Old May 14th, 2018, 01:05 PM   #1
tw0611
Motorcycle(s): ex250f18
Oil Change with Liqui Moly 10w40? any idea?
Hi all,
thanks in advance for this possibly silly question. i bought Liqui Moly oil, but just realized that they are for cars, not for bikes. Any idea if it is good idea to use this on my 2004 Ninja 250 (EX250F18)?
Here is the specifics:
Liqui Moly 2042 MoS2 Anti-Friction 10W-40 Motor Oil - 1 Liter Bottle x 2
any comment is appreciated.
tw0611 is offline   Reply With Quote
Old May 14th, 2018, 01:13 PM   #2
Do not guess....
Any oil that is "wet clutch" safe will have a JASO MA rating on the container. If not, take it back and exchange for something that is.
EDIT: my initial research says this oil will not work for your bike but not sure if you are running dino or synthetic
Old May 14th, 2018, 02:18 PM   #3
Not familiar with that specific oil, but any regular (conventional or synthetic - doesn't matter) automotive oil is not a good choice to run in a cycle engine.
The additives are no longer the same for auto and cycle oils. Auto oil lacks the proper amounts of Zinc and Phosphorus (ZDDP) for safe use in a typical motorcycle engine.
An exception would be a "race" or special auto oil with higher levels of ZDDP than the norm.
The inexpensive, easy to get, solution is an oil for diesel engines like Shell Rotella. Rotella T6 is pretty much the standard for cost conscious cycle owners requiring a 40-grade oil (like the Ninja).
Cycle-specific oils are obviously a good choice as well, but any benefit may not be worth the additional cost for some.
Old May 14th, 2018, 02:28 PM   #4
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
i use amsoil metric motorcycle. been using it for years. shop around tons of different stuff out there.
"trying not to get old"
Old May 14th, 2018, 07:04 PM   #5
1994Ninja250F
‘94 Rider
1994Ninja250F's Avatar
Motorcycle(s): 1994 Kawasaki Ninja EX250F
Like others have said, exchange. Can’t exchange? Buy something else with the same specifications as posted above.
Even if you get super expensive oil, you won’t be breaking the bank. The pregen holds exactly 2 quarts (when oil filter is also changed), and I’m pretty sure the 2008+ models have the exact same capacity.
Personally, I wouldn’t even consider buying anything that is not both name-brand, and synthetic. And like others have said, do not buy anything “energy conserving” or “anti friction”.
Last futzed with by 1994Ninja250F; May 15th, 2018 at 10:45 AM.
1994Ninja250F is offline   Reply With Quote
Old May 15th, 2018, 05:57 AM   #6
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
Any oil that says anti-friction is not to be used in wet clutch bikes.
Cafe Racer is offline   Reply With Quote
[roadracingworld.com] - Liqui Moly Products Now Available Nationwide In America Ninjette Newsbot Motorcycling News 0 August 19th, 2016 10:30 AM
[motorcycle.com] - MotoAmerica Announces Liqui Moly As Supporting Partner Ninjette Newsbot Motorcycling News 0 June 1st, 2016 01:40 PM
[roadracingworld.com] - Liqui Moly Signs On As Supporting Partner Of MotoAmerica Ninjette Newsbot Motorcycling News 0 May 31st, 2016 03:10 PM
[roadracingworld.com] - Dorna Sports Names Liqui Moly The Exclusive Oil For The Moto2 Ninjette Newsbot Motorcycling News 0 November 19th, 2014 08:40 AM
[motogp.com] - LIQUI MOLY becomes official oil supplier to Moto2™ and Moto3™ Ninjette Newsbot Motorcycling News 0 November 18th, 2014 04:11 AM
