotten a lot better at upshifting which may help with that its just that downshifting seems to be a little different at higher speeds. I also need to find a nearby track to practice on. I dun fell in love with my little 250 ... so like an newborn I'm absorbing as much info as I can and ready to learn... also MSF has given me a lot of helpful info but real-life situations change so rapidly some things seem just a tad different than what the books and the instructors said ... although not that far off.
August 9th, 2012, 04:49 PM | #10 | |
Que Buenos Son!!!
MOTM - Nov '14
or you could take kevheads advice and learn how to ride better. The 250 can go as fast as you need to on the street.
August 9th, 2012, 04:56 PM | #11 |
hmm ... not looking for a major upgrade ... just 5-10 more horses will due just fine... I weigh right at 220 and I love my bike so nah no upgrades for me anytime soon... and I KNOW there are tweakers here that can offer some advice. And yep thats what I need some advice on riding better also ... I know 0 bikers thats why I found this forum
August 9th, 2012, 05:09 PM | #12 | |
Que Buenos Son!!!
MOTM - Nov '14
Anyway, we all got to start somewhere. My advice is to spend your time riding and working on you technique.
August 9th, 2012, 05:10 PM | #13 |
5-10HP is about what I got w an Area P 12" +dynojet kit 2193R
http://areapnolimits.com/products/Sl...-250R-2008.php |
August 9th, 2012, 05:11 PM | #14 | |
August 9th, 2012, 05:18 PM | #15 |
you probably double tapped the lever.
try to be more firm with the shifts and move the ball of your foot to the pegs afterwards, so you don't accidentally hit the lever. |
August 9th, 2012, 05:24 PM | #16 |
better riding skill will surpass 3hp extra any day.
to the OP, dont use the rear brake and it wont lock up. they actually did cover locking the rear brake in the MSF, but their advice is pretty ******. they say to keep it locked until you come to a stop so you dont highside but if yoou are going 70mph approaching a turn, keeping the rear locked is going to make you crash. straighten the bike up and down and release the back brake. dont release a locked rear wheel if you arent straight up and down or you will highside (go flying off of the bike with the bike tumbling away... or right into you... )
August 9th, 2012, 05:24 PM | #17 | |
Que Buenos Son!!!
MOTM - Nov '14
The old gen didn't suffer the same loss of power at the top end. http://areapnolimits.com/images/prod...yno_88_big.gif
August 9th, 2012, 05:34 PM | #18 |
watch twist of the wrist 2 you'll see what we're talking about.
August 9th, 2012, 05:35 PM | #19 |
that website is wrong. they say skittles was the RND bike but i just crashed the RND bike and it wasnt skittles. @Trailerboy531 what the deal is home boy
August 9th, 2012, 05:54 PM | #20 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
Skittles is a whore. Gotta be more specific bro!
http://areapnolimits.com/products/Sl...-Race-2008.php |
August 9th, 2012, 07:56 PM | #21 |
Practice practice practice practice......
You clearly downshifted multiple gears, causing the rear tire to "blip" (slide out, lose control) and crash ensues. Practice. You aren't ready to go 70mph yet
August 9th, 2012, 08:06 PM | #22 |
Join Date: Jun 2012 Motorcycle(s): 09 Ninja 250 Posts: 24
August 9th, 2012, 08:54 PM | #23 |
Join Date: Aug 2010 Motorcycle(s): Bike-less, Can I ride yours? Posts: 318
You blip the throttle (small rev) to match the engine speed of the next gear down. Generally, you want to match the engine speed, however you don't have to as long as you ease the clutch out. He locked the rear tire, theres a difference.
RR stands for Responsible Riding... Right? |
August 9th, 2012, 09:06 PM | #24 |
My my.... slow down before you really hurt yourself because you have been lucky.
Complete your MSF, relax and enjoy some road time without the speed. Build your skills and speed at a comfortable pace. Don't mistake fearlessness for skill and be safe out there!
August 9th, 2012, 09:46 PM | #25 |
This whole time I've been waiting for the legendary Jiggles to come in and say something ... crap ... got my hopes up... BTW I'm getting an R1
August 9th, 2012, 10:07 PM | #26 |
Jigglin' your Jiglets
MOTM - Apr '13
Ask and you shall receive
August 10th, 2012, 01:35 AM | #27 |
August 10th, 2012, 01:44 AM | #28 |
MOTM - Apr '13
Yup, 4 months later and I still can't walk for ****
August 10th, 2012, 09:45 AM | #29 |
Fast-Guy wannabe
MOTM - Jan '13
I recommend a dirt bike to learn basic bike control where your less likely to kill yourself. Then when you hit the street it's just a matter of learning the rules of the road.
August 10th, 2012, 10:48 AM | #30 |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
Do you have your license yet, or is that the reason you are taking the MSF course? Because you where going 70mph either in a residential area or the highway, and you can't ride on the highway without a license.
You really need to slow the F down, for your own good. I rode my bike around my neighborhood just to learn all it's little quirks. and LOL at "my ninja keeps falling", no, you keep making it fall
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips |
August 10th, 2012, 11:04 AM | #31 |
Join Date: Apr 2010 Motorcycle(s): 2010 Ninja 250R Posts: 691
Can I ask the obvious question and why are you downshifting at 70mph for a curve anyways? I'm assuming that you were on a highway (if not why the heck are you going 70mph on surface roads), and the curves there are built for highway speed no need to downshift... at least on a 250.
And why the heck is this in tech talk, this should be under riding skills... |
August 13th, 2012, 09:33 AM | #32 | |
Join Date: Apr 2012 Motorcycle(s): 2008 Kawi Ninja 250R, 2013 Honda CRF450R, 2008 Honda CRF250R, 2001 Honda XR400 Posts: 301
OP, you're right. The ninja does have a serious problem with falling over. I would suggest checking out the following bikes, which seem to have corrected this serious undersight: http://smd.craigslist.org/mcy/3076478200.html http://baltimore.craigslist.org/mcy/3202206542.html http://smd.craigslist.org/mcy/3145224864.html http://smd.craigslist.org/mcd/3152465614.html http://smd.craigslist.org/mcy/3201984075.html And to those people talking about the seizing of the rear tire...it's quite simple. The OP either locked up the rear tire or he downshifted too far. Bikes CAN and WILL lock up the rear if you downshift too far (go from 6th gear to 3rd, while doing 70mph). |
August 13th, 2012, 02:04 PM | #33 |
I hate trikes but this one I would drive. In full leathers of course.
August 14th, 2012, 05:17 AM | #34 |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
Come on OP, really? I have less than 300miles on my ninja. first 180, in my neighborhood, 180-280 on the road and ive gone 60 just a few times for short periods on perfectly new paved roads in the middle of absolutely nowhere with no traffic in front or behind me.
I'm learning by myself aswell, dont know anyone else who rides in the area. Just chill and enjoy maneuvering around in ur neighborhood/empty parking lots near by! Also hope the MSF course goes well. My experience with the msf course was meh. we ended an hour and 45mins EARLY on both riding days....i could have learned so much more in that 2hours . |
August 14th, 2012, 07:07 PM | #35 | ||
Toasted.
Join Date: Aug 2012 Motorcycle(s): 2011 Ninja 250R SE Green Posts: 43
Yeah you should NOT be going 70 when you dont know how to shift. Learn in a parking lot where you dont hurt yourself and someone else, then go on 25 roads until youre comfortable. Youre being dumb for even wanting to go that fast when you clearly havent rode any motorized bike in your life. Dirtbike would be better |
